    [SOLVED] ATOM LITE + OLED Unit 1.3" 128 × 64 Display
    Atom
    24.8k
    • C
      cepics
      the library examples doesn't work for me
      I tryed with core gray, core2, atom lite without any result...
      may be I'm missing something......
      • C
        cepics
        some tips???
        • O
          otosan-maker
          why is it not working? Any error code? it is difficult to help you if you give no information.
          • C
            cepics
            I can upload the exemples sketches but nothing is on the display....
            • C
              cepics
              • arduino envirement
              • atom lite
              • oled unit
              • up to date M5GFX
              this is a test sketch:
              #include <M5GFX.h>
              M5GFX display;
              M5Canvas canvas(&display);
              static constexpr char text0[] = "hello world";
              static constexpr char text1[] = "this";
              static constexpr char text2[] = "is";
              static constexpr char text3[] = "text";
              static constexpr char text4[] = "log";
              static constexpr char text5[] = "vertical";
              static constexpr char text6[] = "scroll";
              static constexpr char text7[] = "sample";
              static constexpr const char* text[] = { text0, text1, text2, text3, text4, text5, text6, text7 };
              void setup(void)
                display.begin();
                if (display.isEPD())
                  display.setEpdMode(epd_mode_t::epd_fastest);
                  display.invertDisplay(true);
                  display.clear(TFT_BLACK);
                if (display.width() < display.height())
                  display.setRotation(display.getRotation() ^ 1);
                canvas.setColorDepth(1); // mono color
                canvas.createSprite(display.width(), display.height());
                canvas.setTextSize((float)canvas.width() / 160);
                canvas.setTextScroll(true);
              void loop(void)
                static int count = 0;
                canvas.printf("%04d:%s\r\n", count, text[count & 7]);
                canvas.pushSprite(0, 0);
                ++count;
              this is the arduino ide output:
              Lo sketch usa 301153 byte (22%) dello spazio disponibile per i programmi. Il massimo è 1310720 byte.
              Le variabili globali usano 17052 byte (5%) di memoria dinamica, lasciando altri 310628 byte liberi per le variabili locali. Il massimo è 327680 byte.
              esptool.py v3.0-dev
              Serial port COM8
              Connecting.....
              Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None
              Crystal is 40MHz
              MAC: d8:a0:1d:5c:95:0c
              Uploading stub...
              Running stub...
              Stub running...
              Changing baud rate to 1500000
              Changed.
              Configuring flash size...
              Auto-detected Flash size: 4MB
              Compressed 8192 bytes to 47...
              Writing at 0x0000e000... (100 %)
              Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 4096.1 kbit/s)...
              Hash of data verified.
              Compressed 15856 bytes to 10276...
              Writing at 0x00001000... (100 %)
              Wrote 15856 bytes (10276 compressed) at 0x00001000 in 0.1 seconds (effective 991.0 kbit/s)...
              Compressed 301264 bytes to 153424...
              Writing at 0x00010000... (10 %)
              Writing at 0x00014000... (20 %)
              Writing at 0x00018000... (30 %)
              Writing at 0x0001c000... (40 %)
              Writing at 0x00020000... (50 %)
              Writing at 0x00024000... (60 %)
              Writing at 0x00028000... (70 %)
              Writing at 0x0002c000... (80 %)
              Writing at 0x00030000... (90 %)
              Writing at 0x00034000... (100 %)
              Wrote 301264 bytes (153424 compressed) at 0x00010000 in 2.8 seconds (effective 870.7 kbit/s)...
              Compressed 3072 bytes to 128...
              Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 1365.3 kbit/s)...
              Leaving...
              Hard resetting via RTS pin...
              Trovata libreria non valida in C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher-master: Nessun header file (.h) trovato in C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher-master
              Trovata libreria non valida in C:\Users\Documents\Arduino\libraries\URM-master: Nessun header file (.h) trovato in C:\Users\Documents\Arduino\libraries\URM-master
              this is the serial monitor booting the atom lite
              ets Jun  8 2016 00:22:57
              rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
              configsip: 188777542, SPIWP:0xee
              mode:DIO, clock div:1
              load:0x3fff0018,len:4
              load:0x3fff001c,len:1044
              load:0x40078000,len:8896
              load:0x40080400,len:5816
              entry 0x400806ac
              • C
                cepics
                I think I have to change the i2c pin in the library..... but where??
