    microWebSrv2 on M5atom lite with micropython
    SOFTWARE
    4.3k
    • E
      Eriks
      I'm trying to install the web server microWebSrv2 on a M5atom lite.
      github microWebSrv2
      Has anyone done this before without freezing?
      Would be grateful for any hint.
      I copied the files with ampy to the m5atom lite, here is the file structure on the M5atom lite:
      /ConnectWiFi.py
      /MicroWebSrv2/init.py
      /MicroWebSrv2/httpRequest.py
      /MicroWebSrv2/httpResponse.py
      /MicroWebSrv2/libs/XAsyncSockets.py
      /MicroWebSrv2/libs/XAsyncSocktes.py
      /MicroWebSrv2/libs/urlUtils.py
      /MicroWebSrv2/microWebSrv2.py
      /MicroWebSrv2/mods/PyhtmlTemplate.py
      /MicroWebSrv2/mods/WebSockets.py
      /MicroWebSrv2/webRoute.py
      /SSL-Cert/openhc2.crt
      /SSL-Cert/openhc2.key
      /boot.py
      /img/microWebSrv2.png
      /lib/urequests.py
      /main.py
      /www/favicon.ico
      /www/index.html
      /www/pdf.png
      /www/style.css
      /www/test.pyhtml
      /www/wschat.html
      /www/wstest.html
      And run into this error when booting:
      Connection successful
      ('192.168.1.46', '255.255.255.0', '192.168.1.1', '192.168.1.1')
      running on M5atom lite
         - Python pkg MicroWebSrv2 -
         -      version 2.0.6      -
         -     by JC`zic & HC2     -
      I (6206) modsocket: Initializing
      • [@WebRoute] GET /test-redir
      • [@WebRoute] GET /test-post (TestPost1/2)
      • [@WebRoute] POST /test-post (TestPost2/2)
      File "main.py", line 153, in <module>
      File "MicroWebSrv2/microWebSrv2.py", line 136, in LoadModule
      MicroWebSrv2Exception: Cannot load module "WebSockets".
      MicroPython v1.13 on 2020-09-02; TinyPICO with ESP32-PICO-D4
      this is raised by this code in MicroWebSrv2/microWebSrv2.py:
      @staticmethod
      def LoadModule(modName) :
          if not isinstance(modName, str) or len(modName) == 0 :
              raise ValueError('"modName" must be a not empty string.')
          if modName in MicroWebSrv2._modules :
              raise MicroWebSrv2Exception('Module "%s" is already loaded.' % modName)
          try :
              modPath  = MicroWebSrv2.__module__.split('microWebSrv2')[0] \
                       + ('mods.%s' % modName)
              module   = getattr(__import__(modPath).mods, modName)
              modClass = getattr(module, modName)
              if type(modClass) is not type :
                  raise Exception
              modInstance = modClass()
              MicroWebSrv2._modules[modName] = modInstance
              return modInstance
          except :
              raise MicroWebSrv2Exception('Cannot load module "%s".' % modName)
      • R
        robalstona
        It's probably a typo. I think there should be a / on the line instead of .
        Instead:
        i think it should be:
        ('mods/%s' % modName)
        or
        ('mods\\%s' % modName)
