<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Custom Prototype Board]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1518455650541-proto-v1-boards-resized.jpg" alt="0_1518455651155_Proto v1 Boards.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">I ordered the M5Stack Proto board along with the core unit hoping to develop a working prototype that could be shown to potential users. While the board is fine I quickly realised that you couldn't use the battery back cover since wiring for the through holes would need to be connected to the female header.</p>
<p dir="auto">This was a shame as it would make demonstrations require another power source and would show the internals underneath. So I have created my own version based on the M5Stack Proto board which fits into the shell.</p>
<p dir="auto"><img src="/assets/uploads/files/1518455994044-proto-v1-top-resized.jpg" alt="0_1518455989064_Proto v1 Top.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">The header pads are connected to to first two rows of through holes allowing you to connect into the pins and replace the battery back cover.</p>
<p dir="auto"><img src="/assets/uploads/files/1518456159787-proto-v1-bottom-resized.jpg" alt="0_1518456152119_Proto v1 Bottom.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">The pins follow the same vertical order but reversed horizontally i.e. the first header pads are connected to the second through hole. Both GND and HPWR pins are also connected and the holes tied together as with the header.</p>
<p dir="auto">I have ordered a few sets of header pins from M5Stack which should arrive this week and then test to see if it works. The spacing of the tracks for the first header row are outside production tolerrance, however I will be only connecting a few pins at a time and it is for development purposes only.</p>
]]></description><link>https://community.m5stack.com/topic/95/custom-prototype-board</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 03:01:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/95.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Feb 2018 17:31:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Custom Prototype Board on Mon, 11 Oct 2021 11:03:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/saiaman01" aria-label="Profile: saiaman01">@<bdi>saiaman01</bdi></a></p>
<p dir="auto">don't know about the PCB, but the 3D case is <a href="https://github.com/m5stack/M5-3D_and_PCB/blob/master/PROTO.stl" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/15095</link><guid isPermaLink="true">https://community.m5stack.com/post/15095</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 11 Oct 2021 11:03:29 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Mon, 11 Oct 2021 08:22:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/suremicro" aria-label="Profile: suremicro">@<bdi>suremicro</bdi></a> sorry its been a long time, but do you still have pcb/3D case somewhere ?<br />
Gonna github / easyeda ... nothing found :(</p>
]]></description><link>https://community.m5stack.com/post/15094</link><guid isPermaLink="true">https://community.m5stack.com/post/15094</guid><dc:creator><![CDATA[saiaman01]]></dc:creator><pubDate>Mon, 11 Oct 2021 08:22:00 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Thu, 09 Aug 2018 09:16:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/suremicro" aria-label="Profile: suremicro">@<bdi>suremicro</bdi></a> 在 <a href="/post/1248">Custom Prototype Board</a> 中说：</p>
<p dir="auto">Yes, if you head over to <a href="https://easyeda.com/zazarltd" target="_blank" rel="noopener noreferrer nofollow ugc">https://easyeda.com/zazarltd</a> the design is there which you can use to get your own boards made. I used JLCPCB.</p>
<p dir="auto">Haven't used JLCPCB, I've used Seeedstudio Fusion service <a href="https://www.seeedstudio.com/fusion_pcb.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.seeedstudio.com/fusion_pcb.html</a> a few times. They are especially good if you need several of the same board as they send 10 copies</p>
