    UIFlow 1.7.8
    Official Updates
    7
    12
    22.5k
    • GiacomoG
      Giacomo
      After the release of UIFlow 1.7.8. I can't upload my custom blocks anymore.
      With 1.7.7. it worked great. Please fix it!
      • m5stackM
        Hi. we already fixed it.
        • MatiM
          Mati
          hey @m5stack
          please fix broken link
          https://docs.m5stack.com/#/en/uiflow/hardware/watch-dog-timer0_1623355141708_be20847f-6316-4780-8bc3-fe31c8d158fe-image.png
          • MatiM
            Mati
            Funny bug, while plaing with Atom Lite and Oled when GUI is hidden all elements with i would like to add or move is going to be delated ...
            https://ibb.co/ryfQjdb
            text alternatywny
            • m5stackM
              m5stack @Mati
              @mati thank you feedback. we will fix as soon as possible.
              I 1 Reply Last reply Reply Quote 1
              • I
                ianlyonthomas @m5stack
                @m5stack where can I download 1.7.8 for desktop?
                I can use 1.7.8 on cloud and it contains functions I need (e.g. UnitV2) but, even o m5stack downloads - I can only get v1.7.4.
                Also, any chance of adding the version number to the file name?
                THanks
                Ian
                • AsmodevA
                  Asmodev
                  What about grabbing the content of a fully-loaded webpage? Where is the javascript functionality? This functionality needs to be implemented into UIFLOW for all M5STICK'S as it otherwise lacks ability for the hardware that is there, Please don't turn into apple.
                  • m5stackM
                    m5stack @ianlyonthomas
                    @ianlyonthomas The update speed of the desktop version will be slower than the online version. If you want to use the latest features, it is recommended that you use the online version.
                    • U
                      UKTechguy @m5stack
                      @m5stack said in UIFlow 1.7.8:
                      Ver 1.7.8 time: 2021.06.04
                      • On-board IR(NEC):
                        • StickC/StickC-Plus/ATOM support.
                      Is there any documentation/example for using the IR Remote Unit to receive and send in the recently added NEC IR mode.
                      I realise that that that it said for the "On-Board" IR on the Stick C Plus but wondered what it means by "Recommended download to the device for use NEC mode" - I can't find any help anywhere unless I use Python and the existence of the "IR Receive Data" implies that I can receive NEC codes using the IR Unit with a Stick C-Plus
                      Many thanks
                      m5stackM G 2 Replies Last reply Reply Quote 0
                      • m5stackM
                        m5stack @UKTechguy
                        @uktechguy
                        the api for IR(NEC)
                        https://docs.m5stack.com/en/mpy/hardwares/ir
                        • G
                          gavin67890 @UKTechguy
                          @uktechguy
                          I can confirm that M5StickC has no receive, only IR Infrared transmit
                          A workaround, if you have a line follower (HW-006) or similar you can use a Grove2Dupont cable to connect the sensor to the M5StickC but (V. IMPORTANT!!!) swap the 5V input to the sensor with jumper cable to the 3V3 of the hat connector on the stick. This will allow a quick test of the receive block associated with the M5Stack IR module block in UIFlow.
                          What I discovered is that the standard transmit block (under Hardware > IR). Only accepts one byte for data and one byte for address. According to the NEC standard (not extended) the first 8 bits are the address and 17-24 bits are the command (NB 'data' is a bit of a loose term, it would be better as 'command' in the UIFlow block, datagram or 'data' to mean the assembled code).
                          Next gotcha, the bits need to be reversed to use with external equipment, note reversed not inversed. Tool for this: https://www.browserling.com/tools/reverse-binary
                          And this tool to swap between binary and hex
                          https://www.rapidtables.com/convert/number/binary-to-hex.html
                          An example:
                          The code I wanted to send: 0x00F7B04F --> the first byte is not the inverse binary of the second, so it is NEC extended and, so far as I can tell, is unsupported in UIFlow - ideally this needs fixed or second block added!
                          2nd attempt to use IR to turn on/off LG TV with book code: 0x20DF10EF
                          Logically, I took 20 to be the address and 10 to be the command ('data' in UIFlow block). Sadly, it wasn't. To make this work the addr and data values need to be reversed therefore 20 --> 0x04 and 10 --> 0x08.
                          Hence, I made the UIFlow block: IR(NEC) send addr 0x04 data 0x08 (alt Python ir.tx(0x04, 0x08)). Triggered from button on Atom this worked on my LG tvs.
                          Interestingly, send and receive between Atom and M5StickC didn't reverse the bits. So, I would assume the same would happen if using the receive to scan from a remote.
                          A couple of other examples:
                          https://flow.m5stack.com/?examples=ir_nec_sender_demo
                          https://flow.m5stack.com/?examples=ir_nec_receiver_demo
                          Some other useful references:
                          https://github.com/esikora/ESP32App_Led_IR/blob/PlatformIO/src/ESP32App_Led_IR.cpp
                          https://exploreembedded.com/wiki/NEC_IR_Remote_Control_Interface_with_8051
                          https://www.sbprojects.net/knowledge/ir/nec.php
                          https://qiita.com/poruruba/items/34220a4dd6aaf48392aa
                          https://docs.m5stack.com/en/unit/ir
                          https://shop.m5stack.com/products/stick-c
