    PROJECTS
    25
    89
    416.0k
    • frittnaF
      frittna
      thx!!
      Hi, yes you got it right. The name must be the same when you look at the part of the url accessing a usual binance market with your webborwser.
      But i wanted to mention that i have updated the App a bit more.
      There is no modification with Arduino in the code needed for adjusting the settings.
      Now you can easily burn the app with few clicks, no Arduino needed, if you don't want. You only need a config text file on the root of your sd-card from where settings are read in, then you can eject it or not as you want.
      All settings including wifi, coinpairs, etc will be saved internal. They will update when you put in a modified configuration. No data folder on SD-Card is needed for graphics anymore as they moved back to internal spiffs memory.
      You can simply use M5Burner_Crypto_Coin_Ticker.zip and edit the config file. All done.
      • K
        kevinbrice
        Hello all, thank you so much for the hard work on this project! I created a video demo flashing the M5Stack with the FW, changing the SD card configurations, and 3D printing a desk stand. I hope this helps more novice users get started https://youtu.be/3uQINs6fpio
        • greenleafG
          greenleaf
          Has anyone been able to port this to the Core 2? I tried but the SD Card library seemed to be incompatible.
            m5er
            I saw a crypto project on the M5Stack and had to comment!
            First of all congrats to @frittna for the good execution of the concept. Didn't try it myself, but looks great on the photos!
            Seven years ago I started working on a similar crypto project. Decided to go all the way from idea to market, not just because I love crypto, but because I wanted to gain the learning and experience on the way. It was worth it!
            I've seen a lot of "weekend projects", but none of them had the features I wanted or was easily configurable by non-technical people. So I brought my crypto project to a full commercial product. I call it the TicrThing - your dedicated price ticker. (sorry for the obvious ad)
            The previous versions had custom-made hardware, but they always lacked something... Once I discovered the M5Stack, I thought it was a perfect fit. So I completely re-wrote my code for the M5Stack, wrote also the server side, and released the new product earlier this year. Hope this helps bring the M5Stack platform to a wider audience!
            P.S. It was not my intention to hijack the thread, but to share the story of a similar crypto project and how it evolved to use the M5Stack.
            • frittnaF
              frittna
              Hi, really nice to explore your project! You have really gone thought all the steps which i skipped so far on my ticker. (mobile app to config, fw updates, multiple sources, webstore) NICE and very professional.
                m5er
                For those who are interested in trying out the TicrThing for free, you can now find the firmware in the M5Burner.
                • G
                  gipsyblues @m5er
                  @m5er could you please clarify how to and where to download your version of the crypto ticker to try? M5Burner does not lead anywhere
                  TIA
                  • G
                    gipsyblues
                    Anyone knows how to to obtain TicrThing version of the ticker for test?
                    • A
                      Albman
                      Hi, the M5Stack stand https://shop.m5stack.com/products/btc-standing-base?variant=16804779229274 has an DHT12 sensor for temperature and humidity integrated. I woud like to integrate this output in my BTC ticker. Any hints how to do this? Or where to start? I have not much experience with M5Stack or programming at all...
                      • frittnaF
                        frittna
                        Here you go! I coded some lines. Try this from there: https://github.com/frittna/Crypto_Coin_Ticker
                        just download the M5Burner zip packet, extract it to a path with no spaces in name (causes errors!) run M5burner.exe and select COM + BAUD + Crypto_Coin_Ticker_Sensor_Cel.ino or the Fah version for Fahrenheit and give it a try.
                        BTW: it is a SHT30 Senor built in my base, not a DHT12 although it is written in the description. The temperature is pretty high since the sensor is getting heat from the device itself i guess, maybe a problem of many small devices with temp sensors built in.
                        *** For regular users without the vertical base i recommend to use the normal version because i had to make the info panel a bit larger and loose candle chart hight. **
                        edit: I fixed a bug that the user settings were not saved after a restart - reflash from github if you are affected.
