<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[any known good yaml configs for esphome for the tab5 v2]]></title><description><![CDATA[<p dir="auto">I'm looking for a working yaml to set up the tab5v2 for use with home assistant.   So far it's taken me 5 hours to learn that I have a v2 tab5 and not the one that the demo uses.  I have gotten it to boot, and it connects to the wifi, but I just get a blank screen with blacklight on.  no telling if touch works or anything else.</p>
<pre><code>esphome:
  friendly_name: M5Stack Tab5 V2
  min_version: 2025.9.3
esp32:
  board: esp32-p4-evboard
  flash_size: 16MB
  framework:
    type: esp-idf
    advanced:
      enable_idf_experimental_features: true
external_components:
  - source: github://pr#12075
    components: [st7123]
    refresh: 0s
  - source: github://pr#12074
    components: [mipi_dsi]
    refresh: 0s
# 2. WIFI CO-PROCESSOR
esp32_hosted:
  variant: esp32c6
  active_high: true
  clk_pin: GPIO12
  cmd_pin: GPIO13
  d0_pin: GPIO11
  d1_pin: GPIO10
  d2_pin: GPIO9
  d3_pin: GPIO8
  reset_pin: GPIO15
  slot: 1
logger:
  hardware_uart: USB_SERIAL_JTAG
psram:
  mode: hex
  speed: 200MHz
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
i2c:
  - id: bsp_bus
    sda: GPIO31
    scl: GPIO32
    frequency: 200kHz
    scan: true
pi4ioe5v6408:
  - id: pi4ioe1
    address: 0x43
  - id: pi4ioe2
    address: 0x44
switch:
   - platform: gpio
    pin:
      pi4ioe5v6408: pi4ioe2
      number: 0
    restore_mode: ALWAYS_ON
  - platform: gpio
    pin:
      number: 3
  - platform: gpio
    name: "External 5V Power"
    pin:
      pi4ioe5v6408: pi4ioe1
      number: 2
  - platform: gpio
    pin:
      number: 1
# 4. TOUCHSCREEN (V2)
touchscreen:
  - platform: st7123
    i2c_id: bsp_bus
    interrupt_pin: GPIO23
    display: lcd
    reset_pin:
      number: 5
# 5. LDO &amp; DISPLAY
esp_ldo:
  - voltage: 1.1V
    channel: 4 # MIPI DSI Logic
  - voltage: 2.7V
    channel: 3 # Analog Power
display:
  - platform: mipi_dsi
    pixel_mode: 24bit
    dimensions:
      height: 1280
      width: 720
    model: M5STACK-TAB5-V2
    reset_pin:
      number: 4
      inverted: true
output:
  - platform: ledc
    pin: GPIO22
    frequency: 1000Hz
light:
  - platform: monochromatic
    output: backlight_pwm
    name: "Display Backlight"
    restore_mode: RESTORE_DEFAULT_ON
    initial_state:
      brightness: "100%"
font:
  - file: "gfonts://Roboto"
lvgl:
  buffer_size: 10%
  displays:
    - lcd
  touchscreens:
    - touch
  # 1. DEFINE STYLES HERE (Global Level)
  style_definitions:
    - id: red_bg_style
      bg_color: 0xFF0000
      bg_opa: 100%
    - id: blue_btn_style
      bg_color: 0x0000FF
      bg_opa: 100%
      text_color: 0xFFFFFF
  # 2. USE STYLES HERE
  pages:
    - id: main_page
      # Apply the red background to the whole page
      styles:
        - red_bg_style
      widgets:
        - button:
            align: center
            width: 50%
            height: 20%
            text: "PRESS ME"
            text_font: roboto_16
            # Apply the blue style to the button
            styles:
              - blue_btn_style
            on_click:
              - logger.log: "TOUCH IS WORKING!"
