    RTC Core2
    UIFlow
    10.7k
    • P
      Piet
      Set time using NTP host reports an error for the 'year' and needs to be set using a constant.
      Hour reports incorrectly. 1 hour needs to be added for UTC + time zone.
        Hello @Piet
        could you share your UIFlow code? I can read hour, min, sec, day, month and year just fine, no error.
        • P
          Piet
          • P
            Piet
            Year reports correctly with V1.7.2
              Hello @Piet
              ok, I think I see now what you mean. Interestingly there seems to be a difference between Hardware - RTC and Advanced - NTP. Using the functions from RTC then yes, the hour is off by 1. If I use the NTP functions, the hour is correct.
              • P
                Piet
                thank you
                • ZontexZ
                  Zontex @Piet
                  @piet glad you got it sorted out :)
