    Lcd driver for M5Stack Core2
    29 Posts 4 Posters 96.9k Views 2 Watching
      Russ
      I was able to make concurrent display and sdcard work on the original M5Stacks https://github.com/russhughes/TinyBigBuckBunny but have not been able to make it work on the Core2's yet. I'm not sure why yet.
        Russ
        I was able to get simultaneous display and sdcard access working. The M5CORE2 firmware.bin has been updated. See the tbbunny.py example from https://github.com/russhughes/ili9342c_mpy/blob/main/examples/M5CORE2/tbbunny.py
        W 2 Replies Last reply Reply Quote 1
        • W Offline
          Wolli01 @Russ
          @russ
          Thank you for your work.
          It works now.
          • W Offline
            Wolli01 @Russ
            @russ
            Hello, is there any way to use the three touch buttons as well?
              Russ
              Yes, I’ll add an example working with the touchscreen later tonight.
              • W Offline
                Wolli01 @Russ
                @russ
                Super!
                Thank you for doing this work.
                  Russ @Wolli01
                  @wolli01 Updated repo with two examples using the touchscreen. The buttons on the Core2 are actually part of the touchscreen that extend below the display from about Row 240 to 279.
                  Button press example:
                  https://github.com/russhughes/ili9342c_mpy/blob/main/examples/M5CORE2/buttons.py
                  Very simple paint program:
                  https://github.com/russhughes/ili9342c_mpy/blob/main/examples/M5CORE2/paint.py
                  • W Offline
                    Wolli01 @Russ
                    @russ
                    Thank you very much for your effort.
                    What is this code for in the end?
                    Is it mandatory to use it?
                    finally:
                        # shutdown
                        spi.deinit()
                      ajb2k3 @Wolli01
                      @wolli01 said in Lcd driver for M5Stack Core2:
                      @russ
                      finally:
                          # shutdown
                          spi.deinit()
                      The code de initialises the SPI bus so that that other functions can use the pins or the bus
                      • W Offline
                        Wolli01 @ajb2k3
                        Thanks for the info.
                        Where is the best place to put it in the code
                          Russ @Wolli01
                          @wolli01 At the very end of the program before it quits.
                          W 2 Replies Last reply Reply Quote 0
                          • W Offline
                            Wolli01 @Russ
                            • W Offline
                              Wolli01 @Russ
                              @russ
                              I have a problem with the SD card.
                              My program runs sometimes 1-2 days well through and then when it comes to an error and hangs, it is restarted by the watchdog. When restarting but then no longer the SD card with the command:
                              sd_device = sdcard.SDCard(spi, cs=Pin(4), baudrate=20000000)
                              installed.
                              Do you have a tip what this could be and how I can change it?
                              • W Offline
                                Wolli01
                                @Russ
                                hello,
                                when I install the new firmware 1.16, I get the message that the build rate is unknown.
                                If I go back to 1.14, everything runs without problems.
                                Do you know what the problem could be?
                                  Is the SD card being filled ?
                                  • W Offline
                                    Wolli01 @ajb2k3
                                    Yes works perfectly at the beginning.
                                    Sometimes many days without problems and then is no longer written to the SD card.
                                    Sometimes it no longer works after a few hours.
                                    • W Offline
                                      Wolli01
                                      Is there a way to disable the Core2 in software?
                                      So PowerOff?
                                      • W Offline
                                        Wolli01
                                        SD card unfortunately still does not run through!
                                        I get this error message when the SD card fails.
                                        [Errno 5] EIO
                                        I wonder what the problem is here?
                                        Sometimes it goes only 2 hours and sometimes up to 2 days.
                                        If I log nothing on the SD card, I can just write something on it even after 5 days and it goes. Just not in continuous use.
                                        • W Offline
                                          Wolli01 @Russ
                                          @Russ
                                          I had version 1.14 from you at the time
                                          which worked great for me for years on the M5Stack Core2.
                                          But now there is a new version of Core2 version 1.1
                                          Unfortunately, this version no longer runs with your version 1.14.
                                          Is there a way to make the 1.14 version work with the new firmware 1.1?
                                          The differences between Core2 and Core2 v1.1 are as follows:
                                          1.The power management scheme is iterated from Core2(AXP192) to Core2 v1.1(AXP2101+INA3221). The ID of AXP192 and AXP2101 is different, and the program uses this as a sign to distinguish the versions;
                                          2.The power indicator is changed from green to blue;
                                          3.Add RTC chip power supply battery to ensure accurate timing when power is off.