                          m5er @gipsyblues
                          @gipsyblues I suppose you have figured it out by now (and sorry for late reply - I got no notification for this post). In any case, you can download the M5Burner software, connect your M5stack basic (not core2) and flash the TicrThing firmware. Let me know if you encounter difficulties, preferably in a PM so we don't hijack this thread.
                          • A
                            Albman @frittna
                            @frittna You da man! Haven't had the time to have a look back here, so my late reply. Works like a dream! I see also the offset with the temp but it doesn't bother me so much. Maybe the offset could be dealed with by manually giving a correction factor at startup?
                            So thank you very much, I am deeply impressed like only a layman (in coding) can be :-)
                            • P
                              PiriX
                              I have followed the instructions step by step in my M5Stack ESP-32 and that's what I get:
                              Can anyone help me with the mistakes?
                              Arduino: 1.8.16 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
                              WARNING: library Timezone claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
                              File "esptool.py", line 57, in <module>
                              File "/Library/Python/2.7/site-packages/PyInstaller/loader/pyimod03_importers.py", line 389, in load_module
                              File "serial/tools/list_ports.py", line 29, in <module>
                              File "serial/tools/list_ports_posix.py", line 31, in <module>
                              File "serial/tools/list_ports_osx.py", line 32, in <module>
                              Failed to execute script esptool
                              Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/SD
                              Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
                              Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFi
                              Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi
                              exit status 255
                              /Applications/Arduino.app/Contents/Java/arduino-builder returned 255
                              • frittnaF
                                frittna @PiriX
                                @pirix
                                i have not set up an enviroment for compiling in osx yet, i can't say.. sorry
                                @Albman THX! , yea maybe i'll implement a temperature correction some day
                                • P
                                  PiriX @frittna
                                  @frittna I tried with M5Burner in Windows and compiling it on Ubuntu with the same problem: freezes trying to connect to Wi-Fi.
                                  Any option?
                                  • frittnaF
                                    frittna @PiriX
                                    @PiriX
                                    when you say you burned it with the burner than it should work. I only think of a sd config file corruption or something because of not safe ejected.. or some strange letters in wifi-pass.. i dunno..
                                    • P
                                      PiriX
                                      @frittna said in Bitcoin / Multi Crypto Coin Ticker with 24 candlesticks chart:
                                      I tested with my guest wifi: "guest" pass "guest" and doesn't work
                                      • P
                                        PiriX
                                        Now it works...
                                        The problem was "_" in the Wi-Fi
                                        Thank you so much for your patience.
                                        • K
                                          kaos
                                          Hi frittna,
                                          Awersome work for making this for us, its a struggle to keep watch of the crypto market while also living a life away from it.
                                          I'm a noob, but i'm sure if I know exactly where to edit, i could get away with it, so my query is how do edit one of the existing
                                          timezones to get my local timezone option? I'm looking for GMT +8 (Singapore/Kuala Lumpur Timezone). Thanks is advance!
                                          • frittnaF
                                            frittna
                                            Hi and thank you very much. Yea, it's really a good alternative to a pc running all day or checking your mobile all the time. You can focus on other things and have always an eye on it. It's nice to have one under your pc screen btw.
                                            to your question, the corresponding part is the following. You would have to add for example your Zimezone as nr.8 in the code and compile it new in Arduino, then set the same number in the sd-config to load this setting at least once. If you're really new to arduino its a bit tricky with all the libraries and stuff (boardmanager!) but it is documented.
                                            Problem right now is that i dont know where to find the correct TimeChangeRule values for your timezone (UTC+8 is SGT ...?)
                                            Maybe you find some info. I found the lines i used in the code on the web or in Arduino code examples but i know no more zones right now.