]]></description><link>https://community.m5stack.com/topic/7975/any-known-good-yaml-configs-for-esphome-for-the-tab5-v2</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 21:26:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7975.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Dec 2025 07:17:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to any known good yaml configs for esphome for the tab5 v2 on Sat, 03 Jan 2026 14:11:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/konstantint" aria-label="Profile: konstantint">@<bdi>konstantint</bdi></a> Thankyou for doing that! very useful.</p>
<p dir="auto">I see your config puts the reset pin definitions directly in the correct driver sections for the touchscreen and LCD so that those driver handle them correctly. I think this is better than doing it separately the way I suggested :-)</p>
]]></description><link>https://community.m5stack.com/post/30401</link><guid isPermaLink="true">https://community.m5stack.com/post/30401</guid><dc:creator><![CDATA[easytarget]]></dc:creator><pubDate>Sat, 03 Jan 2026 14:11:28 GMT</pubDate></item><item><title><![CDATA[Reply to any known good yaml configs for esphome for the tab5 v2 on Fri, 02 Jan 2026 19:48:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manmade" aria-label="Profile: manmade">@<bdi>manmade</bdi></a> For sake of those who stumble upon this thread in search of a copy-pasteable solution, here's a config that works for me: <a href="https://github.com/konstantint/HomeDicator-ESPHome-Package/blob/main/HomeDicator/hardware/m5stack_tab5_v2_landscape.yaml" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/konstantint/HomeDicator-ESPHome-Package/blob/main/HomeDicator/hardware/m5stack_tab5_v2_landscape.yaml</a></p>
]]></description><link>https://community.m5stack.com/post/30395</link><guid isPermaLink="true">https://community.m5stack.com/post/30395</guid><dc:creator><![CDATA[konstantint]]></dc:creator><pubDate>Fri, 02 Jan 2026 19:48:48 GMT</pubDate></item><item><title><![CDATA[Reply to any known good yaml configs for esphome for the tab5 v2 on Tue, 30 Dec 2025 19:59:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/easytarget" aria-label="Profile: easytarget">@<bdi>easytarget</bdi></a> hey one of those suggestions got it.  I added in the camera pin and I moved the display pin out of the display block and now I'm off to the races.</p>
]]></description><link>https://community.m5stack.com/post/30383</link><guid isPermaLink="true">https://community.m5stack.com/post/30383</guid><dc:creator><![CDATA[manmade]]></dc:creator><pubDate>Tue, 30 Dec 2025 19:59:44 GMT</pubDate></item><item><title><![CDATA[Reply to any known good yaml configs for esphome for the tab5 v2 on Mon, 29 Dec 2025 21:23:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manmade" aria-label="Profile: manmade">@<bdi>manmade</bdi></a><br />
I dont see the nRESET signal being removed from the LCD, TouchPanel (and Camera).<br />
It's a low=active reset for these devices, and the E1 pi4ioe5v6408 chip that controls them will default these pins to low (actually, input-pulldown) and holds the reset pin active. These are pins 4,5,6 on the chip:</p>
<p dir="auto">Maybe you need something like:</p>
<pre><code>  - platform: gpio
    pin:
      number: 4
  - platform: gpio
    pin:
      number: 5
  - platform: gpio
    pin:
      number: 6
<p dir="auto">Because these are active-low lines they are being applied when the unit powers up, you have to explicitly remove them after boot.</p>
<p dir="auto">This <strong>is</strong> a guess, I'm not running HA on my tab5. There may be other things that need to happen too or are broken. But I just spent all day playing with some TAB5 hardware stuff in MicroPython and<br />
this was one of the things I discovered..</p>
]]></description><link>https://community.m5stack.com/post/30378</link><guid isPermaLink="true">https://community.m5stack.com/post/30378</guid><dc:creator><![CDATA[easytarget]]></dc:creator><pubDate>Mon, 29 Dec 2025 21:23:20 GMT</pubDate></item><item><title><![CDATA[Reply to any known good yaml configs for esphome for the tab5 v2 on Mon, 29 Dec 2025 15:41:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manmade" aria-label="Profile: manmade">@<bdi>manmade</bdi></a> nothing is shown on the screen still, however I have been able to add the device to home assistant and connect to the api to turn the backlight on and off.</p>
]]></description><link>https://community.m5stack.com/post/30377</link><guid isPermaLink="true">https://community.m5stack.com/post/30377</guid><dc:creator><![CDATA[manmade]]></dc:creator><pubDate>Mon, 29 Dec 2025 15:41:40 GMT</pubDate></item></channel></rss>
