M5stack Fire - no check code for binding device
Hi all!
I hope this question is not too simple. I finally got my new m5stack fire, unboxed it, connected first to the m5-wifi then entered my SSID and let the device reboot. The next step would be to bind the m5stack to my io.m5stack with the check code. BUT: where is this code? The m5stack just shows either a rock paper scissor button test or a screen with some lessons and the information, that no device has been connected yet. No code anywhere to be seen. I am sure, I am just missing something very simple but anyhow - its a blocking point that prevents me from the acutal coding. ;-)
Thanks for your support.
Caly. -
@calypticus Hi, I just have bumped into the same problem as you.
@soogie me three :(
This post is deleted! -
@soogie Hello
Try to burn a M5GO firmware please.
This is the article about how to burn a firmware
https://m5stack.readthedocs.io/en/latest/get-started/how_to_burn_firmware_en.html -
@mynameisdavehi Hello
@watson Thank you, but I use mac.
I will look for some way to burn ith my mac. -
@lukasmaximus Thank you for your comment. I'll see Youtube later.
