<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Dial Example App - Home Assistant, RSS News and OpenWeatherMap]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I've been working on a little project to show local weather, Home Assistant measurements and RSS news headlines. These are all accessible by turning the dial:-</p>
<p dir="auto"><strong>Forecast</strong>: Shows current conditions, and if you wait 5 secs, then shows the next 7 days, one at a time with a 3 second pause between.</p>
<p dir="auto"><strong>Home Assistant</strong>: You can define any measurements in the config file (for mine, I'm getting a couple of temperature sensors)</p>
<p dir="auto"><strong>News RSS</strong>: It will show the top 10 headlines from an RSS feed.</p>
<p dir="auto">Here is the Arduino .ino code:</p>
<pre><code>/*
  M5Dial Home Assistant + Weather + News Dashboard
  Written by Paul McGuinness
  License: GNU General Public License (GPL)
  ===== Arduino IDE / Board settings =====
  - Install M5Stack Board Manager
  - Select Tools -&gt; Board -&gt; "M5Dial"
  - Board package: M5Stack &gt;= 3.2.2
  - Library: M5Dial &gt;= 1.0.3
  - Libraries:
    - M5Dial
    - ArduinoJson (v6)
  - Serial Monitor: 115200
#include &lt;Arduino.h&gt;
#include &lt;WiFi.h&gt;
#include &lt;HTTPClient.h&gt;
#include &lt;WiFiClient.h&gt;
#include &lt;WiFiClientSecure.h&gt;
#include &lt;ArduinoJson.h&gt;
#include &lt;math.h&gt;
#include "M5Dial.h"
#include "config.h"
// Limits
static const uint8_t MAX_FORECAST_DAYS = 7;
static const uint8_t MAX_NEWS_HEADLINES = 10;
// State
static size_t  gIndex = 0;
static int32_t gLastEnc = INT32_MIN;
static int32_t gEncAccum = 0;
static const int32_t ENC_STEP = 2;    // 1 page change per 2 encoder counts
static uint32_t gLastPageTurnMs = 0;
static const uint32_t ENC_PAGE_DEBOUNCE_MS = 120;
static uint32_t gLastInteractionMs = 0;
static bool     gDisplayOn = true;
static uint32_t gLastFetchMs = 0;
static uint32_t gMetricEnteredMs = 0;
// Main display values
static String gValueLine1;
static String gValueLine2;
static String gWeatherSummary;
static String gWeatherIconKey;
// Weather cache
static String gWeatherTempLine;
static float  gWeatherNowC = NAN;
static uint32_t gLastWeatherForecastFetchMs = 0;
static bool gHasWeatherForecastCache = false;
struct DailyForecast {
  bool valid;
  String label;      // e.g. "Sat 7th"
  String summary;    // e.g. "Rain expected"
  int minTemp;
  int maxTemp;
static DailyForecast gDailyForecast[MAX_FORECAST_DAYS];
static uint8_t gDailyForecastCount = 0;
// Weather auto rotation page:
// 0 = main weather page
// 1..gDailyForecastCount = forecast pages
static uint8_t gWeatherAutoPage = 0;
static uint32_t gLastWeatherAutoRotateMs = 0;
// News cache
static String gNewsCaption;
static String gNewsHeadlines[MAX_NEWS_HEADLINES];
static uint8_t gNewsHeadlineCount = 0;
static uint32_t gLastNewsFetchMs = 0;
static bool gHasNewsCache = false;
static uint8_t gNewsAutoIndex = 0;
static uint32_t gLastNewsAutoRotateMs = 0;
// Helpers
static String formatNumber(double value, uint8_t decimals) {
  char buf[32];
  snprintf(buf, sizeof(buf), "%.*f", (int)decimals, value);
  return String(buf);
static String stripDegree(const String&amp; s) {
  String out = s;
  out.replace("°", "");
  return out;
static const char* ordinalSuffix(int day) {
  if (day &gt;= 11 &amp;&amp; day &lt;= 13) return "th";
