Where is LAN Module example??
I would like to try "LAN Module with W5500 Chip".
+1
I am looking also for the example.
can anyone help with a working LAN Module example for W5500?
Hello M5Stack-Admin,
the link for the LAN-Modul at your homepage is corrupt.
This part didn't work:
Documents ... Example Arduino Example
Please look at "Documents" at this page: https://github.com/m5stack/m5stack-documentation/blob/master/en/product-documents/modules/m5stack_lan_module.rst
I found an example of W5500, but it did not work.
W5500 example is
https://github.com/adafruit/Ethernet2But,I get the following error in my environment.
Failed to configure Ethernet using DHCP
My code is
#include <SPI.h> #include <Ethernet2.h> byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 }; void setup() { Serial.begin(115200); if (Ethernet.begin(mac) == 0) { Serial.println("Failed to configure Ethernet using DHCP"); // no point in carrying on, so do nothing forevermore: for(;;) ; } Serial.print("My IP address: "); for (byte thisByte = 0; thisByte < 4; thisByte++) { Serial.print(Ethernet.localIP()[thisByte], DEC); Serial.print("."); } Serial.println(); } void loop() { }
And, Arduino Example page in M5Stack LAN Module is "Page not found".
M5Stack-Admin,I want you to correspond.
My problem was solved below.
https://github.com/m5stack/M5Stack/tree/master/examples/Modules/W5500
Here is the LAN example
https://github.com/m5stack/M5Stack/tree/master/examples/Modules/W5500I have updated at the m5stack document website
please visit https://m5stack.readthedocs.io/en/latest/product-documents/modules/m5stack_lan_module.html
@nnn Thank you!
Hi!
Here is an example (Korean but you can using code, Simple Chat Server)https://www.wiznetian.com/m5stack-lan-모듈을-이용한-간단한-채팅-서버-만들기/
And I will publish this document in English as soon as possible. :D
