<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow2 and just general problems that should be here.]]></title><description><![CDATA[<p dir="auto">Hello Everyone,</p>
<p dir="auto">First I really enjoy the M5Stack products so much that I plan to use them in the 2025/26 school year as part two new electronics classes...I think?</p>
<p dir="auto">Simply put is that my problems are the result of not knowing the M5Stack products well enough yet. Yet part of my issues are the result of:</p>
<li>M5Stack AI Engine (and other AI Engines) simply making stuff up</li>
<li>Lack of documents with an explanation of blocks (which isn't a problem with Arduinos)</li>
<li>Simply put some stuff should "just work"</li>
<p dir="auto">So my question is...because my students will ask...trust me....why can't we simply:</p>
<li>adjust the SCL and SDA so they align with UIFLOW2?</li>
<li>why not add the address of the device with the SCL and SDA in UIFLOW2?</li>
<p dir="auto">I am guessing these requests will cause a lot of code to be rewrote? Yet to make UIFLOW2 more flexible and to reduce frustration these requests would go a long way when you consider I wasted over 2 hours on a Friday night of trying to figure out why I couldn't connect a ENV III Sensor to work through a PaHub (now I know...address conflict) which was even more complicated when I was using PortC!</p>
<p dir="auto">Thanks to a few of you (Felix) for this magic line of code and I just discovered how to add my own code today with Green item "Add mpy code"  under SYSTEM (so the weekend wasn't a total loss) :</p>
<p dir="auto">extio2_0 = EXTIO2Unit(PAHUBUnit(i2c=i2c0, channel=0, address=0x77)) # For EXTI/0 2</p>
<p dir="auto">Sorry for my rant but I want to see M5Stack gain more of a market share!</p>
<p dir="auto">Thanks-Brian</p>
<p dir="auto">PS: I will visit the ENVIII later...it was more just a proof of concept vs. needing something to work.</p>
]]></description><link>https://community.m5stack.com/topic/8139/uiflow2-and-just-general-problems-that-should-be-here</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 17:24:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8139.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 15 Mar 2026 18:08:26 GMT</pubDate><ttl>60</ttl></channel></rss>