  switch (day % 10) {
    case 1: return "st";
    case 2: return "nd";
    case 3: return "rd";
    default: return "th";
static String formatDayDateLabel(int wday, int mday) {
  static const char* names[] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
  String s = (wday &gt;= 0 &amp;&amp; wday &lt; 7) ? String(names[wday]) : String("Day");
  s += " ";
  s += String(mday);
  s += ordinalSuffix(mday);
  return s;
static void fadeBrightness(uint8_t fromB, uint8_t toB, uint32_t durationMs) {
  if (durationMs == 0) {
    M5Dial.Display.setBrightness(toB);
    return;
  const int steps = 12;
  for (int i = 0; i &lt;= steps; i++) {
    float t = (float)i / (float)steps;
    uint8_t b = (uint8_t)round(fromB + (toB - fromB) * t);
    M5Dial.Display.setBrightness(b);
    delay(durationMs / steps);
static void resetAutoPages() {
  gMetricEnteredMs = millis();
  gNewsAutoIndex = 0;
  gLastWeatherAutoRotateMs = millis();
  gLastNewsAutoRotateMs = millis();
static void markInteraction() {
  gLastInteractionMs = millis();
  resetAutoPages();
  if (!gDisplayOn) {
    gDisplayOn = true;
    M5Dial.Display.setBrightness(DISPLAY_BRIGHTNESS);
    M5Dial.Display.wakeup();
static void maybeSleepDisplay() {
  if (gDisplayOn &amp;&amp; (millis() - gLastInteractionMs &gt; DISPLAY_SLEEP_MS)) {
    gDisplayOn = false;
    M5Dial.Display.setBrightness(0);
    M5Dial.Display.sleep();
static void wifiEnsureConnected() {
  if (WiFi.status() == WL_CONNECTED) return;
  WiFi.mode(WIFI_STA);
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  uint32_t start = millis();
  while (WiFi.status() != WL_CONNECTED &amp;&amp; (millis() - start) &lt; 8000) {
    delay(50);
    M5Dial.update();
    if (M5Dial.Touch.getCount() &gt; 0) markInteraction();
    int32_t enc = M5Dial.Encoder.read();
    if (enc != gLastEnc) {
      gLastEnc = enc;
      markInteraction();
static String httpGET(const String&amp; url, bool https) {
  String payload;
  if (https) {
    WiFiClientSecure client;
    client.setInsecure();
    HTTPClient http;
    if (!http.begin(client, url)) return "";
    int code = http.GET();
    if (code &gt; 0) payload = http.getString();
    http.end();
  } else {
    WiFiClient client;
    HTTPClient http;
    http.end();
  return payload;
static String xmlDecode(String s) {
  s.replace("&amp;amp;", "&amp;");
  s.replace("&amp;lt;", "&lt;");
  s.replace("&amp;gt;", "&gt;");
  s.replace("&amp;quot;", "\"");
  s.replace("&amp;#39;", "'");
  return s;
static String extractTagValue(const String&amp; xml, const String&amp; tag, int startPos = 0, int* outEndPos = nullptr) {
  String open1 = "&lt;" + tag + "&gt;&lt;![CDATA[";
  String close1 = "]]&gt;&lt;/" + tag + "&gt;";
  String open2 = "&lt;" + tag + "&gt;";
  String close2 = "&lt;/" + tag + "&gt;";
  int s = xml.indexOf(open1, startPos);
  if (s &gt;= 0) {
    s += open1.length();
    int e = xml.indexOf(close1, s);
    if (e &gt;= 0) {
      if (outEndPos) *outEndPos = e + close1.length();
      return xml.substring(s, e);
  s = xml.indexOf(open2, startPos);
  if (s &gt;= 0) {
    s += open2.length();
    int e = xml.indexOf(close2, s);
    if (e &gt;= 0) {
      if (outEndPos) *outEndPos = e + close2.length();
  if (outEndPos) *outEndPos = -1;
  return "";
// Icons
static void drawIcon(IconType icon, int cx, int cy, int r) {
  auto&amp; d = M5Dial.Display;
  switch (icon) {
    case IconType::Thermometer: {
