<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Audio Module ES8388]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I am struggling with bring up audio module with es8388 codec on ESP-IDF. I trying to based on <a href="https://github.com/m5stack/M5Module-Audio/tree/main" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Module-Audio/tree/main</a> but this example is not true I2S bypass (it set bypass on chip in registers ES8388_DACCONTROL17 and ES8388_DACCONTROL20). But I need working solution with bypass audio ADC -&gt; I2S -&gt; DSP (bypass) -&gt; I2S -&gt; DAC. Anyone can help me with this codec?<br />
Its my main file:</p>
<pre><code>#include "freertos/FreeRTOS.h"
#include "es8388.h"
#include "esp_log.h"
#include "driver/i2c_master.h"
#define I2C_PORT        I2C_NUM_0
#define I2C_SDA         12
#define I2C_SCL         11
#define I2C_CLK_SPEED   100000
static const char *TAG = "ES8388";
static i2c_master_bus_handle_t bus_handle;
static i2c_master_dev_handle_t dev_handle;
static void i2c_init(void)
    i2c_master_bus_config_t bus_cfg = {
        .i2c_port = I2C_PORT,
        .sda_io_num = I2C_SDA,
        .scl_io_num = I2C_SCL,
        .clk_source = I2C_CLK_SRC_DEFAULT,
        .flags.enable_internal_pullup = true,
    ESP_ERROR_CHECK(i2c_new_master_bus(&amp;bus_cfg, &amp;bus_handle));
    i2c_device_config_t dev_cfg = {
        .device_address = ES8388_ADDR,
        .dev_addr_length = I2C_ADDR_BIT_LEN_7,
        .scl_speed_hz = I2C_CLK_SPEED,
    ESP_ERROR_CHECK(i2c_master_bus_add_device(bus_handle, &amp;dev_cfg, &amp;dev_handle));
    ESP_LOGI(TAG, "ES8388 I2C device initialized (new API)");
esp_err_t es_write_reg(uint8_t reg, uint8_t data)
    uint8_t buf[2] = {reg, data};
    return i2c_master_transmit(dev_handle, buf, sizeof(buf), -1);
esp_err_t es_read_reg(uint8_t reg, uint8_t *data)
    esp_err_t res = i2c_master_transmit(dev_handle, &amp;reg, 1, -1);
    if (res != ESP_OK) return res;
    return i2c_master_receive(dev_handle, data, 1, -1);
esp_err_t es8388_init(void)
    i2c_init();
	esp_err_t res = ESP_OK;
	/* INITIALIZATION (BASED ON ES8388 USER GUIDE EXAMPLE) */
    // Set Chip to Slave
    res |= es_write_reg(ES8388_MASTERMODE, 0x00);
    // Power down DEM and STM
    res |= es_write_reg(ES8388_CHIPPOWER, 0xFF);
    // Set same LRCK	Set same LRCK
    res |= es_write_reg(ES8388_DACCONTROL21, 0x80);
    // Set Chip to Play&amp;Record Mode
    res |= es_write_reg(ES8388_CONTROL1, 0x05);
    // Power Up Analog and Ibias
    res |= es_write_reg(ES8388_CONTROL2, 0x40);
    /* ADC setting */
    // Micbias for Record
    res |= es_write_reg(ES8388_ADCPOWER, 0x00);
    // Enable Lin1/Rin1 (0x00 0x00) for Lin2/Rin2 (0x50 0x80)
    res |= es_write_reg(ES8388_ADCCONTROL2, 0x00);
    res |= es_write_reg(ES8388_ADCCONTROL3, 0x00);
    // PGA gain (0x88 - 24db) (0x77 - 21db)
    res |= es_write_reg(ES8388_ADCCONTROL1, 0x88);
    // SFI setting (i2s mode/16 bit)
    res |= es_write_reg(ES8388_ADCCONTROL4, 0x2C);
    // ADC MCLK/LCRK ratio (256)
    res |= es_write_reg(ES8388_ADCCONTROL5, 0x02);
    // set ADC digital volume
    res |= es_write_reg(ES8388_ADCCONTROL7, 0x28);
    res |= es_write_reg(ES8388_ADCCONTROL8, 0x00);
    res |= es_write_reg(ES8388_ADCCONTROL9, 0x00);
    // recommended ALC setting for VOICE refer to ES8388 MANUAL
    res |= es_write_reg(ES8388_ADCCONTROL10, 0x38);
    res |= es_write_reg(ES8388_ADCCONTROL11, 0xC0);
    res |= es_write_reg(ES8388_ADCCONTROL12, 0x12);
    res |= es_write_reg(ES8388_ADCCONTROL13, 0x06);
    res |= es_write_reg(ES8388_ADCCONTROL14, 0xC3);
    /* DAC setting */
    // Power Up DAC&amp; enable Lout/Rout
    res |= es_write_reg(ES8388_DACPOWER, 0x3F);
    res |= es_write_reg(ES8388_DACCONTROL1, 0x18);
    // DAC MCLK/LCRK ratio (256)
    res |= es_write_reg(ES8388_DACCONTROL2, 0x02);
    // unmute codec
    res |= es_write_reg(ES8388_DACCONTROL3, 0x00);
    // set DAC digital volume
    res |= es_write_reg(ES8388_DACCONTROL4, 0x05);
    res |= es_write_reg(ES8388_DACCONTROL5, 0x05);
    // Setup Mixer
    // (reg[16] 1B mic Amp, 0x09 direct;[reg 17-20] 0x90 DAC, 0x50 Mic Amp)
    res |= es_write_reg(ES8388_DACCONTROL16, 0x00);
    res |= es_write_reg(ES8388_DACCONTROL17, 0x90);
    // res |= es_write_reg(ES8388_DACCONTROL18, 0x38);  //??
