    Tutorial: Using COM.LoRaWAN in UIFlow
    Modules
    8
    15
    27.3k
    • sodokuS
      sodoku
      I wrote a tutorial on using COM.LoRaWAN in UIFlow.
      This is my first tutorial at hackster.io, I would highly appreciate some feedback.
      https://www.hackster.io/sodoku/m5stack-com-lorawan-using-uiflow-fdcd7f
      • ZontexZ
        Zontex
        Hi @sodoku
        Great job! looks amazing, thank you for supporting and sharing it with the community!
        • E
          ehm.education
          Great job. Does this work the same with the old (blue) LoRaWAN module?
          sodokuS 1 Reply Last reply Reply Quote 0
          • sodokuS
            sodoku @ehm.education
            @lasniko you could reuse some parts of the tutorial, but the older blue module uses completely different AT-commands.
            bob_isatB 1 Reply Last reply Reply Quote 0
            • ArnoA
              Arno
              thank you very much for this very valuable information for a beginner like me.
              • H
                holgerw 0
                Great Tutorial,
                please go on with it, would like to find an way to upload sensordata to TTN via ABP.
                I have only an singleGateWay here and it does not let my join via OTAA.
                I am stuck here.
                many greetins from danube/austria
                holger
                • A
                  anvalin
                  Hello @sodoku. Many thanks for sharing the tutorial! I found it on m5stack.hackster.io and it helped me a lot. Registered two COM.LoRaWAN 868MHz modules sucessfully with TTN and managed to see uplinks (alas with long join latency and lots of retrying uplinks though I am in the very middle of Berlin - it seems coverage still has to improve a lot). I am still struggling with the adaption of the official P2P example. Especially regarding use with a sensor in a setup without use of buttons to initiate data requests. If you'd find the time to extend your tutorial his would be much appreciated.
                  Also I wonder about the real life range of the modules. I have currently set them to 5V and cannot pull data beyond 20m distance, line of sight. Seems odd ... what are your experiences? Can this be enhanced using 12V? Maybe a faulty antenna connection?
                  As a side note - all blocks in Flow 1.7.2 are dedicated to the older blue modules - but an implementation for the M031-C is in development, as confirmed by M5Stack support.
                  bob_isatB 1 Reply Last reply Reply Quote 1
                  • sodokuS
                    sodoku
                    @anvalin I am glad I could help. I haven't done an example with sensors yet, because M5Stack said they would release support to the module in UIFlow which would make my example obsolete. I might still do it if I find the time.
                    I think the input power doesn't matter since the 12V will be regulated down to 5V anyway. I am also in Berlin. With a simple P2P test and a TTGO board in my window I recieved packages about 400m away. My record though was getting a connection to an outdoor TTN gateway which is over 8km away!
                    LoRa works best with a line of sight, any buildings inbetween can significantly decrease the signal.
                    • sodokuS
                      sodoku
                      @holgerw-0 didn't see your question. Did you manage to get it working?
                      I haven't used ABP so far, but you should be able to use it by setting the ABP settings from TTN:
                      AT+NwkSKey=kkkk
                      AT+AppSKey=kkkk
                      AT+DevAddr=kkkk
                      and then switching from OTAA to ABP:
                      AT+OTAA=0
                      • A
                        anvalin
                        Hi @sodoku
                        first COM.X LoraWan blocks became available with UI.Flow 1.7.5. Unfortunately still no support for the european frequency model.
                        I now run a public TTN gateway myself covering a portion of the Gleisdreieck area filling a blind spot. Hopefully adding an external LoraWan antenna with higher gain will solve my range problem at my nodes location - half a kilometre distance in a dense urban area can really be a show stopper with LoraWan when there's no gateway around ;)
                        • sodokuS
                          sodoku
                          @anvalin glad you got something working. Your gateway is about 4km away from me. Not sure I will manage to get a connection to you :D
                          • bob_isatB
                            bob_isat @sodoku
                            Hi @sodoku and thanks for the nice tutorial.
                            As @LasNiko , I plan to try the same :Using old blue LORAWAN Module (LORA868) to send data to TTN.
                            Would you have any insights on the commands to use by any chance ?
                            Blocks exists in UIFLOW 1.8.2 but hard to find documentations related to it
                            Cheers,
                            bob_isat
                            • bob_isatB
                              bob_isat @anvalin
                              @anvalin said in Tutorial: Using COM.LoRaWAN in UIFlow:
                              Damned, i had the same expectation! (the 12V to enhance range)...
                              • A
                                anvalin
                                COM.LoRaWAN Module 868MHz V2.0 (ASR6501, product code MS03031-C4) is now listed at retailers. Hopefully this new module will finally see full UIFlow support.
                                • D
                                  Donpedrito
                                  No news for the COM.X 868 Modul in UIFlow. Still not in the UIFlow "Library".
                                  Edit:
                                  @sodoku, the COM.LORAWAN 868 (ASR6501, M031-C) modul has different "AT"-Commands and if i use these commands instead of yours in the description, i could communicate with the modul via Console and USB and can send "payloads" to TTN, but no chance to use some other "programming-blocks" in UIFlow. The AT-Command Introductions are here:
