<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StackSAM - Application Menu Library]]></title><description><![CDATA[<p dir="auto">For a great interest in SAM I wrote a simply to use library for a simple application menu on the M5Stack platform.</p>
<p dir="auto"><a href="https://github.com/tomsuch/M5StackSAM" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/tomsuch/M5StackSAM</a></p>
]]></description><link>https://community.m5stack.com/topic/85/m5stacksam-application-menu-library</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 08:28:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/85.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Feb 2018 16:12:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Thu, 15 Feb 2018 04:09:34 GMT]]></title><description><![CDATA[<p dir="auto">A new version of the M5StackSAM library<br />
<p dir="auto">Added features to easily create and navigate the list.<br />
(APPLICATIONS -&gt; LIST DEMO)</p>
<p dir="auto">Added support for the FACES QWERTY keyboard.<br />
(APPLICATIONS -&gt; FACES GET STRING)</p>
]]></description><link>https://community.m5stack.com/post/379</link><guid isPermaLink="true">https://community.m5stack.com/post/379</guid><dc:creator><![CDATA[TomSuch]]></dc:creator><pubDate>Thu, 15 Feb 2018 04:09:34 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Tue, 13 Feb 2018 16:47:46 GMT]]></title><description><![CDATA[<p dir="auto">A bit off-topic:<br />
Can someone using a battery gauge indicate how long does the 150mah battery takes to charge on an M5Stack limited edition ? (assuming ESP is sleeping)</p>
<p dir="auto">(FYI, with the screen backlight turned off, and not connected to any network, the battery lasted for 40 minutes with the ESP <strong>not</strong> sleeping)</p>
]]></description><link>https://community.m5stack.com/post/366</link><guid isPermaLink="true">https://community.m5stack.com/post/366</guid><dc:creator><![CDATA[DoNcK]]></dc:creator><pubDate>Tue, 13 Feb 2018 16:47:46 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Mon, 12 Feb 2018 20:07:42 GMT]]></title><description><![CDATA[<p dir="auto">@jimit Thanks - after rereading I noticed that a separate module is needed :-) Just ordered some of those...</p>
]]></description><link>https://community.m5stack.com/post/359</link><guid isPermaLink="true">https://community.m5stack.com/post/359</guid><dc:creator><![CDATA[jwdberlin]]></dc:creator><pubDate>Mon, 12 Feb 2018 20:07:42 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Sun, 11 Feb 2018 11:10:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/160">@reaper7</a><br />
Excellent thanks very much !</p>
]]></description><link>https://community.m5stack.com/post/351</link><guid isPermaLink="true">https://community.m5stack.com/post/351</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sun, 11 Feb 2018 11:10:07 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Sun, 11 Feb 2018 19:53:53 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1518346187801-mod.jpg" alt="0_1518346185558_mod.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">cutting pcb is not necessary,</p>
<p dir="auto">cutting wire between ACCU+ and VCC also not necessary<br />
but I do not want drain accu by max17043 when m5stack is off</p>
<p dir="auto"><strong>REMEMBER! If wire between ACCU+ and VCC are not cut (on the max17043 pcb) as it is originally,<br />
then connect only ACCU+ pin to M-BUS BATTERY and DO NOT connect VCC to M-BUS 3.3V</strong></p>
]]></description><link>https://community.m5stack.com/post/350</link><guid isPermaLink="true">https://community.m5stack.com/post/350</guid><dc:creator><![CDATA[reaper7]]></dc:creator><pubDate>Sun, 11 Feb 2018 19:53:53 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Sat, 10 Feb 2018 22:48:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/160">@reaper7</a></p>
<p dir="auto">Hi Reaper7, I'm planning to do this mod.</p>
<p dir="auto">Could you please share some details on how you've wired the MAX17043 ? I am sure others would also be interested.</p>
<p dir="auto">So you've  removed the battery connector from the MAX. Looks like you are using 7 of the 8 pins on the the MAX... NOT using the Quick start QSTRT pin from what I can see. Then i presume SDA to G21 on M5Stack; SCL to G22 on M5Stack....</p>
<p dir="auto">Is that right? And the rest ?  Thanks !</p>
