<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[RELEASE] WiFi CSI Radar ADV (V1.42) - Detect Motion Through Walls with Cardputer!]]></title><description><![CDATA[<p dir="auto">Hello M5Stack Community! 👋</p>
<p dir="auto">What if your Cardputer could see through walls?</p>
<p dir="auto">I’ve been working on pushing the ESP32-S3 to its absolute physical limits and I'm excited to share WiFi CSI Radar ADV (V1.42). This firmware turns your device into a high-performance Channel State Information (CSI) radar that analyzes invisible radio wave reflections to detect motion and spatial presence.</p>
<p dir="auto">🔥 WHAT IT ACTUALLY DOES:</p>
<p dir="auto">🛡️ 1D Invisible Tripwire: Ultra-precise motion detection. It senses subtle movements (like walking or even breathing) through solid doors and walls. Perfect for perimeter monitoring.</p>
<p dir="auto">📍 2D Spatial Tracking (Active Beta): Tracks your physical position inside a room in real-time via a built-in Web UI by profiling Wi-Fi reflections in the corners of the room.</p>
<p dir="auto">🗺️ Hybrid SLAM Room Mapping: Draw a digital floor plan of your environment simply by holding the device flat against your chest and walking around.</p>
<p dir="auto">⚙️ UNDER THE HOOD (For the Geeks):<br />
To make this work without lag, I had to bypass standard limitations:</p>
<p dir="auto">200+ PPS Capture Rate: Achieved the physical limit of the 2.4GHz stack.</p>
<p dir="auto">Dual-Core FreeRTOS Architecture: Core 0 handles aggressive radio/injection (NAT Bypass), while Core 1 crunches the heavy math and UI rendering.</p>
<p dir="auto">Smart Power Management: Advanced ADC noise filtering to prevent false charging detections under heavy Wi-Fi load.</p>
<p dir="auto">📥 HOW TO INSTALL:<br />
The firmware is available directly in M5Burner.</p>
<p dir="auto">Open M5Burner.</p>
<p dir="auto">Go to the Cardputer -&gt; User Custom (or Community) section.</p>
<p dir="auto">Search for WiFi CSI Radar ADV or Zeloksa.</p>
<p dir="auto">Burn and enjoy!</p>
<p dir="auto">📖 MANUAL &amp; FEEDBACK:<br />
Wi-Fi sensing requires exact calibration (e.g., leaving the room to set a baseline). Please read the full User Manual before your first launch!<br />
If you find bugs or have ideas for improving the 2D spatial math, drop an issue here:<br />
👉 <a href="https://github.com/Zeloksa/Cardputer-ADV-CSI-Radar" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Zeloksa/Cardputer-ADV-CSI-Radar</a></p>
<p dir="auto">☕ SUPPORT THE PROJECT:<br />
If this tool helps with your research, pentesting, or hobbyist projects, consider supporting further development. It keeps the updates coming!<br />
👉 <a href="https://boosty.to/zeloksa" target="_blank" rel="noopener noreferrer nofollow ugc">https://boosty.to/zeloksa</a></p>
<p dir="auto">Looking forward to seeing your test results and PPS records! Let me know how it performs on your local routers. 📡<br />
Tags: Cardputer, CSI, Radar, ESP32-S3, Sensing, FreeRTOS</p>
]]></description><link>https://community.m5stack.com/topic/8143/release-wifi-csi-radar-adv-v1-42-detect-motion-through-walls-with-cardputer</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 16:51:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8143.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Mar 2026 05:03:44 GMT</pubDate><ttl>60</ttl></channel></rss>
