    UIFlow 1.8.2
    Official Updates
    10
    19
    35.2k
      Hello @m5stack
      thank you for your feedback. Unfortunately it did not resolve the issue.
      I've changed the code to only use a flag my_move in the touch button callback function and then do the real action in the loop.
      Same result: touch screen becomes unresponsive as soon as the S1 servo command has been executed.
      Note: it only happens for servo S1. (Same code with servo S2 works fine.)
      Please test and fix. Thank you.
      from m5stack import *
      from m5stack_ui import *
      from uiflow import *
      import module
      screen = M5Screen()
      screen.clean_screen()
      my_count = None
      my_move = None
      go_plus_2 = module.get(module.GOPLUS2)
      label0 = M5Label('Text', x=110, y=22, color=0x000, font=FONT_MONT_48, parent=None)
      touch_button0 = M5Btn(text='Count', x=100, y=95, w=120, h=50, bg_c=0xFFFFFF, text_c=0x000000, font=FONT_MONT_14, parent=None)
      touch_button1 = M5Btn(text='Servo', x=100, y=173, w=120, h=50, bg_c=0xFFFFFF, text_c=0x000000, font=FONT_MONT_14, parent=None)
      from numbers import Number
      def touch_button0_pressed():
        global my_count, my_move
        my_count = (my_count if isinstance(my_count, Number) else 0) + 1
        pass
      touch_button0.pressed(touch_button0_pressed)
      def touch_button1_pressed():
        my_move = True
        pass
      touch_button1.pressed(touch_button1_pressed)
      my_count = 0
      while True:
        label0.set_text(str(my_count))
        if my_move == True:
          my_move = False
          go_plus_2.set_servo_angle(go_plus_2.S1, 75)
        wait_ms(2)
      • liemphL
        liemph @m5stack
        @m5stack Does it support BaseX? I could not run the same UIFlow script (previously worked) to drive the BaseX.
        • m5stackM
          m5stack @liemph
          @liemph fixed.
          • liemphL
            liemph @m5stack
            @m5stack Thank you very much. I will try.
            • C
              capacious
              Where can the desktop IDE for this version be gotten from?
              I need the Thermal Unit on a Fire but uploading it via the internet connection and the online IDE is very instable.
              I'm only able to download UIFlow-Desktop-IDE version 1.0.17 that contains UiFlow version 1.7.5.
              Creating the file online and then trying to upload it via USB via the lower versioned desktop IDE doesn't work.
              • C
                capacious
                Another thing I notice is that in version 1.8.2 when trying to load the THERMAL demo it 'hangs' and doesn't load anything.
                </> Python is selected with the default imports but Blockly tab can't be opened.
                When switching to version 1.4.5 I can open the THERMAL demo and view it online but there's no stable way of getting it transferred to the Fire running version 1.8.2 as the internet connection to the code platform seems to be very unstable, after several attempts to upload some code it will state that it's UPLOADING (on the screen of the device) but it doesn't succeed as it disconnects from the cloud where I think it's supposed to get the code from.
                The cloud icon then turns red.
                Sometimes it also remains green but still doesn't succeed in getting the code.
                • bob_isatB
                  bob_isat
                  Great Job guys!
                  Would have documentation related to the LORAWAN Module blocks ?
                  Kind Regards,
                  bob_isat
                  • C
                    capacious @capacious
                    @m5stack any idea when the Desktop IDE containing UiFlow version 1.8.2 will be available?
                      Cant connect M5Stamp to Uiflow. firmware installed but not connecting and no wifi host
                      • OyczEO
                        OyczE @ajb2k3
                        @ajb2k3 said in UIFlow 1.8.2:
                        remove Connection to pin0 and EN
                        If programator is connected device is in the download mode.
                          ajb2k3 @OyczE
                          @mati pins not connected.
                          going to try reflashing uiflow.
                          • D
                            Dario @felmue
                            Hello @m5stack, I'm facing the same problem reported by @felmue with Core 2 and GoPlus2. Are you working on this bug?
                            • C
                              ciconde @Dario
                              @dario @m5stack I have the same problem here. Is it going to be fixed?
