    M5cam and BMP180
    FAQS
    10.3k
      sheepDog
      I can read the pressure from BMP180 on a M5Stack and with Arduino.
      I can compile the M5cam software, but if I compile with esp-idf a BMP180 example I got a problem.
      I use this sample: https://github.com/krzychb/esp32-everest-run
      I can compile it and M5cam logged on my wifi. Then it read
      W (2116) Altimeter: Weather data retrieval initialized
      ... -> OK
      For the BMP180 I got this error:
      E (9184) BMP180: Sensor not found at 0x77
      E (9189) Altimeter: BMP180 init failed with error = 196610
      Is this a problem with the IO's?
      I used sample used sensor pins sda/scl: 0x19/0x1b
      Is this correct?
      • W
        wschnell
          sheepDog
          Here is am small test program that worked with M5Stack-hardware. With M5cam-hardware it didn't work.
          #include <Wire.h>
          #include <Adafruit_BMP085.h>
          Adafruit_BMP085 bmp;
            Serial.begin(115200);
            //Wire.begin();       //Default
            Wire.begin(25,23);  //M5cam SDA, SCL
            //Wire.begin(21,22);  //M5Stack SDA, SCL
            Serial.println("\nStart program");
            if (!bmp.begin()) {
               Serial.println("Could not find a valid BMP085 sensor, check wiring!");
          	  while (1) {
                       Serial.println("Could not find a BMP085 sensor!");
          	     delay(2000);
              Serial.print("Temperature = ");
              Serial.print(bmp.readTemperature());
              Serial.println(" *C");
              delay(500);
            sheepDog
            The answer is:
                conf.sda_io_num = 13;
                conf.scl_io_num = 4;