      d.drawCircle(cx, cy + r/2, r/3, TFT_WHITE);
      d.drawLine(cx, cy - r, cx, cy + r/2, TFT_WHITE);
      d.drawRoundRect(cx - r/6, cy - r, r/3, (int)(r*1.5f), r/6, TFT_WHITE);
    } break;
    case IconType::Droplet: {
      d.drawCircle(cx, cy, r/2, TFT_WHITE);
      d.drawTriangle(cx, cy - r, cx - r/2, cy, cx + r/2, cy, TFT_WHITE);
      d.drawCircle(cx, cy + r/3, r/2, TFT_WHITE);
    } break;
    case IconType::Gauge: {
      d.drawCircle(cx, cy, r, TFT_WHITE);
      d.drawLine(cx, cy, cx + r/2, cy - r/3, TFT_WHITE);
      d.fillCircle(cx, cy, 3, TFT_WHITE);
    } break;
    case IconType::Weather: {
      for (int i = 0; i &lt; 8; i++) {
        float a = (float)i * (PI / 4.0f);
        int x1 = cx + (int)(cos(a) * (r * 0.65f));
        int y1 = cy + (int)(sin(a) * (r * 0.65f));
        int x2 = cx + (int)(cos(a) * (r * 0.95f));
        int y2 = cy + (int)(sin(a) * (r * 0.95f));
        d.drawLine(x1, y1, x2, y2, TFT_WHITE);
    } break;
    case IconType::News: {
      d.drawRect(cx - r, cy - r, r * 2, r * 2, TFT_WHITE);
      d.drawLine(cx - r + 4, cy - r + 8, cx + r - 4, cy - r + 8, TFT_WHITE);
      d.drawLine(cx - r + 4, cy, cx + r - 4, cy, TFT_WHITE);
      d.drawLine(cx - r + 4, cy + r - 8, cx + r - 4, cy + r - 8, TFT_WHITE);
    } break;
    default:
      break;
// Home Assistant
static bool haGetEntityState(const char* entityId, String&amp; outState, String&amp; outUnit, bool&amp; outNumeric, double&amp; outNumber) {
  outState = "";
  outUnit = "";
  outNumeric = false;
  outNumber = 0;
  if (!entityId || !*entityId) return false;
  String url = String(HA_BASE_URL) + "/api/states/" + entityId;
  WiFiClient client;
  HTTPClient http;
  if (!http.begin(client, url)) return false;
  http.addHeader("Authorization", String("Bearer ") + HA_BEARER_TOKEN);
  http.addHeader("Content-Type", "application/json");
  if (code &lt;= 0) {
    http.end();
    return false;
  String payload = http.getString();
  http.end();
  StaticJsonDocument&lt;4096&gt; doc;
  if (deserializeJson(doc, payload)) return false;
  outState = String((const char*)(doc["state"] | ""));
  outUnit = String((const char*)(doc["attributes"]["unit_of_measurement"] | ""));
  char* endPtr = nullptr;
  double v = strtod(outState.c_str(), &amp;endPtr);
  if (endPtr &amp;&amp; endPtr != outState.c_str() &amp;&amp; *endPtr == '\0') {
    outNumeric = true;
    outNumber = v;
  return true;
// Weather
static String classifySummary(bool rain, bool snow, int avgClouds) {
  if (snow) return "Snow expected";
  if (rain) return "Rain expected";
  if (avgClouds &gt;= 70) return "Mostly cloudy";
  return "Staying clear";
static bool fetchWeatherForecastCache() {
  String urlFc =
    String("https://api.openweathermap.org/data/2.5/forecast?q=") +
    OWM_CITY + "," + OWM_COUNTRY +
    "&amp;units=" + OWM_UNITS +
    "&amp;lang=" + OWM_LANG +
    "&amp;appid=" + OWM_API_KEY;
  String fcJson = httpGET(urlFc, true);
  if (fcJson.length() &lt; 10) return false;
  StaticJsonDocument&lt;28000&gt; fcDoc;
  if (deserializeJson(fcDoc, fcJson)) return false;
  for (int i = 0; i &lt; MAX_FORECAST_DAYS; i++) {
    gDailyForecast[i].valid = false;
    gDailyForecast[i].label = "";
    gDailyForecast[i].summary = "";
    gDailyForecast[i].minTemp = 0;
    gDailyForecast[i].maxTemp = 0;
  JsonArray list = fcDoc["list"].as&lt;JsonArray&gt;();
  if (list.isNull()) return false;
