I do have demo micropython code for that found here PaHub Code Demo
It was built using UIFlows blocks but alas I didn't save the file :(
BTW you have to initialise the i2c port before accessing it.
I don't think the Stick C can power it which I think is the reason that it is disabled in UIFLow.
Its common bug, neither Core nor Stick would connect to AP with space in its name. e.g. will not connect to "My Wifi" network, but will work with "MyWifi". %20 trick also didnt work for me, had to rename mine aswell
Hi @lsy51739488 I just tested Stick C on both beta and 1.3.2 Uiflow with no connection issues. I was using firmware 1.3.5 firmware but older firmwares should also work fine. Are you still having issues?
The Api key is for connecting your stick c to the online version of uiflow (flow.m5stack.com) in the settings menu you can enter your apikey and switch from m5stack unit to stick c unit
The interesting thing is in USB mode you still get an apikey. I tried entering that key in the online version of UIFlow and it is not working...
It wont work because in USB mode the M5Stack has not connected over the wifi and so the online UIFlow cannot find it.
This is a bug or a feature of the upcoming WebUSB function coming soon.
Thanks, lets hope it is a feature for the online version of UIFlow instead of a bug :)
@brett do you want to rotate the whole display or simply some of the graphic elements? As @ajb2k3 stated the rotation option is available for the text label, but elements such as the rectangle or triangle graphic elements are not rotatable due to the module they are based on not supporting this feature.
Hey Kenny, just wondering why you would want to get the image width and height if you already prepared an image that fits within the screens confines, I would have thought you'd already know the size of your image. If you can give me a valid reason I can see if we can include those functions in the M5IMG library
@hetzer that would be great.
In my scrolling and bouncing text demo's the same location 0,0 is also used for detecting the edge of the screen which is proving rather annoying.
