<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved]M5Stack, Arduino, RFID Module example needed]]></title><description><![CDATA[<p dir="auto">Hi there, is there an example somewhere that shows how to use an RFID rc522 i2c module (module like in this post: M5Stick-C can not detected RFID Unit). I have no idea what I need to make it working (libraries and possibly other wiring). I am using the M5Stack with Arduino and installed software from here: <a href="https://github.com/miguelbalboa/rfid" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/miguelbalboa/rfid</a>. Probably not usable because it shows the library might be incompatible.<br />
Someone out there that can give me a kickstart with tutorial example how to use these three together (Arduino, M5Stack and RFID module)?</p>
]]></description><link>https://community.m5stack.com/topic/970/solved-m5stack-arduino-rfid-module-example-needed</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Mar 2026 14:04:50 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/970.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Apr 2019 16:52:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Fri, 10 Apr 2020 17:07:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Sorry for pulling this olde thread up.</p>
<p dir="auto">I really need an Arduino example on how to read and write I can't seem to find any examples on that.</p>
Christian</p>
]]></description><link>https://community.m5stack.com/post/8098</link><guid isPermaLink="true">https://community.m5stack.com/post/8098</guid><dc:creator><![CDATA[ChristianH]]></dc:creator><pubDate>Fri, 10 Apr 2020 17:07:33 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Tue, 07 May 2019 13:34:06 GMT]]></title><description><![CDATA[<p dir="auto">Yes, you should use the I2C code to experiment. Looks like I won’t be able to help more for another two weeks until mine arrives</p>
]]></description><link>https://community.m5stack.com/post/4177</link><guid isPermaLink="true">https://community.m5stack.com/post/4177</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 07 May 2019 13:34:06 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Tue, 07 May 2019 12:01:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> To understand correctly. The M5Stack can use both SPI and I2C (as does the ESP32), however the RFID device I have (and you ordered) only uses I2C,  and the code for the library I mentioned only supports SPI. The code you both mentioned supports I2C (Grove Port device). So assuming the tag functions suffice I should use that. Correct or nonsense.</p>
]]></description><link>https://community.m5stack.com/post/4174</link><guid isPermaLink="true">https://community.m5stack.com/post/4174</guid><dc:creator><![CDATA[Kees]]></dc:creator><pubDate>Tue, 07 May 2019 12:01:30 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Mon, 06 May 2019 10:28:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1407">@kees</a> said in <a href="/post/4141">[Solved]M5Stack, Arduino, RFID Module example needed</a>:</p>
<p dir="auto">Thanks, both(?). I ran the example and it does seem to work. I also saw that an addition for this library is in the pipeline: <a href="https://github.com/miguelbalboa/rfid" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/miguelbalboa/rfid</a> to also support ESP32.<br />
I can continue building software for the M5Stack hardware with my requirements using, among others, the RFID module, the same ajb2k3 ordered.<br />
Again, thanks!!!</p>
<p dir="auto">The code base doesn't support I2C which is used By the M5Stack device.</p>
]]></description><link>https://community.m5stack.com/post/4150</link><guid isPermaLink="true">https://community.m5stack.com/post/4150</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 06 May 2019 10:28:48 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Mon, 06 May 2019 09:23:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1407">@kees</a> Have a good day.</p>
]]></description><link>https://community.m5stack.com/post/4148</link><guid isPermaLink="true">https://community.m5stack.com/post/4148</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 06 May 2019 09:23:59 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Sun, 05 May 2019 16:01:10 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, both(?). I ran the example and it does seem to work. I also saw that an addition for this library is in the pipeline: <a href="https://github.com/miguelbalboa/rfid" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/miguelbalboa/rfid</a> to also support ESP32.<br />
]]></description><link>https://community.m5stack.com/post/4141</link><guid isPermaLink="true">https://community.m5stack.com/post/4141</guid><dc:creator><![CDATA[Kees]]></dc:creator><pubDate>Sun, 05 May 2019 16:01:10 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Sun, 05 May 2019 10:43:45 GMT]]></title><description><![CDATA[<p dir="auto">There is sample code here - <a href="https://docs.m5stack.com/#/en/unit/rfid" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/rfid</a></p>
<p dir="auto">I have ordered one and will see what I can do, btw had to order cards from elsewhere.</p>
]]></description><link>https://community.m5stack.com/post/4137</link><guid isPermaLink="true">https://community.m5stack.com/post/4137</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 05 May 2019 10:43:45 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Sun, 05 May 2019 10:19:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1407">@Kees</a>  Have you tried this code?<br />
<a href="https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Unit/RFID/Arduino" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Unit/RFID/Arduino</a></p>
]]></description><link>https://community.m5stack.com/post/4133</link><guid isPermaLink="true">https://community.m5stack.com/post/4133</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Sun, 05 May 2019 10:19:14 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Wed, 01 May 2019 23:02:58 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, this was very helpful. So now the problem is software. As I stated in the first part of the topic: I use software found at <a href="https://github.com/miguelbalboa/rfid" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/miguelbalboa/rfid</a>. Has anyone experience with this in combination with Arduino, M5Stack and the RFID Module with RC522? Or perhaps anyone tells me to use a different IDE and language (I have enough experience with C, but not C++). All suggestions are welcome.</p>
]]></description><link>https://community.m5stack.com/post/4088</link><guid isPermaLink="true">https://community.m5stack.com/post/4088</guid><dc:creator><![CDATA[Kees]]></dc:creator><pubDate>Wed, 01 May 2019 23:02:58 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Wed, 01 May 2019 17:49:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1407">@kees</a> said in <a href="/post/4083">M5Stack, Arduino, RFID Module example needed</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> Okay, I found the I2C tester and ran it. It shows the addresses 0x68 and 0x75. With the device attached it also shows 0x28. When not attached this disappears. Does this mean the device can be found and the hardware wiring is okay? If so the focus is on a software problem.</p>
<p dir="auto">Yes, that is correct, 0x28 is the address so it is being read.<br />
The RFID uses the MFRC522 to read and write to 13.56MHz devices.<br />
Try looking for guides on the MRFC522 readers</p>
]]></description><link>https://community.m5stack.com/post/4085</link><guid isPermaLink="true">https://community.m5stack.com/post/4085</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 01 May 2019 17:49:42 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Wed, 01 May 2019 08:25:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> Okay, I found the I2C tester and ran it. It shows the addresses 0x68 and 0x75. With the device attached it also shows 0x28. When not attached this disappears. Does this mean the device can be found and the hardware wiring is okay? If so the focus is on a software problem.</p>
]]></description><link>https://community.m5stack.com/post/4083</link><guid isPermaLink="true">https://community.m5stack.com/post/4083</guid><dc:creator><![CDATA[Kees]]></dc:creator><pubDate>Wed, 01 May 2019 08:25:55 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack, Arduino, RFID Module example needed on Tue, 30 Apr 2019 17:54:21 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried the I2C scanner to find the RFID device?</p>
]]></description><link>https://community.m5stack.com/post/4079</link><guid isPermaLink="true">https://community.m5stack.com/post/4079</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 30 Apr 2019 17:54:21 GMT</pubDate></item></channel></rss>