  long timezone = fcDoc["city"]["timezone"] | 0;
  int dateKeys[MAX_FORECAST_DAYS] = {0};
  bool dayRain[MAX_FORECAST_DAYS] = {false};
  bool daySnow[MAX_FORECAST_DAYS] = {false};
  int dayCloudSum[MAX_FORECAST_DAYS] = {0};
  int dayCloudN[MAX_FORECAST_DAYS] = {0};
  for (JsonObject it : list) {
    time_t fcTs = it["dt"] | 0;
    time_t localFc = fcTs + timezone;
    tm tFc;
    gmtime_r(&amp;localFc, &amp;tFc);
    int key = (tFc.tm_year + 1900) * 10000 + (tFc.tm_mon + 1) * 100 + tFc.tm_mday;
    int idx = -1;
    for (int i = 0; i &lt; gDailyForecastCount; i++) {
      if (dateKeys[i] == key) {
        idx = i;
        break;
    if (idx &lt; 0) {
      if (gDailyForecastCount &gt;= MAX_FORECAST_DAYS) continue;
      idx = gDailyForecastCount++;
      dateKeys[idx] = key;
      gDailyForecast[idx].valid = true;
      gDailyForecast[idx].label = formatDayDateLabel(tFc.tm_wday, tFc.tm_mday);
      float t = it["main"]["temp"] | NAN;
      int ti = isnan(t) ? 0 : (int)round(t);
      gDailyForecast[idx].minTemp = ti;
      gDailyForecast[idx].maxTemp = ti;
    float temp = it["main"]["temp"] | NAN;
    if (!isnan(temp)) {
      int ti = (int)round(temp);
      if (ti &lt; gDailyForecast[idx].minTemp) gDailyForecast[idx].minTemp = ti;
      if (ti &gt; gDailyForecast[idx].maxTemp) gDailyForecast[idx].maxTemp = ti;
    const char* main0 = it["weather"][0]["main"] | "";
    int clouds = it["clouds"]["all"] | 0;
    if (!strcmp(main0, "Rain") || !strcmp(main0, "Drizzle") || !strcmp(main0, "Thunderstorm")) dayRain[idx] = true;
    if (!strcmp(main0, "Snow")) daySnow[idx] = true;
    dayCloudSum[idx] += clouds;
    dayCloudN[idx]++;
    int avgClouds = dayCloudN[i] ? (dayCloudSum[i] / dayCloudN[i]) : 0;
    gDailyForecast[i].summary = classifySummary(dayRain[i], daySnow[i], avgClouds);
  gHasWeatherForecastCache = (gDailyForecastCount &gt; 0);
  gLastWeatherForecastFetchMs = millis();
  return gHasWeatherForecastCache;
static bool ensureWeatherForecastCache() {
  if (!gHasWeatherForecastCache) return fetchWeatherForecastCache();
  if (millis() - gLastWeatherForecastFetchMs &gt;= WEATHER_FORECAST_CACHE_MS) return fetchWeatherForecastCache();
  return true;
static bool fetchCurrentWeather(String&amp; outTempC, String&amp; outWind, String&amp; outHum, String&amp; outIcon, String&amp; outRestOfDaySummary) {
  outTempC = outWind = outHum = outIcon = outRestOfDaySummary = "";
  String urlNow =
    String("https://api.openweathermap.org/data/2.5/weather?q=") +
  String nowJson = httpGET(urlNow, true);
  if (nowJson.length() &lt; 10) return false;
  StaticJsonDocument&lt;8192&gt; nowDoc;
  if (deserializeJson(nowDoc, nowJson)) return false;
  double tempNow = nowDoc["main"]["temp"] | NAN;
  double wind = nowDoc["wind"]["speed"] | NAN;
  int hum = nowDoc["main"]["humidity"] | -1;
  const char* icon = nowDoc["weather"][0]["icon"] | "";
  if (isnan(tempNow) || hum &lt; 0) return false;
  gWeatherNowC = (float)tempNow;
  outTempC = String((int)round(tempNow)) + "C";
  outWind = isnan(wind) ? String("? m/s") : (String(wind, 1) + " m/s");
  outHum = String(hum) + "%";
  outIcon = String(icon);
  if (!ensureWeatherForecastCache()) {
    outRestOfDaySummary = "Forecast unavailable";
    gWeatherTempLine = outTempC + " (Now)";
    return true;
  if (gDailyForecastCount &gt; 0) {
    int todayMax = gDailyForecast[0].maxTemp;
