    Disconnect speaker
    3 Posts 3 Posters 6.6k Views 1 Watching
      tialm
      Hi! My m5stack fire is making some loud white noise and I can't turn it off even with
      p = Pin(25)
      dac0 = DAC(p)
      dac0.write(0)
      Can I disconnect the speak safely if I don't ever intend to use it? Like cut the cable and remove it?
      Thank you!
      m5stackM world101W 2 Replies Last reply Reply Quote 0
      • m5stackM Online
        m5stack @tialm
        @tialm make sure you don't want to use it. remove the bottom you could see the speaker cable. you could cut the cable remove it.
        • world101W Offline
          world101 @tialm
          @tialm
          Or you can try this as well:
          https://community.m5stack.com/topic/367/mod-to-programmatically-disable-speaker-whine-hiss