    // res |= es_write_reg(ES8388_DACCONTROL19, 0x38);  //??
    res |= es_write_reg(ES8388_DACCONTROL20, 0x90);
    // set Lout/Rout Volume -45db
    res |= es_write_reg(ES8388_DACCONTROL24, 0x12);
    res |= es_write_reg(ES8388_DACCONTROL25, 0x12);
    res |= es_write_reg(ES8388_DACCONTROL26, 0x00);
    res |= es_write_reg(ES8388_DACCONTROL27, 0x00);
    /* Power up DEM and STM */
    res |= es_write_reg(ES8388_CHIPPOWER, 0x00);
    if(res == ESP_OK)
        ESP_LOGI(TAG, "ES8388 initializes OK");
    else
        ESP_LOGI(TAG, "ES8388 initializes FAIL");
	return res;
esp_err_t setMicGain(es_mic_gain_t gain)
    uint8_t controlValue = (gain &lt;&lt; 4) | gain;
    res |= es_write_reg(ES8388_ADCCONTROL1, controlValue);
    return res;
uint8_t getMicGain()
    static uint8_t data;
    es_read_reg(ES8388_ADCCONTROL1, &amp;data);
    data = data &amp; 0x0f;
    return data;
esp_err_t setADCInput(es_adc_input_t input)
    uint8_t reg = 0;
    res         = es_read_reg(ES8388_ADCCONTROL2, &amp;reg);
    reg         = reg &amp; 0x0f;
    res |= es_write_reg(ES8388_ADCCONTROL2, reg | input);
    if (input == ADC_INPUT_LINPUT2_RINPUT2) {
        res |= es_write_reg(ES8388_ADCCONTROL3, 0x80);
    return res;
esp_err_t setADCVolume(uint8_t volume)
    if (volume &gt; 100) volume = 100;
    uint16_t steps = (uint16_t)(((100 - volume) * 192) / 100);
    uint8_t data   = (uint8_t)(steps);
    res |= es_write_reg(ES8388_ADCCONTROL8, data);
    res |= es_write_reg(ES8388_ADCCONTROL9, data);
    return res;
esp_err_t setDACVolume(uint8_t volume)
    volume        = (volume &gt; 100) ? 100 : volume;
    uint8_t steps = (uint8_t)(((uint16_t)(volume) * 33 + 50) / 100);
    steps         = (steps &gt; 0x21) ? 0x21 : steps;
    res |= es_write_reg(ES8388_DACCONTROL24, steps);
    res |= es_write_reg(ES8388_DACCONTROL25, steps);
    return res;
esp_err_t setDACOutput(es_dac_output_t output)
    res |= es_write_reg(ES8388_DACPOWER, output);
    return res;
// mute Output
esp_err_t setDACmute(bool mute)
    uint8_t _reg;
    es_read_reg(ES8388_ADCCONTROL1, &amp;_reg);
    if (mute)
        res |= es_write_reg(ES8388_DACCONTROL3, _reg | 0x02);
    else
        res |= es_write_reg(ES8388_DACCONTROL3, _reg &amp; ~(0x02));
    return res;
esp_err_t setMixSourceSelect(es_mixsel_t lmixsel, es_mixsel_t rmixsel)
    uint8_t left_bits = 0, right_bits = 0;
    switch (lmixsel) {
        case MIXLIN1:
            left_bits = 0b000;
            break;
        case MIXLIN2:
            left_bits = 0b001;
            break;
        case MIXADC:
            left_bits = 0b011;
            break;
        case MIXRES:
            return false;
        default:
            return false;
    switch (rmixsel) {
        case MIXLIN1:
            right_bits = 0b000;
            break;
        case MIXLIN2:
            right_bits = 0b001;
            break;
        case MIXADC:
            right_bits = 0b011;
            break;
        case MIXRES:
            return false;
        default:
            return false;
    uint8_t data = (left_bits &lt;&lt; 3) | (right_bits &lt;&lt; 0);
    res |= es_write_reg(ES8388_DACCONTROL16, data);
    return res;
esp_err_t setBitsSample(es_module_t mode, es_bits_length_t bits_len)
    uint8_t reg = 0;
    int bits    = (int)bits_len;
    if (mode == ES_MODULE_ADC || mode == ES_MODULE_ADC_DAC) {
        res = es_read_reg(ES8388_ADCCONTROL4, &amp;reg);
        reg = reg &amp; 0xe3;