    gWeatherTempLine = String(todayMax) + "C (" + String((int)round(gWeatherNowC)) + "C Now)";
    outRestOfDaySummary = gDailyForecast[0].summary;
  } else {
  return true;
// Newsfeed
static bool fetchNewsFeed() {
  String xml = httpGET(String(RSS_NEWS_URL), true);
  if (xml.length() &lt; 20) return false;
  int channelPos = xml.indexOf("&lt;channel&gt;");
  if (channelPos &lt; 0) channelPos = 0;
  int firstItemPos = xml.indexOf("&lt;item&gt;", channelPos);
  gNewsCaption = extractTagValue(xml.substring(channelPos, firstItemPos &gt; 0 ? firstItemPos : xml.length()), "description");
  gNewsCaption = xmlDecode(gNewsCaption);
  int pos = channelPos;
  while (gNewsHeadlineCount &lt; MAX_NEWS_HEADLINES) {
    int itemStart = xml.indexOf("&lt;item&gt;", pos);
    if (itemStart &lt; 0) break;
    int itemEnd = xml.indexOf("&lt;/item&gt;", itemStart);
    if (itemEnd &lt; 0) break;
    String itemXml = xml.substring(itemStart, itemEnd + 7);
    String title = extractTagValue(itemXml, "title");
    title = xmlDecode(title);
    title.trim();
    if (title.length()) {
      gNewsHeadlines[gNewsHeadlineCount++] = title;
    pos = itemEnd + 7;
  gHasNewsCache = (gNewsHeadlineCount &gt; 0);
  gLastNewsFetchMs = millis();
  return gHasNewsCache;
static bool ensureNewsCache() {
  if (!gHasNewsCache) return fetchNewsFeed();
  if (millis() - gLastNewsFetchMs &gt;= NEWS_CACHE_MS) return fetchNewsFeed();
  return true;
// Drawing helpers
static void drawWrappedTwoLinesCentered(const String&amp; text, int yTop, int maxWidth) {
  d.setTextFont(1);
  d.setTextDatum(top_center);
  String s = text;
  s.trim();
  if (d.textWidth(s) &lt;= maxWidth) {
    d.drawString(s, d.width() / 2, yTop);
    return;
  int bestPos = -1;
  int bestBalance = 999999;
  for (int i = 0; i &lt; (int)s.length(); i++) {
    if (s[i] != ' ') continue;
    String a = s.substring(0, i);
    String b = s.substring(i + 1);
    int wa = d.textWidth(a);
    int wb = d.textWidth(b);
    if (wa &lt;= maxWidth &amp;&amp; wb &lt;= maxWidth) {
      int balance = abs(wa - wb);
      if (balance &lt; bestBalance) {
        bestBalance = balance;
        bestPos = i;
  if (bestPos &lt; 0) {
    String line1 = s;
    while (line1.length() &gt; 3 &amp;&amp; d.textWidth(line1 + "...") &gt; maxWidth) line1.remove(line1.length() - 1);
    line1 += "...";
    d.drawString(line1, d.width() / 2, yTop);
    return;
  String line1 = s.substring(0, bestPos);
  String line2 = s.substring(bestPos + 1);
  d.drawString(line2, d.width() / 2, yTop + 12);
static void drawCircularTextBlock(const String&amp; text, int yStart) {
  d.setTextColor(TFT_WHITE);
  d.setTextFont(2);
  const int limits[] = {10, 14, 20, 22, 20, 14, 10};
  const int lineCount = sizeof(limits) / sizeof(limits[0]);
  String remaining = text;
  remaining.trim();
  int y = yStart;
  for (int line = 0; line &lt; lineCount &amp;&amp; remaining.length(); line++) {
    int limit = limits[line];
    String out = "";
    if ((int)remaining.length() &lt;= limit) {
      out = remaining;
      remaining = "";
    } else {
      int split = -1;
      for (int i = min(limit, (int)remaining.length() - 1); i &gt;= 0; i--) {
        if (remaining[i] == ' ') {
          split = i;
          break;
      if (split &lt; 0) split = limit;
      out = remaining.substring(0, split);
      remaining = remaining.substring(split);
      remaining.trim();