                • m5stackM
                  you need to #include <M5UnitOLED.h>
                  M5UnitOLED display;
                  static constexpr char text[] = "Hello world ! こんにちは世界! this is long long string sample. 寿限無、寿限無、五劫の擦り切れ、海砂利水魚の、水行末・雲来末・風来末、喰う寝る処に住む処、藪ら柑子の藪柑子、パイポ・パイポ・パイポのシューリンガン、シューリンガンのグーリンダイ、グーリンダイのポンポコピーのポンポコナの、長久命の長助";
                  static constexpr size_t textlen = sizeof(text) / sizeof(text[0]);
                  int textpos = 0;
                  int scrollstep = 2;
                  void setup(void)
                    display.init();
                    display.setRotation(2);
                    canvas.setFont(&fonts::lgfxJapanMinchoP_32);
                    canvas.setTextWrap(false);
                    canvas.setTextSize(2);
                    canvas.createSprite(display.width() + 64, 72);
                  void loop(void)
                    int32_t cursor_x = canvas.getCursorX() - scrollstep;
                    if (cursor_x <= 0)
                      textpos = 0;
                      cursor_x = display.width();
                    canvas.setCursor(cursor_x, 0);
                    canvas.scroll(-scrollstep, 0);
                    while (textpos < textlen && cursor_x <= display.width())
                      canvas.print(text[textpos++]);
                      cursor_x = canvas.getCursorX();
                    display.waitDisplay();
                    canvas.pushSprite(&display, 0, (display.height() - canvas.height()) >> 1);
                  C 1 Reply Last reply Reply Quote 1
                  • C
                    cepics @m5stack
                    @m5stack said in ATOM LITE + OLED Unit 1.3" 128 × 64 Display:
                    M5UnitOLED display;
                    int textpos = 0;
                    int scrollstep = 2;
                    void setup(void)
                      display.init();
                    void loop(void)
                      if (cursor_x <= 0)
                        textpos = 0;
                    this sketch compile but doesn't display nothing
                    no error message
                    this is the atom lite boot on serial monitor after uploaded sketch
                    entry 0x400806ac
                    • O
                      otosan-maker @cepics
                      @cepics said in ATOM LITE + OLED Unit 1.3" 128 × 64 Display:
                      I don´t like it ... please remove it and give a try in the loop with a static string ...
                      And also, put any serial.println() debug code to see what code are you running
                      • C
                        cepics
                        @otosan-maker said in ATOM LITE + OLED Unit 1.3" 128 × 64 Display:
                        ...and give a try in the loop with a static string ...
                        sorry but I don't understand ...
                        I deleted :
                        this is the compiling error message
                            Arduino:1.8.13 (Windows 10), Scheda:"M5Stick-C, Default, 1500000, None
                            C:\Users\Documents\Arduino\OLEDDAJE\OLEDDAJE.ino: In function 'void loop()':
                            OLEDDAJE:41:39: error: 'text' was not declared in this scope
                            Più di una libreria trovata per "SPI.h"
                            Usata: C:\Users\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\1.0.7\libraries\SPI
                            Non usata: C:\Users\Documents\Arduino\libraries\SPI
                            exit status 1
                            Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
                            "Mostra un output dettagliato durante la compilazione"
                            in "File -> Impostazioni
                        • m5stackM
                          //M5UnitOLED display; // default setting
                          M5UnitOLED display ( 21, 22, 400000 ); // SDA, SCL, FREQ
                          • C
                            cepics
                            tnks a lot !!!!
                            this sketch is working for me
                            M5UnitOLED display ( 26, 32, 400000 ); // SDA, SCL, FREQ
                            int textpos = 0;
                            int scrollstep = 2;
                            void setup(void)
                              display.begin();
                            void loop(void)
                              if (cursor_x <= 0)
                                textpos = 0;
