<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cardputer AVD  via laptop usb]]></title><description><![CDATA[<p dir="auto">Hi  Ive just got a Cardputer ADV to experiment with but my eye sight aint so good and Im having trouble seeing on the small screen<br />
Is it possible use the laptop via usb to input information ie wifi passwords</p>
]]></description><link>https://community.m5stack.com/topic/8089/cardputer-avd-via-laptop-usb</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 23:54:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/8089.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Feb 2026 19:27:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cardputer AVD  via laptop usb on Tue, 31 Mar 2026 09:47:08 GMT]]></title><description><![CDATA[<p dir="auto">Besides the WiFi web terminal option, you could also check if your firmware supports USB serial so you can interact with it via a terminal on your laptop. That’s usually more reliable and doesn’t depend on specific firmware features.</p>
]]></description><link>https://community.m5stack.com/post/30842</link><guid isPermaLink="true">https://community.m5stack.com/post/30842</guid><dc:creator><![CDATA[glimvex]]></dc:creator><pubDate>Tue, 31 Mar 2026 09:47:08 GMT</pubDate></item><item><title><![CDATA[Reply to Cardputer AVD  via laptop usb on Sat, 21 Feb 2026 09:31:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5596">@robski</a>  Hi. I was having trouble entering passwords etc. I’ve solved it at the moment by using magnifying glasses, I may add a bigger external screen later if possible</p>
]]></description><link>https://community.m5stack.com/post/30666</link><guid isPermaLink="true">https://community.m5stack.com/post/30666</guid><dc:creator><![CDATA[Topp53]]></dc:creator><pubDate>Sat, 21 Feb 2026 09:31:13 GMT</pubDate></item><item><title><![CDATA[Reply to Cardputer AVD  via laptop usb on Fri, 20 Feb 2026 11:32:46 GMT]]></title><description><![CDATA[<p dir="auto">if its about initial config with stock firmware to add your Cardputer device to your wifi then it can be done via M5Burner in config,</p>
]]></description><link>https://community.m5stack.com/post/30662</link><guid isPermaLink="true">https://community.m5stack.com/post/30662</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Fri, 20 Feb 2026 11:32:46 GMT</pubDate></item><item><title><![CDATA[Reply to Cardputer AVD  via laptop usb on Fri, 20 Feb 2026 09:29:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/425061">@Focs94</a><br />
Hi. Thanks for that I will look into that.<br />
I’m using magnifying glasses at the moment but my son says I look to geeky. 🤣</p>
]]></description><link>https://community.m5stack.com/post/30660</link><guid isPermaLink="true">https://community.m5stack.com/post/30660</guid><dc:creator><![CDATA[Topp53]]></dc:creator><pubDate>Fri, 20 Feb 2026 09:29:29 GMT</pubDate></item><item><title><![CDATA[Reply to Cardputer AVD  via laptop usb on Wed, 18 Feb 2026 23:29:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/12818">@Topp53</a><br />
Hi! in some firmware like bus pirate you can.<br />
If you connect the cardputer and your pc or smartphone to the same wifi and select as terminal type "wifi web" , it appears an IP adress.<br />
And if you put this adress into your laptop browser you can control bus pirate from there.<br />
But i don't think you can do that normaly with other firmwares.</p>
]]></description><link>https://community.m5stack.com/post/30659</link><guid isPermaLink="true">https://community.m5stack.com/post/30659</guid><dc:creator><![CDATA[Focs94]]></dc:creator><pubDate>Wed, 18 Feb 2026 23:29:58 GMT</pubDate></item></channel></rss>