        res |= es_write_reg(ES8388_ADCCONTROL4, reg | (bits &lt;&lt; 2));
    if (mode == ES_MODULE_DAC || mode == ES_MODULE_ADC_DAC) {
        res = es_read_reg(ES8388_DACCONTROL1, &amp;reg);
        reg = reg &amp; 0xc7;
        res |= es_write_reg(ES8388_DACCONTROL1, reg | (bits &lt;&lt; 3));
    return res;
esp_err_t setSampleRate(es_sample_rate_t rate)
    uint8_t masterMode = 0x00;
    uint8_t adcFsRatio = 0x02;
    uint8_t dacFsRatio = 0x02;
    uint8_t mclkDiv    = 0x00;
    switch (rate) {
        case SAMPLE_RATE_8K:    // MCLK=12.288MHz
            adcFsRatio = 0x0A;  // 01010 (MCLK/1536)
            dacFsRatio = 0x0A;
            break;
        case SAMPLE_RATE_11K:   // MCLK=11.2896MHz
            adcFsRatio = 0x07;  // 00111 (MCLK/1024)
            dacFsRatio = 0x07;
            break;
        case SAMPLE_RATE_16K:   // MCLK=12.288MHz
            adcFsRatio = 0x06;  // 00110 (MCLK/768)
            dacFsRatio = 0x06;
            break;
        case SAMPLE_RATE_24K:   // MCLK=12.288MHz
            adcFsRatio = 0x04;  // 00100 (MCLK/512)
            dacFsRatio = 0x04;
            break;
        case SAMPLE_RATE_32K:   // MCLK=12.288MHz
            adcFsRatio = 0x03;  // 00011 (MCLK/384)
            dacFsRatio = 0x03;
            break;
        case SAMPLE_RATE_44K:   // MCLK=11.2896MHz
            adcFsRatio = 0x02;  // 00010 (MCLK/256)
            dacFsRatio = 0x02;
            mclkDiv    = 0x40;
            break;
        case SAMPLE_RATE_48K:
            dacFsRatio = 0x02;
            break;
        default:
            return false;
    res |= es_write_reg(ES8388_MASTERMODE, masterMode | mclkDiv);
    res |= es_write_reg(ES8388_ADCCONTROL5, adcFsRatio &amp; 0x1F);
    res |= es_write_reg(ES8388_DACCONTROL2, dacFsRatio &amp; 0x1F);
    return res;
<p dir="auto">This is my driver<br />
es8388.c:</p>
#include "es8388.h"
#define I2C_SDA         12
#define I2C_SCL         11
    i2c_init();
    /* ADC setting */
    /* DAC setting */
    // unmute codec
    // Setup Mixer
    res |= es_write_reg(ES8388_DACCONTROL17, 0xD0);
    res |= es_write_reg(ES8388_DACCONTROL20, 0xD0);
    if(res == ESP_OK)
    else
	return res;
    return res;
    return data;
    uint8_t reg = 0;
    return res;
    return res;
    return res;
    return res;
// mute Output
    uint8_t _reg;
    if (mute)
    else
    return res;
    switch (lmixsel) {
        case MIXLIN1:
            left_bits = 0b000;
            break;
        case MIXLIN2:
            left_bits = 0b001;
            break;
        case MIXADC:
            left_bits = 0b011;
            break;
        case MIXRES:
            return false;
        default:
            return false;
    switch (rmixsel) {
        case MIXLIN1:
            right_bits = 0b000;
            break;
        case MIXLIN2:
            right_bits = 0b001;
            break;
        case MIXADC:
            right_bits = 0b011;
            break;
        case MIXRES:
            return false;
        default:
            return false;
    return res;
    uint8_t reg = 0;
    return res;
    switch (rate) {
            dacFsRatio = 0x0A;
            break;
            dacFsRatio = 0x07;
            break;
            dacFsRatio = 0x06;
            break;
            dacFsRatio = 0x04;
            break;
            dacFsRatio = 0x03;
            break;
            dacFsRatio = 0x02;
            mclkDiv    = 0x40;
            break;