]]></description><link>https://community.m5stack.com/post/1392</link><guid isPermaLink="true">https://community.m5stack.com/post/1392</guid><dc:creator><![CDATA[Omoe]]></dc:creator><pubDate>Thu, 09 Aug 2018 09:16:45 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Thu, 23 Aug 2018 15:11:00 GMT]]></title><description><![CDATA[<p dir="auto">Yes, if you head over to <a href="https://easyeda.com/suremicro" target="_blank" rel="noopener noreferrer nofollow ugc">https://easyeda.com/suremicro</a> the design is there which you can use to get your own boards made. I used JLCPCB.</p>
]]></description><link>https://community.m5stack.com/post/1248</link><guid isPermaLink="true">https://community.m5stack.com/post/1248</guid><dc:creator><![CDATA[suremicro]]></dc:creator><pubDate>Thu, 23 Aug 2018 15:11:00 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Mon, 25 Jun 2018 12:21:55 GMT]]></title><description><![CDATA[<p dir="auto">Hello, your prototype board is very usefull, more than the genuine one.</p>
<p dir="auto">It's possible to order a set from EasyEDA ?</p>
]]></description><link>https://community.m5stack.com/post/1180</link><guid isPermaLink="true">https://community.m5stack.com/post/1180</guid><dc:creator><![CDATA[sibtcha]]></dc:creator><pubDate>Mon, 25 Jun 2018 12:21:55 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Thu, 08 Mar 2018 12:19:10 GMT]]></title><description><![CDATA[<p dir="auto">Yes the device will be used to record multiple temperatures using DS18B20 sensors on one wire with a single 4.7k resistor. I hooked up 5 and can read them indiviudally since they have there own addresses. I only need the temperature to the nearest degree so they are fine for my purposes.</p>
<p dir="auto">I actually use a 3.5mm jack and bought a few connectors as like you found that many do not fit, however the very small SMD mounted ones just fit in the standard case. The ones I found are on Amazon:</p>
<p dir="auto"><a href="https://www.amazon.co.uk/dp/B008SO0E60/ref=pe_3187911_189395841_TE_3p_dp_1" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.co.uk/dp/B008SO0E60/ref=pe_3187911_189395841_TE_3p_dp_1</a></p>
]]></description><link>https://community.m5stack.com/post/536</link><guid isPermaLink="true">https://community.m5stack.com/post/536</guid><dc:creator><![CDATA[suremicro]]></dc:creator><pubDate>Thu, 08 Mar 2018 12:19:10 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Thu, 08 Mar 2018 11:38:38 GMT]]></title><description><![CDATA[<p dir="auto">This is excellent.  Looks like you are doing a temperature reading (thermistor/thermocouple) setup, which is what I have been working on.  Are you using a voltage divider to calculate temperature?  If so, please provide your schematic.</p>
<p dir="auto">Also, can you provide part numbers for the input jacks (2.5mm I assume)?  I have some panel mount jacks that were for another case enclosure, but they are too big for the m5stack.  Yours look great.</p>
<p dir="auto">How accurate is the temperature? I've been reading the ESP32 ADC can be not quite linear and therefore not so accurate.  So I was looking into another ADC breakout module like the ADS1115 for more resolution bits and accuracy.</p>
]]></description><link>https://community.m5stack.com/post/535</link><guid isPermaLink="true">https://community.m5stack.com/post/535</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Thu, 08 Mar 2018 11:38:38 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Thu, 23 Aug 2018 15:12:42 GMT]]></title><description><![CDATA[<p dir="auto">The PCB and 3D case design files can now be found on GitHub at <a href="https://github.com/zazardev/M5Stack-Proto" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/zazardev/M5Stack-Proto</a></p>
<p dir="auto">For those using EasyEDA see <a href="https://easyeda.com/suremicro" target="_blank" rel="noopener noreferrer nofollow ugc">https://easyeda.com/suremicro</a></p>
]]></description><link>https://community.m5stack.com/post/518</link><guid isPermaLink="true">https://community.m5stack.com/post/518</guid><dc:creator><![CDATA[suremicro]]></dc:creator><pubDate>Thu, 23 Aug 2018 15:12:42 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Mon, 05 Mar 2018 01:16:35 GMT]]></title><description><![CDATA[<p dir="auto">@zazar  Nice design !!! Thanks for the details and the photos.... and for making the files available soon.</p>