                                            here is the part at the beginning
                                            TimeChangeRule summer_aedt = {"AEDT", First, Sun, Oct, 2, 660}; // 0: Australia Eastern Time Zone (Sydney, Melbourne)
                                            TimeChangeRule standard_aest = {"AEST", First, Sun, Apr, 3, 600};
                                            TimeChangeRule summer_bst = {"BST", Last, Sun, Mar, 1, 60}; // 1: United Kingdom (London, Belfast)
                                            TimeChangeRule standard_gmt = {"GMT", Last, Sun, Oct, 2, 0};
                                            TimeChangeRule summer_eest = {"EEST", Last, Sun, Mar, 3, 180}; // 2: Eastern European Time (Bulgaria, Greece, Romania, Ukraine, Egypt)
                                            TimeChangeRule standard_eet = {"EET ", Last, Sun, Oct, 4, 120};
                                            TimeChangeRule summer_cest = {"CEST", Last, Sun, Mar, 2, 120}; // 3: Central European Time Zone (Frankfurt, Paris)
                                            TimeChangeRule standard_cet = {"CET ", Last, Sun, Oct, 3, 60};
                                            TimeChangeRule summer_edt = {"EDT", Second, Sun, Mar, 2, -240}; // 4: US Eastern Time Zone (New York, Detroit)
                                            TimeChangeRule standard_est = {"EST", First, Sun, Nov, 2, -300};
                                            TimeChangeRule summer_cdt = {"CDT", Second, dowSunday, Mar, 2, -300}; // 5: US Central Time Zone (Chicago, Houston)
                                            TimeChangeRule standard_cst = {"CST", First, dowSunday, Nov, 2, -360};
                                            TimeChangeRule summer_mdt = {"MDT", Second, dowSunday, Mar, 2, -360}; // 6: US Mountain Time Zone (Denver, Salt Lake City)
                                            TimeChangeRule standard_mst = {"MST", First, dowSunday, Nov, 2, -420};
                                            TimeChangeRule summer_pdt = {"PDT", Second, dowSunday, Mar, 2, -420}; // 7: US Pacific Time Zone (Las Vegas, Los Angeles);
                                            TimeChangeRule standard_pst = {"PST", First, dowSunday, Nov, 2, -480};
                                            Timezone myTZ0(summer_aedt, standard_aest); // myTZ0: 0 Australia Eastern Time Zone (Sydney, Melbourne)
                                            Timezone myTZ1(summer_bst, standard_gmt); // myTZ1: 1 United Kingdom (London, Belfast)
                                            Timezone myTZ2(summer_eest, standard_eet); // myTZ2: 2 Eastern European Time (Bulgaria, Greece, Romania, Ukraine, Egypt)
                                            Timezone myTZ3(summer_cest, standard_cet); // myTZ3: 3 Central European Time Zone (Frankfurt, Paris)
                                            Timezone myTZ4(summer_edt, standard_est); // myTZ4: 4 US Eastern Time Zone (New York, Detroit)
                                            Timezone myTZ5(summer_cdt, standard_cst); // myTZ5: 5 US Central Time Zone (Chicago, Houston)
                                            Timezone myTZ6(summer_mdt, standard_mst); // myTZ6: 6 US Mountain Time Zone (Denver, Salt Lake City)
                                            Timezone myTZ7(summer_pdt, standard_pst); // myTZ7: 7 US Pacific Time Zone (Las Vegas, Los Angeles);
                                            and later in the code:
                                            ..} else if..=4..
                                            ..} else if..=5..
                                            } else if (myTimeZone == 6) {
                                            time_t now = myTZ6.toLocal(time(nullptr), &tcr);
                                            M5.Lcd.printf("%s %2d.%s %02d:%02d", weekDay_MyLang[weekday(now)], day(now), monthName_MyLang[month(now)], hour(now), minute(now));
                                            } else if (myTimeZone == 7) {
                                            time_t now = myTZ7.toLocal(time(nullptr), &tcr);
                                            here the new else if for nr.8
                                            i think that would be all