    d.drawString(out, d.width() / 2, y);
    y += 18;
  if (remaining.length()) {
    String tail = remaining;
    while (tail.length() &gt; 3 &amp;&amp; d.textWidth(tail + "...") &gt; 180) tail.remove(tail.length() - 1);
    tail += "...";
    d.drawString(tail, d.width() / 2, y);
static void drawTitle(const String&amp; rawTitle) {
  const int margin = 10;
  const int maxW = d.width() - (margin * 2);
  d.setTextFont(2);
  String title = stripDegree(rawTitle);
  if (d.textWidth(title) &gt; maxW) {
    d.setTextFont(1);
    while (title.length() &gt; 3 &amp;&amp; d.textWidth(title + "...") &gt; maxW) title.remove(title.length() - 1);
    title += "...";
  d.drawString(title, d.width() / 2, 10);
static void renderWeatherMain() {
  d.clear(TFT_BLACK);
  drawTitle("Local Weather");
  drawIcon(IconType::Weather, d.width() / 2, 78, 26);
  d.setTextDatum(middle_center);
  d.setTextFont(4);
  d.drawString(stripDegree(gValueLine1), d.width() / 2, 140);
  d.setTextFont(2);
  d.drawString(stripDegree(gValueLine2), d.width() / 2, 175);
  drawWrappedTwoLinesCentered(stripDegree(gWeatherSummary), d.height() - 44, d.width() - 20);
static void renderWeatherForecastPage(uint8_t forecastIdx) {
  d.clear(TFT_BLACK);
  if (forecastIdx &gt;= gDailyForecastCount || !gDailyForecast[forecastIdx].valid) {
    renderWeatherMain();
    return;
  drawTitle("Forecast");
  drawIcon(IconType::Weather, d.width() / 2, 68, 22);
  d.setTextFont(2);
  d.drawString(gDailyForecast[forecastIdx].label, d.width() / 2, 112);
  d.setTextFont(4);
  String hi = String(gDailyForecast[forecastIdx].maxTemp) + "C";
  d.drawString(hi, d.width() / 2, 146);
  d.setTextFont(2);
  String lo = "Low " + String(gDailyForecast[forecastIdx].minTemp) + "C";
  d.drawString(lo, d.width() / 2, 176);
  drawWrappedTwoLinesCentered(gDailyForecast[forecastIdx].summary, 198, d.width() - 20);
static void renderNewsPage(uint8_t idx) {
  d.clear(TFT_BLACK);
  drawTitle("Newsfeed");
  drawIcon(IconType::News, d.width() / 2, 58, 18);
  d.setTextFont(1);
  String caption = gNewsCaption;
  caption.trim();
  if (!caption.length()) caption = "Top headlines";
  while (caption.length() &gt; 3 &amp;&amp; d.textWidth(caption + "...") &gt; 190) caption.remove(caption.length() - 1);
  if (gNewsCaption.length() &amp;&amp; caption != gNewsCaption) caption += "...";
  d.drawString(caption, d.width() / 2, 82);
  if (idx &lt; gNewsHeadlineCount) {
    drawCircularTextBlock(gNewsHeadlines[idx], 108);
  } else {
    d.setTextFont(2);
    d.drawString("No headlines", d.width() / 2, 150);
static void renderCurrentMetric() {
  d.clear(TFT_BLACK);
  const MetricItem&amp; m = METRICS[gIndex];
  if (m.type == MetricType::Weather) {
    if (gWeatherAutoPage == 0) {
    } else {
      renderWeatherForecastPage(gWeatherAutoPage - 1);
    return;
  if (m.type == MetricType::Newsfeed) {
    renderNewsPage(gNewsAutoIndex % (gNewsHeadlineCount ? gNewsHeadlineCount : 1));
    return;
  drawTitle(String(m.title));
  drawIcon(m.icon, d.width() / 2, 78, 26);
  d.setTextFont(4);
  d.setTextFont(2);
static void setMetricIndex(size_t idx) {
  if (METRIC_COUNT == 0) {
    gIndex = 0;
    return;
  gIndex = idx % METRIC_COUNT;
  gLastFetchMs = 0;
  gEncAccum = 0;
  resetAutoPages();
static void refreshSelectedMetricIfDue(bool force) {
  uint32_t minIntervalMs = (uint32_t)m.refresh_s * 1000UL;
