    [M5Paper] Ideas/recommendations for a revision or V2 model
    Features Wish List
    m5paper
    6
    22
    76.7k
    • BoRRoZB
      BoRRoZ
      good points !
      • replace the (useless) temp/humidity sensor with a speaker/piezo to create a form of tactile feedback for the touchscreen ('click') or a general 'bleep' .
      • a led indicator when device is on (switchable)
      • B
        bricox
        Instead of ESP32-S3, an ESP32-S2-FN4R2 allows flash and PSRAM to be integrated
        0_1614806518526_edc3dd3d-7d53-4ef7-aa8e-a8c51c524405-image.png https://www.youtube.com/watch?v=iW3xD7Eo5Gw
        Flash equal to M5stack, SDRAM larger than M5stack.
        This allows to release pins to control the eInk with the 74HC4094D, 8-stage shift-and-store bus register, used as IO extander in the LilyGO T5 4.7
        Bill of materials :
        Sorry, comments are in french, my native language ....
        Touch connector :
        Schematic : https://github.com/Xinyuan-LilyGO/LilyGo-EPD47/blob/master/schematic/LilyGo-EPD47.pdf
        SYL
        F B 2 Replies Last reply Reply Quote 0
        • F
          fonix232 @bricox
          @bricox while I like the idea of using a smaller package, I think the ESP32-S3 is a better choice - it's basically the same as the ESP32-S2, however, with added bits that would be quite important for some of the possible applications of the M5Paper, including: SDIO (the S2 has no SDIO interface according to the docs), secure boot and flash encryption, and of course the S3 is dual-core instead of single-core, has larger internal memory (S2 has 320kB SRAM, S3 comes with 512kB), Bluetooth (the S2 is WiFi only)... Overall the S3 is a better package for a solution that needs to provide a bit higher performance and wider range of applications.
          Also, the package you're quoting has considerably smaller flash and PSRAM. The M5Paper comes with 16MB of SPI flash, and 8MB PSRAM - 4x as much as the quoted package. I think it's a good trade-off for slightly less space on the board, and a handful less pins. The LilyGO T5 4.7 made the display work with a shift register, while still having the necessary pins available for external ports.
          The reason why I'd like to see an update to the M5Paper is simply because of this revision's design faults. An ESP32-S2 would be a massive downgrade, and it's not something I'd like to see in a revised, upgraded version that fixes a number of issues, only to bring in a handful of limitations and setbacks.
          • B
            bricox @bricox
            @bricox
            bill of materials most complete
            SYL
            • D
              Dario
              I think that M5Stack is not going to switch to ESP32 S2 or S3 any time soon. At least not before Micropython has a port for these chips.
              • B
                bricox @fonix232
                @fonix232
                on https://www.espressif.com/en/support/documents/technical-documents
                No pdf for S3, just C3
                74HC4094D, IO extander, needs many pins
                ESP32-D0WD => 48 pin (m5paper)
                ESP32-C3-FH4 => 32 pin, with 4 Mo flash only
                ESP32-WROVER => 38 pin (LilyGo), with 16 Mo Flash and 8 Mo SDRAM
                ESP32-S2-FN4R2 => 56 pin, with 4 Mo flash and 2 Mo SDRAM integrated
                SYL
                • B
                  bricox @bricox
                  @bricox
                  Touch connector most complete
                    ajb2k3 @bricox
                    @bricox said in [M5Paper] Ideas/recommendations for a revision or V2 model:
                    @fonix232
                    SYL
                    No data for the S3 exist because it officially doesn't exist.
                    Some WIP samples are out in the wild but the information the testers have and IDF support is incomplete as the silicone can change.
                    • B
                      bricox @ajb2k3
                      Thank you for this information ... ;>)...
                      Unexpected Maker have some for board development
                      SYL
                      • B
                        bricox @fonix232
                        @fonix232
                        2 months ago, you said :
                        "Uhm... Pardon my ignorance but according to my research the IT8591 is a full-blown EPD timing controller, not just a bus register. I don't see how the 74HC4094D would be an alternative (most definitely not a drop-in replacement)."