            dacFsRatio = 0x02;
            break;
        default:
            return false;
    return res;
<p dir="auto">es8388.h:</p>
<pre><code>/*
 * es8388.h
 *  Created on: Jul 31, 2021
 *      Author: xenir
#ifndef ES8388_H_
#define ES8388_H_
#include "stdbool.h"
#include "stdint.h"
 * @file ES8388_registers.h
 * @brief Definitions for ES8388 audio codec registers
 *  @brief I2C device address for ES8388
#define ES8388_ADDR (0x10)
/* ES8388 control registers */
 * @brief Control register 1 - System control and clock settings
#define ES8388_CONTROL1 (0x00)
 * @brief Control register 2 - Interface format and clock mode
#define ES8388_CONTROL2 (0x01)
 * @brief Chip power management register
#define ES8388_CHIPPOWER (0x02)
 * @brief ADC power control register
#define ES8388_ADCPOWER (0x03)
 * @brief DAC power control register
#define ES8388_DACPOWER (0x04)
 * @brief Low power control register 1
#define ES8388_CHIPLOPOW1 (0x05)
 * @brief Low power control register 2
#define ES8388_CHIPLOPOW2 (0x06)
 * @brief Analog volume management control
#define ES8388_ANAVOLMANAG (0x07)
 * @brief Master/slave mode control
#define ES8388_MASTERMODE (0x08)
/* ADC registers */
 * @brief ADC control 1 - Input selection and PGA gain
#define ES8388_ADCCONTROL1 (0x09)
 @brief ADC control 2 - Digital mic settings
#define ES8388_ADCCONTROL2 (0x0a)
 * @brief ADC control 3 - High-pass filter and ADC mode
#define ES8388_ADCCONTROL3 (0x0b)
 * @brief ADC control 4 - Sample rate and clock divider
#define ES8388_ADCCONTROL4 (0x0c)
 * @brief ADC control 5 - Digital volume control
#define ES8388_ADCCONTROL5 (0x0d)
 * @brief ADC control 6 - ALC settings 1
#define ES8388_ADCCONTROL6 (0x0e)
 * @brief ADC control 7 - ALC settings 2
#define ES8388_ADCCONTROL7 (0x0f)
 * @brief ADC control 8 - ALC settings 3
#define ES8388_ADCCONTROL8 (0x10)
 * @brief ADC control 9 - Noise gate control
#define ES8388_ADCCONTROL9 (0x11)
 * @brief ADC control 10 - Zero detection
#define ES8388_ADCCONTROL10 (0x12)
 * @brief ADC control 11 - ALC enable and mode
#define ES8388_ADCCONTROL11 (0x13)
 * @brief ADC control 12 - Left channel volume
#define ES8388_ADCCONTROL12 (0x14)
 * @brief ADC control 13 - Right channel volume
#define ES8388_ADCCONTROL13 (0x15)
 * @brief ADC control 14 - Analog PGA control
#define ES8388_ADCCONTROL14 (0x16)
/* DAC registers */
 * @brief DAC control 1 - Soft ramp and volume control
#define ES8388_DACCONTROL1 (0x17)
 * @brief DAC control 2 - DAC interface format
#define ES8388_DACCONTROL2 (0x18)
 * @brief DAC control 3 - De-emphasis and mute control
#define ES8388_DACCONTROL3 (0x19)
 * @brief DAC control 4 - Sample rate and clock divider
#define ES8388_DACCONTROL4 (0x1a)
 * @brief DAC control 5 - Digital volume left
#define ES8388_DACCONTROL5 (0x1b)
 * @brief DAC control 6 - Digital volume right
#define ES8388_DACCONTROL6 (0x1c)
 * @brief DAC control 7 - Volume mixer control
#define ES8388_DACCONTROL7 (0x1d)
 * @brief DAC control 8 - Mixer settings
#define ES8388_DACCONTROL8 (0x1e)
 * @brief DAC control 9 - Channel swap and mute
#define ES8388_DACCONTROL9 (0x1f)
 * @brief DAC control 10 - Zero cross detection
#define ES8388_DACCONTROL10 (0x20)
 * @brief DAC control 11 - Volume ramp rate
#define ES8388_DACCONTROL11 (0x21)
 * @brief DAC control 12 - Power management
#define ES8388_DACCONTROL12 (0x22)
 * @brief DAC control 13 - Analog output control
#define ES8388_DACCONTROL13 (0x23)