<p dir="auto"><img src="/assets/uploads/files/1518302461439-max17043-mod.jpg" alt="0_1518302458704_MAX17043 Mod.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/348</link><guid isPermaLink="true">https://community.m5stack.com/post/348</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sat, 10 Feb 2018 22:48:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Sat, 10 Feb 2018 10:14:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/172">@jwdberlin</a>  - i2c scanner app show max17043 at address 0x36?, your master ino has Wire.begin(); ?<br />
Try first with regular library:<br />
<a href="https://github.com/nlamprian/LiFuelGauge/" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/nlamprian/LiFuelGauge/</a></p>
<p dir="auto">@JimiT - good question :)</p>
]]></description><link>https://community.m5stack.com/post/344</link><guid isPermaLink="true">https://community.m5stack.com/post/344</guid><dc:creator><![CDATA[reaper7]]></dc:creator><pubDate>Sat, 10 Feb 2018 10:14:52 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Sat, 10 Feb 2018 10:12:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/172">@jwdberlin</a><br />
Hi, just checking...  have you added a MAX17043 "battery gauge module" to your M5Stack in some way - perhaps soldered to the add-on Battery module as per reaper7's example  ?</p>
]]></description><link>https://community.m5stack.com/post/343</link><guid isPermaLink="true">https://community.m5stack.com/post/343</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sat, 10 Feb 2018 10:12:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Fri, 09 Feb 2018 20:39:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/160">@reaper7</a> shows strange values: VCell: -0.0213V SoC: -1.00%<br />
what's going wrong?</p>
]]></description><link>https://community.m5stack.com/post/340</link><guid isPermaLink="true">https://community.m5stack.com/post/340</guid><dc:creator><![CDATA[jwdberlin]]></dc:creator><pubDate>Fri, 09 Feb 2018 20:39:54 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Tue, 06 Feb 2018 09:58:02 GMT]]></title><description><![CDATA[<p dir="auto">不知楼主是否看得懂中文~哈哈<br />
这个例子非常好，已经借用，谢谢作者TomSuch~<br />
另外，建议做菜单列表，比现在的菜单页面直观一些。<br />
APPLICATION<br />
1.APP1<br />
2.APP2<br />
3.RETRUN<br />
SYSTEM<br />
1.SYSTEM INFO<br />
2.SLEEP/..<br />
3.RETRUN</p>
]]></description><link>https://community.m5stack.com/post/327</link><guid isPermaLink="true">https://community.m5stack.com/post/327</guid><dc:creator><![CDATA[面包]]></dc:creator><pubDate>Tue, 06 Feb 2018 09:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Sat, 10 Feb 2018 10:39:32 GMT]]></title><description><![CDATA[<p dir="auto">simple app <strong><a href="http://forum.m5stack.com/topic/78/m5stack-simple-applications-menu-some-apps/33#" target="_blank" rel="noopener noreferrer nofollow ugc">Accu meter</a></strong> (MAX17043 module soldered inside Battery Module):</p>
<p dir="auto"><img src="/assets/uploads/files/1518259076139-accu_meter2.jpg" alt="1_1518259074527_accu_meter2.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1518259075994-accu_meter1.jpg" alt="0_1518259074527_accu_meter1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">code based on nlamprian library from <a href="https://github.com/nlamprian/LiFuelGauge:" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/nlamprian/LiFuelGauge:</a><br />
available on my gist:<br />
<a href="https://gist.github.com/reaper7/c9f8dba68edae8c3d53075b10f6bbba4" target="_blank" rel="noopener noreferrer nofollow ugc">https://gist.github.com/reaper7/c9f8dba68edae8c3d53075b10f6bbba4</a></p>
]]></description><link>https://community.m5stack.com/post/324</link><guid isPermaLink="true">https://community.m5stack.com/post/324</guid><dc:creator><![CDATA[reaper7]]></dc:creator><pubDate>Sat, 10 Feb 2018 10:39:32 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Sun, 04 Feb 2018 22:29:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/149">@tomsuch</a><br />
Nice one Tom. Thanks.  Should be handy for many users....</p>
]]></description><link>https://community.m5stack.com/post/314</link><guid isPermaLink="true">https://community.m5stack.com/post/314</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Sun, 04 Feb 2018 22:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to M5StackSAM - Application Menu Library on Sun, 04 Feb 2018 21:53:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/149">@TomSuch</a> Thanks! I think this will be really helpful.<br />
Don't need to waste time setting a my quick dirty menu anymore :)</p>
]]></description><link>https://community.m5stack.com/post/312</link><guid isPermaLink="true">https://community.m5stack.com/post/312</guid><dc:creator><![CDATA[kaotiklabs]]></dc:creator><pubDate>Sun, 04 Feb 2018 21:53:09 GMT</pubDate></item></channel></rss>