                        Now :
                        "Replace IT8951 with a better option (maybe just a simple shift register, similar to how the LilyGO T5 4.7 solves it)"
                        Congratulations for this nice evolution in the absence of my late answer ... ;>) ...
                        • B
                          bricox
                          We can also replace the MCU IT8591 with a low power MCU as STM32L0 or STM32L4 family and keep le SPI bus.
                            Hi guys
                            currently the INT line from the touch IC is connected to GPIO36 of the ESP32. This is a poor choice for two reasons:
                            • GPIO36 is an input only GPIO, but to put the touch IC into sleep mode the ESP32 needs to be able to drive and control the touch INT line.
                            • GPIO36 (and GPIO39 for that matter) produce 'ghost' inputs if used as interrupts and WiFi is in use with a power save mode enabled. (This is a hardware limitation / bug of the ESP32.)
                            Thank you for listening.
                            • F
                              fonix232 @bricox
                              @bricox yep, did some research and realised how the shift register can be used in place of the controller. Not sure if it's a definitely better solution. However I like your idea of using a smaller, more power-efficient MCU, especially if it has some deep sleep mode with quick wake.
                              I was also wondering - the IT8951 schematic shows that internally, it's a RISC-V microcontroller with a bunch of attachments (USB, I2C, SPI and SDMMC host interfaces). It also supports (apparently) firmware upgrades. I could not find any sources unfortunately, but, in theory, if we had those sources... Would it be possible to write a more optimised version of this firmware, one that would reduce the power usage? Obviously we don't even know what kind of RISC-V core it has, if it has any low power modes (though the fact that a "sleep" mode is supposedly implemented in it would suggest that it is capable of some sort of sleep mode, the data sheet even details what is powered and how in which state), and so on. Sadly the only documentation we have on this chip comes from an early draft (v0.2.x.x, from Waveshare), and even M5Stack decided not to attach this datasheet to the documentation. I can't help but wonder if they even got the firmware source and build environment, even if under an NDA.
                              • F
                                fonix232
                                Also, my TTGO T5 4.7 arrived, finally. Overall, a nice piece, although a bit rough around the edges compared to the M5Paper. Overall, the PCB seems to be better designed, everything is nicely sectioned apart. But, LilyGO did bum it up, the EPD connector is just sliiiiightly further from the edge than the ribbon itself, which results in some twisting of the cables, and I'm not sure I'm comfortable with it...
                                One thing I'm extremely unhappy with is the battery connector. I opted for the 18650 model (the difference is literally just the connector soldered - with a J2 female connector and 5 minutes of soldering I could convert it easily, but I want to use it with 18650 batteries for easy battery swapping), and the metal wings are outrageously bad quality. They are too rigid, and the edges were not finished properly, and I managed to cut open the wrap of one of my cells on the first insert. This was with great attention paid to the insertion process, and ~3 hours spent on filing down the connector edges (don't worry, I covered the rest of the board with painter's tape, and blasted it with some compressed air to make sure no metal fragments linger around). I think once I have a finalised 3D printed case for it, I'll remove the connector and replace it with a homemade spring-loaded version.
                                Another, interesting thing I noticed while digging around in the guts of the M5Stack... Apparently, there's a second, unpopulated USB-C port on the board. None of the schematics mention it, and I can't really trace it, since the components are too tightly packed: m5paper pcb
                                It's right next (or, in the orientation of the above picture, below) the SD card slot. I'm not sure if it's meant to be a power port only (though the fact the data lines are labeled makes me think it isn't), or if it's directly connected to the IT8951 (which would make sense, since that MCU has a built in USB interface, which allows controlling and even updating the controller).
                                On another note, I reached out to ITE and requested the release of the source code + dev environment for the IT8951 firmware. With any luck, we should have the sources soon, and maybe we can put together a better, less resource-hungry one, just to make the M5Paper that tiny bit better.
