    PROJECTS
    14
    51
    350.9k
    • P
      picpic020960
      sad that the pre-compiled firmware is no longer available.
      when will he come back
      thanks
      • C
        Calin @picpic020960
        @picpic020960 在 M5Stack MultiApp Advanced Firmware 中说:
        thanks
        Install VsCode, PlatformIO, then flash the project to M5Stack.
        Is a straight forward procedure.
        I removed the pre-compiled firmware because the M5Stack had to be formatted with a specific partition table for pre-compiled firmware to work.
        • P
          picpic020960
          no is straight forward with corporate proxy !
          old version of pre-compiled firmware work fine.
          why partition issue ?
          [pre-compiled firmware is best for MultiApp popularity]
          thanks
          • C
            Calin @picpic020960
            Well... yeah... you are right on this one...
            thanks
            Ok... i will bring it back later today...
            • P
              picpic020960
              Hi Calin
              tested last night ! sync , download , finish , reset and ... black screen
              maybe my error : use the old [not Advanced] FLASH_DOWNLOAD_TOOLS_V3.6.4.zip
              other way : 'old MultiApp' is OK without SD card and no jpg , maybe 'Advanced' no ?
              more : windows 10 (on thomson tablet)
              my fear :have bad clone !
              I test again tonight
              Regards
              • C
                Calin @picpic020960
                Hi Calin
                Regards
                As i told you... the best solution is to COMPILE the project on PlatformIO.
                The M5Stack came with default factory partitions table.
                That partition table is incompatible with MultiApp-Advanced firmware.
                Old MultiApp firmware use standard partitions table and that's why that precompiled binary work.
                The precompiled firmware only write the application data. So precom piled binary will be useful only if you try to update the multiapp-advanced firmware to a newer version.
                Will NOT work if you try to write the multiapp-advanced over a different application.
                On MultiApp-advanced i use a custom partition table that is written if you compile and upload the project from PlatformIO.
                • P
                  picpic020960
                  Hi Calin , OK
                  Download (and unzip) this repository ==> OK
                  Download and Install Visual Studio Code https://code.visualstudio.com/ ==>OK
                  Install the PlatformIO Extension ==> OK
                  Install ESP32 Framework on PlatformIO ==> How TO ? no link and a lot of ESP32 framework
                  thanks for help
                  Regards
                  • C
                    Calin @picpic020960
                    Hi Calin , OK
                    thanks for help
                    Regards
                    Go to Platforms
                    Type in ESP32 on the search bar
                    Click on Espressif 32
                    Click INSTALL
                    Wait to finish (this may take 1 - 5 minutes, depending on your internet connection speed)
                    Done.
                    To open MultiApp Advanced project:
                    right click on the project folder
                    Select "Open in VsCode"
                    VsCode will open and the project will be loaded in PlatformIO
                    You don't need to install any library to compile the MultiApp-Advanced. All necessary resources are included into project.
                    • P
                      picpic020960
                      Calin
                      first compil :
                      src\Apps\WiFiWps\WpsConnect.cpp:73:16: error: no match for 'operator=' (operand types are 'esp_wps_config_t' and '<brace-enclosed initializer list>')
                      some mistake ?
                      edit :
                      commented ==> Build OK
                      but how to load the firmware in the m5stack ?
                      other question : how to apply the patch ?
                      thanks for help
                      Regards
                      • C
                        Calin @picpic020960
                        Calin
                        first compil :
                        some mistake ?
                        No. There is no mistake.
                        PlatformIO updated the Arduino-ESP32 framework to new version.
                        I updated the MultiApp firmware to work with this new version.
                        If you use git, just pull the latest commit from github and recompile.
                        If not, download the repository again then compile.
                        edit :
                        Please READ the repository instructions !
                        The old patch is no longer needed... because Espressif fixed the GPIO39 bug on the latest arduino-esp32 framework.
                        • P
                          picpic020960
                          Hi Calin
                          when m5stack not connected i see ' <version....py>' at end of build report.
                          (from memory , now at work , not at home)
                          when m5stack connected i see nothing at end of build report.
                          i have com1 and com4. how to choose ?
                          thanks for help
                          Regards
                          • C
                            Calin @picpic020960
                            Hi Calin
                            thanks for help
                            Regards
                            You don't have to chose anything.
                            No need to select the upload port.
                            PlatformIO will detect the M5Stack port automatically, once is connected to PC USB.
                            • KabronK
                              Kabron
                              New version compilation results:
                              M5StackMod initializing...[E][sd_diskio.cpp:739] sdcard_mount(): f_mount failed 0x(3)
                              E (705) SPIFFS: mount failed, -10025
                              [E][SPIFFS.cpp:47] begin(): Mounting SPIFFS failed! Error: -1
                              OK
                              [E][Preferences.cpp:330] getUShort(): nvs_get_u16 fail: light NOT_FOUND
                              and nothing more...
                              any ideas?
                              • C
                                Calin @Kabron
                                @kabron 在 M5Stack MultiApp Advanced Firmware 中说:
                                OK
                                and nothing more...
                                any ideas?
                                Please update the Espressif 32 platform to latest version (v1.1.1 at this moment)
                                That should solve the problem.
                                • KabronK
                                  Kabron @Calin
                                  @calin 在 M5Stack MultiApp Advanced Firmware 中说:
                                  I have 1.1.2 installed and do not know how to degrade
                                  P.S.
                                  degrade with
                                  platform = espressif32@1.1.1
                                  and now it works
                                  • C
                                    Calin @Kabron
                                    P.S.
                                    degrade with
                                    and now it works
                                    I just tested with espressif32 V1.1.2 and work's just fine.
                                    Please download the latest repository commit and compile.
                                    it should work just fine.
                                    • R
                                      Rodlenz
                                      Hi Calin, thanks for this amazing work. How I can add my own code/Application? Tks in advance for any help you can provide. brgds.
                                      ? 1 Reply Last reply Reply Quote 0
                                        A Former User @Rodlenz
                                        Hi
                                        somebody make a test with Netatmo ?
                                        I would like to be sure before start this install to see if there are possibility to connect via API key to netatmo server.
                                        interest by this
                                        Thx
                                        • B
                                          brianbgarber
                                          Hello, I realize this topic is very old but I'm trying to compile the MultiApp Advanced firmware. I'm getting several compile issues:
                                          1. src/Apps/WiFiWps/WpsConnect.cpp:30:12: error: 'struct esp_wps_config_t' has no member named 'crypto_funcs'
                                          2. src/Apps/WiFiWps/WpsConnect.cpp:30:28: error: 'g_wifi_default_wps_crypto_funcs' was not declared in this scope
                                          3. src/Apps/WiFiWps/WpsConnect.cpp:90:27: error: no matching function for call to 'onEvent(void (&)(arduino_event_id_t, system_event_info_t))'
                                          4. src/Apps/WiFiWps/WpsConnect.cpp:90:18: error: invalid conversion from 'void ()(arduino_event_id_t, system_event_info_t)' to 'WiFiEventSysCb' {aka 'void ()(arduino_event_t*)'} [-fpermissive]
                                          5. *** [.pio\build\esp-wrover-kit\src\Apps\WiFiWps\WpsConnect.cpp.o] Error 1
                                          6. lib/ESP32Audio/src/AudioOutputI2S.cpp:190:10: error: 'i2s_write_bytes' was not declared in this scope
                                          7. *** [.pio\build\esp-wrover-kit\lib803\ESP32Audio\AudioOutputI2S.cpp.o] Error 1
                                          I did clone the git repo today, so everything should be up to date. Looks like I'm missing some library?
                                          Thanks,
                                          Brian
