<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved]My M5Go can&#x27;t connect to flow.m5stack.com]]></title><description><![CDATA[<p dir="auto">I have updated my M5GO to UIFlow-v1.2.3 then I got a new API key and now it can't connect to <a href="http://flow.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">flow.m5stack.com</a><br />
I tried to rewrite the firmware several times. But the problem persists. How do I fix it?</p>
]]></description><link>https://community.m5stack.com/topic/974/solved-my-m5go-can-t-connect-to-flow-m5stack-com</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 21:35:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/974.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 May 2019 09:13:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved]My M5Go can&#x27;t connect to flow.m5stack.com on Sun, 05 May 2019 10:11:08 GMT]]></title><description><![CDATA[<p dir="auto">Server hangs</p>
]]></description><link>https://community.m5stack.com/post/4130</link><guid isPermaLink="true">https://community.m5stack.com/post/4130</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Sun, 05 May 2019 10:11:08 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]My M5Go can&#x27;t connect to flow.m5stack.com on Thu, 02 May 2019 16:52:16 GMT]]></title><description><![CDATA[<p dir="auto">if you can connect to m5flow you should be good to go.<br />
Once the correct SSID and password is put into the M5go once, it will stay there.<br />
how far do you get when you follow the connection guide in this document?<br />
<a href="https://github.com/Ajb2k3/UIFlowHandbook/blob/master/UIFlowhandbook.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Ajb2k3/UIFlowHandbook/blob/master/UIFlowhandbook.pdf</a></p>
]]></description><link>https://community.m5stack.com/post/4095</link><guid isPermaLink="true">https://community.m5stack.com/post/4095</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 02 May 2019 16:52:16 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]My M5Go can&#x27;t connect to flow.m5stack.com on Thu, 02 May 2019 10:16:46 GMT]]></title><description><![CDATA[<p dir="auto">And now i can connect to M5Go with FlowUI by connecting to the internet without doing anything with my M5Go.<br />
I don't know what the cause of the problem is.</p>
]]></description><link>https://community.m5stack.com/post/4094</link><guid isPermaLink="true">https://community.m5stack.com/post/4094</guid><dc:creator><![CDATA[watcharakorn]]></dc:creator><pubDate>Thu, 02 May 2019 10:16:46 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]My M5Go can&#x27;t connect to flow.m5stack.com on Thu, 02 May 2019 10:07:22 GMT]]></title><description><![CDATA[<p dir="auto">Now M5Go can connect to the <a href="http://flow.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">flow.m5stack.com</a> without doing anything. But I still can't connect with FlowUI</p>
]]></description><link>https://community.m5stack.com/post/4093</link><guid isPermaLink="true">https://community.m5stack.com/post/4093</guid><dc:creator><![CDATA[watcharakorn]]></dc:creator><pubDate>Thu, 02 May 2019 10:07:22 GMT</pubDate></item></channel></rss>