                                EDIT:
                                I've been going through the M5Paper schematic to check that USB port and also the USB hookup of the IT8951... First thing I noticed is that the schematic says the M5Paper is supposed to have the IT8951E-64, yet we only have the regular IT8951E.
                                However, I've found the unpopulated Type-C port on the schematics - no idea how I missed it the first time around. It's J8, labeled USB-TYPEC/NC, and its data pins are connected to the IT8951's USB OTG pins, plus the VUSB rail. Meaning that with a quick solder job, one could add a secondary USB-C port that would allow direct communication with the IT8951. With a custom firmware, we could coax that MCU to act as, well, any kind of USB peripheral. And who knows, maybe other stuff could be also offloaded to it. IF we can get the source code for the damn controller. And that's a very big if.
                                • B
                                  bricox @fonix232
                                  @fonix232
                                  In my professional activity, I use the STM32L476.
                                  Its average power consumption is 15-20mA at 80 MHz.
                                  I use "Stop 2" mode to reduce consumption => 2.3µA (5µs wake-up with many sources).
                                  In addition, it has its own RTC with calendar and the ADCs are most linear than ESP32.
                                  • B
                                    bricox @fonix232
                                    @fonix232
                                    USB-TYPEC/NC is not a real USB port because no bridge.
                                    The connector is USB-C but the line is UART only.
                                    • F
                                      fonix232 @bricox
                                      @bricox are you sure about that USB-C port? Because according to the schematics, it goes to the USB lines of IT8951 (IT_DBG_P and IT_DBG_N, pins 52 and 51 on the IT8951, which matches the official IT8951 documentation - the Waveshare adapter board also connects those pins to its USB interface), while the UART lines of it connect to a grayed out (presumably not in the final design?) 4-pin port called J10. As the IT8951 has a built in USB interface, and the default firmware (at least on Waveshare panels) even provides a UMS interface with custom, I believe SCSI, commands similar to the SPI protocol.
                                      There's a red symbol on both the M5Paper and the Waveshare IT8951 driver board's schematics where the IT8951 pins 51 and 52 connect to the USB port, which I do not know the meaning of. Could you enlighten me?
                                      @m5stack could we please get some information on the IT8951? Of course within your NDA limitations. Things like changes you've managed to its firmware (apart from the display specific things like resolution, waveform generation, etc.). Is it possible to modify this firmware to reduce power consumption, introduce the SLEEP mode that is apparently missing, and to update it without hardware modifications (i.e. is there a firmware update solution via SPI, or only USB)?
                                      • B
                                        bricox @fonix232
                                        @fonix232
                                        My apologies, I don’t know how I made that big mistake ... ;>)
                                        You’re right, it’s definitely a native USB.
                                        The red symbol is, for me, that printfoot USB-C connector is on the pcb but not welded.
                                        This part of the schema is not completely greyed out as J10 because the 2 resistors R1 and R60 are welded.
                                        0_1615799393503_6e7b05c0-8cd3-4d95-b710-90b58b42b8d7-image.pngThe Google search with this image did not succeed.
                                        You’d have to look in the symbol library of the design software, I think it’s Altium...
                                        • F
                                          fonix232 @bricox
                                          @bricox The same red symbol appears on the Waveshare schematics for the IT8951 Pi HAT, in the same place (although the M5Paper schematics have the symbol on both the IT8951 and the USB port side, whereas the Waveshare one only has it on the USB port). And based on the second page of that PDF that shows the exact traces, there's nothing between the IT8951's pins and the USB port, just the trace. No resistors, capacitors, nada.
                                          Nonetheless, in my opinion, that USB port could be "easily" soldered in (by someone who knows how to solder properly, i.e. not me), and used to directly communicate with the IT8951, and power the device in the process (the voltage line of this port is also hooked up to the PMIC, just like the main USB port).
                                          • F
                                            fonix232
                                            Okay, so ITE came back to me regarding the IT8951 things. Unfortunately they do not offer the source code directly to developers, only to business partners - and that's M5Stack themselves. @m5stack could you please give us some details, or if the NDA allows, release parts of the IT8951 firmware?