  if (!force &amp;&amp; gLastFetchMs != 0 &amp;&amp; (millis() - gLastFetchMs) &lt; minIntervalMs) return;
  gLastFetchMs = millis();
    String t, w, h, icon, summary;
    if (fetchCurrentWeather(t, w, h, icon, summary)) {
      gValueLine1 = stripDegree(gWeatherTempLine.length() ? gWeatherTempLine : t);
      gValueLine2 = String("Wind ") + stripDegree(w) + "  Hum " + stripDegree(h);
      gWeatherSummary = stripDegree(summary);
      gWeatherIconKey = icon;
    } else {
      gValueLine1 = "Weather";
      gValueLine2 = "Unavailable";
      gWeatherSummary = "Check OWM settings";
      gWeatherIconKey = "";
  } else if (m.type == MetricType::Newsfeed) {
    if (!ensureNewsCache()) {
      gNewsCaption = "News unavailable";
    gValueLine1 = "";
    gValueLine2 = "";
    gWeatherSummary = "";
  } else {
    String state, unit;
    bool isNum = false;
    double num = 0;
    if (haGetEntityState(m.ha_entity_id, state, unit, isNum, num)) {
      if (isNum) {
        gValueLine1 = stripDegree(String(m.prefix) + formatNumber(num, m.decimals) + String(m.suffix));
      } else {
        gValueLine1 = stripDegree(String(m.prefix) + state + String(m.suffix));
      if (m.ha_entity_id &amp;&amp;
         (strcmp(m.ha_entity_id, "sensor.office_temperature") == 0 ||
          strcmp(m.ha_entity_id, "sensor.office_humidity") == 0 ||
          strcmp(m.ha_entity_id, "sensor.thermostat_1_current_temperature") == 0)) {
        gValueLine2 = "";
      } else {
        if (unit.length()) gValueLine2 = stripDegree(unit);
        else gValueLine2 = "";
    } else {
      gValueLine1 = "HA";
  renderCurrentMetric();
static void animateMetricChange(size_t newIndex) {
  if (!gDisplayOn) {
    setMetricIndex(newIndex);
    refreshSelectedMetricIfDue(true);
    return;
  fadeBrightness(DISPLAY_BRIGHTNESS, 0, 75);
  fadeBrightness(0, DISPLAY_BRIGHTNESS, 75);
static void turnMetricBy(int dir) {
  if (METRIC_COUNT == 0 || dir == 0) return;
  size_t newIndex;
  if (dir &gt; 0) {
    newIndex = (gIndex + 1) % METRIC_COUNT;
  } else {
    newIndex = (gIndex == 0) ? (METRIC_COUNT - 1) : (gIndex - 1);
  animateMetricChange(newIndex);
static void handleAutoRotate() {
  if (!gDisplayOn) return;
  if (millis() - gMetricEnteredMs &lt; AUTO_ROTATE_DELAY_MS) return;
    if (gDailyForecastCount == 0) return;
    if (millis() - gLastWeatherAutoRotateMs &gt;= AUTO_ROTATE_INTERVAL_MS) {
      // Cycle: main -&gt; day1 -&gt; day2 -&gt; ... -&gt; lastday -&gt; main -&gt; repeat
      uint8_t totalPages = gDailyForecastCount + 1;
      gWeatherAutoPage = (gWeatherAutoPage + 1) % totalPages;
    if (gNewsHeadlineCount == 0) return;
    if (millis() - gLastNewsAutoRotateMs &gt;= AUTO_ROTATE_INTERVAL_MS) {
      gNewsAutoIndex = (gNewsAutoIndex + 1) % gNewsHeadlineCount;
// Arduino
  auto cfg = M5.config();
  M5Dial.begin(cfg, true, false);
  M5Dial.Display.setTextColor(TFT_WHITE);
  M5Dial.Display.setTextDatum(middle_center);
  Serial.begin(115200);
  delay(200);
  resetAutoPages();
  gLastEnc = M5Dial.Encoder.read();
  gEncAccum = 0;
  wifiEnsureConnected();
  gValueLine1 = "Loading...";
  gValueLine2 = "";
  M5Dial.update();
  if (M5Dial.Touch.getCount() &gt; 0) {
    markInteraction();
  if (gLastEnc == INT32_MIN) gLastEnc = enc;
  int32_t delta = enc - gLastEnc;
  if (delta != 0) {
    markInteraction();
    gLastEnc = enc;
    gEncAccum += delta;
  // Process at most one widget change per debounce window.