]]></description><link>https://community.m5stack.com/post/505</link><guid isPermaLink="true">https://community.m5stack.com/post/505</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Mon, 05 Mar 2018 01:16:35 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Sun, 04 Mar 2018 17:26:20 GMT]]></title><description><![CDATA[<p dir="auto">I used Easy EDA which imported the pcbdoc file after some messing around with the format. I will make the gerber and pcb files files available as well as the 3D prototype enclosure file (with solid edges) soon.</p>
<p dir="auto">I have now tried out the new board with a couple of simple jack connectors and all seems to work!</p>
<p dir="auto"><img src="/assets/uploads/files/1520184374221-proto1-resized.jpg" alt="0_1520184373834_proto1.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/501</link><guid isPermaLink="true">https://community.m5stack.com/post/501</guid><dc:creator><![CDATA[suremicro]]></dc:creator><pubDate>Sun, 04 Mar 2018 17:26:20 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Sat, 24 Feb 2018 22:21:12 GMT]]></title><description><![CDATA[<p dir="auto">Out of curiosity what package did you use to do your breakout boards?  I am looking at drawing up a breakout sch/pcb in KiCad for sharing as we speak.</p>
]]></description><link>https://community.m5stack.com/post/457</link><guid isPermaLink="true">https://community.m5stack.com/post/457</guid><dc:creator><![CDATA[ohararp]]></dc:creator><pubDate>Sat, 24 Feb 2018 22:21:12 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Tue, 20 Feb 2018 03:58:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a> the pins and the sockets are the customization. if u want more, u can order from me(email me), i will give u nice price.  i had not swapped anything, it is the same.</p>
]]></description><link>https://community.m5stack.com/post/422</link><guid isPermaLink="true">https://community.m5stack.com/post/422</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 20 Feb 2018 03:58:30 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Sun, 18 Feb 2018 14:33:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> 在 <a href="/post/362">Custom Prototype Board</a> 中说：</p>
<p dir="auto">.</p>
<p dir="auto"><img src="/assets/uploads/files/1518963986404-img_1547-resized.jpg" alt="0_1518963981835_IMG_1547.JPG" class=" img-fluid img-markdown" /><br />
I've just received the headers, which seem to be custom parts so they're not readily available which is a shame (and expensive since they only ship them with a module or core). Once they have been soldered I'll test them and report back - thanks for the note on DAC/ADC it's a print error the pins are the same as the main board.</p>
<p dir="auto">I have also had a few blank enclosures made, with the holes removed, in both PLS and ABS for testing.</p>
<p dir="auto">I really like the M5Stack but it's let down by not releasing more design files (for all the enclosure parts) and having better access to custom parts such as the headers so other developers can make their own modules.</p>
]]></description><link>https://community.m5stack.com/post/402</link><guid isPermaLink="true">https://community.m5stack.com/post/402</guid><dc:creator><![CDATA[suremicro]]></dc:creator><pubDate>Sun, 18 Feb 2018 14:33:04 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Sun, 18 Feb 2018 01:51:24 GMT]]></title><description><![CDATA[<p dir="auto">Is the custom proto board working out good for you?  I just received my stock Proto board and found the same limitation you did. I can’t connect any pins and use the bottom module. Do you have any extras for sale or where could I purchase it?</p>
<p dir="auto">Also I noticed your ADC and DAC screen printed labels are swapped compared to the core. Is that a mistake or did you swap the pins in the design?</p>
]]></description><link>https://community.m5stack.com/post/394</link><guid isPermaLink="true">https://community.m5stack.com/post/394</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 18 Feb 2018 01:51:24 GMT</pubDate></item><item><title><![CDATA[Reply to Custom Prototype Board on Tue, 13 Feb 2018 08:10:33 GMT]]></title><description><![CDATA[<p dir="auto">nice, maybe more text Instructions on the board will be better.</p>
]]></description><link>https://community.m5stack.com/post/362</link><guid isPermaLink="true">https://community.m5stack.com/post/362</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 13 Feb 2018 08:10:33 GMT</pubDate></item></channel></rss>
