<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A fatal error occurred: MD5 of file does not match data in flash!]]></title><description><![CDATA[<p dir="auto">I purchased an M5Stack Fire and it worked great for about twenty minutes.  (using Win10 and Arduino)</p>
<p dir="auto">Since then I get the error; A fatal error occurred: MD5 of file does not match data in flash!</p>
<p dir="auto">I've spent an insane amount of time trying to find a fix.  Do I just have broken hardware?</p>
<p dir="auto">Please help.</p>
]]></description><link>https://community.m5stack.com/topic/838/a-fatal-error-occurred-md5-of-file-does-not-match-data-in-flash</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 06:17:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/838.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Apr 2019 02:42:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A fatal error occurred: MD5 of file does not match data in flash! on Fri, 27 Jun 2025 16:30:00 GMT]]></title><description><![CDATA[<p dir="auto">This error usually means the uploaded firmware didn't flash correctly. Try these steps:</p>
<pre><code>Use a different USB cable and port.
Press the reset button on your M5Stack before uploading.
Make sure you have the latest Arduino M5Stack libraries and board definitions.
Try erasing the flash completely using esptool (esptool.py erase_flash).
Reboot your PC and M5Stack.
<p dir="auto">If it persists, it could be a hardware fault, but most often it’s a flashing or connection issue.</p>
]]></description><link>https://community.m5stack.com/post/29347</link><guid isPermaLink="true">https://community.m5stack.com/post/29347</guid><dc:creator><![CDATA[hacxx]]></dc:creator><pubDate>Fri, 27 Jun 2025 16:30:00 GMT</pubDate></item><item><title><![CDATA[Reply to A fatal error occurred: MD5 of file does not match data in flash! on Wed, 20 Nov 2019 05:35:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/2406">@mr-clay</a> said in <a href="/post/6448">A fatal error occurred: MD5 of file does not match data in flash!</a>:</p>
<p dir="auto">sorry for resurrecting this post from the dead but where exactly do you run the esptool --port &lt;YOUR PORT&gt; write_flash_status --non-volatile 0 command?</p>
<p dir="auto">You run this in a terminal or command line program.<br />
Replace YOUR PORT with the name of the port that appears in arduino. On windows this may be COM followed by a number on OSX this is often somelike USBslab.</p>
]]></description><link>https://community.m5stack.com/post/6452</link><guid isPermaLink="true">https://community.m5stack.com/post/6452</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 20 Nov 2019 05:35:54 GMT</pubDate></item><item><title><![CDATA[Reply to A fatal error occurred: MD5 of file does not match data in flash! on Wed, 20 Nov 2019 03:04:04 GMT]]></title><description><![CDATA[<p dir="auto">sorry for resurrecting this post from the dead but where exactly do you run the esptool --port &lt;YOUR PORT&gt; write_flash_status --non-volatile 0 command?</p>
]]></description><link>https://community.m5stack.com/post/6448</link><guid isPermaLink="true">https://community.m5stack.com/post/6448</guid><dc:creator><![CDATA[mr.clay]]></dc:creator><pubDate>Wed, 20 Nov 2019 03:04:04 GMT</pubDate></item><item><title><![CDATA[Reply to A fatal error occurred: MD5 of file does not match data in flash! on Thu, 04 Jul 2019 09:11:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/724">@salty_good</a> said in <a href="/post/3624">A fatal error occurred: MD5 of file does not match data in flash!</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1294">@pchidley</a>  Hi, Please try this command on your terminal.</p>
<p dir="auto"><code>esptool --port &lt;YOUR PORT&gt; write_flash_status --non-volatile 0</code></p>
<p dir="auto">or</p>
<p dir="auto"><code>esptool.py --port &lt;YOUR PORT&gt; write_flash_status --non-volatile 0</code></p>
<p dir="auto"><em>take care this command!!!</em></p>
<p dir="auto">Thanks this is the way to go with my M5Stack, got it new and I was never able to make it work, this command fixed it!</p>
<p dir="auto">Great! Thanks</p>
]]></description><link>https://community.m5stack.com/post/4758</link><guid isPermaLink="true">https://community.m5stack.com/post/4758</guid><dc:creator><![CDATA[dfacchin]]></dc:creator><pubDate>Thu, 04 Jul 2019 09:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to A fatal error occurred: MD5 of file does not match data in flash! on Tue, 09 Apr 2019 06:39:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1294">@pchidley</a>  Hi, Please try this command on your terminal.</p>
]]></description><link>https://community.m5stack.com/post/3624</link><guid isPermaLink="true">https://community.m5stack.com/post/3624</guid><dc:creator><![CDATA[salty_good]]></dc:creator><pubDate>Tue, 09 Apr 2019 06:39:15 GMT</pubDate></item><item><title><![CDATA[Reply to A fatal error occurred: MD5 of file does not match data in flash! on Wed, 03 Apr 2019 06:07:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1294">@pchidley</a> then...Please try these way.</p>
<li>Turn upside down cable connection.</li>
<li>Change cable If you have an another cable.</li>
<li>Remove battery bottom.</li>
]]></description><link>https://community.m5stack.com/post/3514</link><guid isPermaLink="true">https://community.m5stack.com/post/3514</guid><dc:creator><![CDATA[salty_good]]></dc:creator><pubDate>Wed, 03 Apr 2019 06:07:36 GMT</pubDate></item><item><title><![CDATA[Reply to A fatal error occurred: MD5 of file does not match data in flash! on Wed, 03 Apr 2019 05:59:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1294">@pchidley</a> Hi, Which writer do you use? M5Burner ?<br />
Please try the erase button once and setting Baurate 115200 bps!!</p>
]]></description><link>https://community.m5stack.com/post/3513</link><guid isPermaLink="true">https://community.m5stack.com/post/3513</guid><dc:creator><![CDATA[salty_good]]></dc:creator><pubDate>Wed, 03 Apr 2019 05:59:25 GMT</pubDate></item></channel></rss>