  // This prevents wrap-around overshoot and "Weather -&gt; Office Temperature" jumps.
  if (millis() - gLastPageTurnMs &gt;= ENC_PAGE_DEBOUNCE_MS) {
    if (gEncAccum &gt;= ENC_STEP) {
      gEncAccum = 0;
      gLastPageTurnMs = millis();
      turnMetricBy(+1);
    } else if (gEncAccum &lt;= -ENC_STEP) {
      gEncAccum = 0;
      turnMetricBy(-1);
  if (WiFi.status() != WL_CONNECTED) {
    static uint32_t lastRetry = 0;
    if (millis() - lastRetry &gt; WIFI_RETRY_MS) {
      lastRetry = millis();
  if (gDisplayOn) {
    refreshSelectedMetricIfDue(false);
    handleAutoRotate();
  maybeSleepDisplay();
  delay(10);
<p dir="auto">and the Include file with the settings : <strong>config.h</strong></p>
<pre><code>#pragma once
#include &lt;stdint.h&gt;
// M5Dial - Weather and News Display
// WiFi
static const char* WIFI_SSID     = "SSID_GOES_HERE";
static const char* WIFI_PASSWORD = "WIFI_PASSWORD_GOES_HERE";
// Home Assistant
static const char* HA_BASE_URL   = "http://homeassistant.local:8123";  // Point to your instances of Home Assistant.
static const char* HA_BEARER_TOKEN = "HA_KEY_GOES_HERE";
// OpenWeatherMap
static const char* OWM_API_KEY   = "OPENWEATHERMAP_API_KEY_GOES_HERE";
static const char* OWM_CITY      = "Latchingdon";
static const char* OWM_COUNTRY   = "GB";
static const char* OWM_UNITS     = "metric";
static const char* OWM_LANG      = "en";
// Newsfeed
static const char* RSS_NEWS_URL  = "https://feeds.bbci.co.uk/news/rss.xml?edition=uk"; // Change to any RSS News feed
// UI / Power
static const uint32_t DISPLAY_SLEEP_MS   = 60UL * 1000UL;
static const uint8_t  DISPLAY_BRIGHTNESS = 80;
// Refresh behaviour
static const uint32_t WIFI_RETRY_MS      = 10UL * 1000UL;
// Widget timing
static const uint32_t WEATHER_FORECAST_CACHE_MS = 60UL * 60UL * 1000UL; // 60 mins
static const uint32_t AUTO_ROTATE_DELAY_MS      = 5UL * 1000UL;         // wait 5s before auto-rotate
static const uint32_t AUTO_ROTATE_INTERVAL_MS   = 3UL * 1000UL;         // pause 3s on each page
static const uint32_t NEWS_CACHE_MS             = 30UL * 60UL * 1000UL; // 30 mins
// METRIC CONFIG
enum class MetricType : uint8_t {
  Weather = 0,
  HAState = 1,
  Newsfeed = 2,
enum class IconType : uint8_t {
  Weather = 0,
  Thermometer,
  Droplet,
  Gauge,
  Info,
  News,
struct MetricItem {
  MetricType type;
  const char* title;
  // For HAState only
  const char* ha_entity_id;
  // Formatting
  const char* prefix;
  const char* suffix;
  uint8_t decimals;
  // Icon
  IconType icon;
  // Refresh interval (seconds) while this metric is selected
  uint16_t refresh_s;
static const MetricItem METRICS[] = {
    MetricType::Weather,
    "Local Weather",
    nullptr,
    "", "", 0,
    IconType::Weather,
    300,
    MetricType::HAState,
    "Office Temperature",
    "sensor.office_temperature",
    "", "C", 1,
    IconType::Thermometer,
    30,
    "House Temperature",
    "sensor.thermostat_1_current_temperature",
    "", "C", 1,
    30,
    "Office Humidity",
    "sensor.office_humidity",
    "", "% RH", 0,
    IconType::Droplet,
    30,
    MetricType::Newsfeed,
    "Newsfeed",
    nullptr,
    "", "", 0,
    IconType::News,
    1800,
static const size_t METRIC_COUNT = sizeof(METRICS) / sizeof(METRICS[0]);
]]></description><link>https://community.m5stack.com/topic/8113/m5dial-example-app-home-assistant-rss-news-and-openweathermap</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 21:21:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8113.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Mar 2026 16:14:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Dial Example App - Home Assistant, RSS News and OpenWeatherMap on Fri, 06 Mar 2026 16:20:24 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1772814000502-7e5ce5b2-8d9d-48f9-ae34-7fa5884c1e12-image.png" alt="7e5ce5b2-8d9d-48f9-ae34-7fa5884c1e12-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/30726</link><guid isPermaLink="true">https://community.m5stack.com/post/30726</guid><dc:creator><![CDATA[PaulMcGuinness_UK]]></dc:creator><pubDate>Fri, 06 Mar 2026 16:20:24 GMT</pubDate></item></channel></rss>