 * @brief DAC control 14 - Output phase control
#define ES8388_DACCONTROL14 (0x24)
 * @brief DAC control 15 - Output level control
#define ES8388_DACCONTROL15 (0x25)
 * @brief DAC control 16 - Mixer volume left
#define ES8388_DACCONTROL16 (0x26)
 * @brief DAC control 17 - Mixer volume right
#define ES8388_DACCONTROL17 (0x27)
 * @brief DAC control 18 - ALC control 1
#define ES8388_DACCONTROL18 (0x28)
 * @brief DAC control 19 - ALC control 2
#define ES8388_DACCONTROL19 (0x29)
 * @brief DAC control 20 - ALC control 3
#define ES8388_DACCONTROL20 (0x2a)
 * @brief DAC control 21 - ALC control 4
#define ES8388_DACCONTROL21 (0x2b)
 * @brief DAC control 22 - Noise gate control
#define ES8388_DACCONTROL22 (0x2c)
 * @brief DAC control 23 - Zero detection
#define ES8388_DACCONTROL23 (0x2d)
 * @brief DAC control 24 - Output mute control
#define ES8388_DACCONTROL24 (0x2e)
 * @brief DAC control 25 - Volume bypass control
#define ES8388_DACCONTROL25 (0x2f)
 * @brief DAC control 26 - Output phase control
#define ES8388_DACCONTROL26 (0x30)
 * @brief DAC control 27 - Volume fade control
#define ES8388_DACCONTROL27 (0x31)
 * @brief DAC control 28 - Power on delay control
#define ES8388_DACCONTROL28 (0x32)
 * @brief DAC control 29 - Output driver control
#define ES8388_DACCONTROL29 (0x33)
 * @brief DAC control 30 - Reserved/test mode
#define ES8388_DACCONTROL30 (0x34)
 * @brief Mixer input source selection
 * @note Mixer configuration affects audio path routing
typedef enum {
    MIXLIN1, /**&lt; Direct line input 1 (unprocessed signal path) */
    MIXLIN2, /**&lt; Direct line input 2 (alternative signal path) */
    MIXRES,  /**&lt; Reserved mixer source (do not use in normal operation) */
    MIXADC   /**&lt; Processed signal from ADC/ALC (with automatic level control) */
} es_mixsel_t;
 * @brief ES8388 functional module selection
typedef enum {
    ES_MODULE_MIN     = -1,   /**&lt; Minimum module selector (validation flag) */
    ES_MODULE_ADC     = 0x01, /**&lt; Enable ADC module */
    ES_MODULE_DAC     = 0x02, /**&lt; Enable DAC module */
    ES_MODULE_ADC_DAC = 0x03, /**&lt; Enable both ADC and DAC modules */
    ES_MODULE_LINE    = 0x04, /**&lt; Line-in/out interface control */
    ES_MODULE_MAX             /**&lt; Maximum module selector (validation flag) */
} es_module_t;
 * @brief Audio data bit length configuration
 * @note Actual supported resolution depends on hardware capabilities
typedef enum {
    BIT_LENGTH_MIN    = -1,   /**&lt; Minimum bit length flag (validation) */
    BIT_LENGTH_16BITS = 0x03, /**&lt; 16-bit word length */
    BIT_LENGTH_18BITS = 0x02, /**&lt; 18-bit word length */
    BIT_LENGTH_20BITS = 0x01, /**&lt; 20-bit word length */
    BIT_LENGTH_24BITS = 0x00, /**&lt; 24-bit word length (typical default) */
    BIT_LENGTH_32BITS = 0x04, /**&lt; 32-bit word length */
    BIT_LENGTH_MAX,           /**&lt; Maximum bit length flag (validation) */
} es_bits_length_t;
 * @brief ADC input channel selection
 * @note Configuration affects both left and right channels
typedef enum {
    ADC_INPUT_LINPUT1_RINPUT1 = 0x00, /**&lt; Use input 1 for both channels */
    ADC_INPUT_LINPUT2_RINPUT2 = 0x10, /**&lt; Use input 2 for both channels */
    ADC_INPUT_DIFFERENCE1     = 0xf0, /**&lt; Differential input configuration */
} es_adc_input_t;
 * @brief DAC output channel selection
 * @note Multiple outputs can be combined using bitwise OR
typedef enum {
    DAC_OUTPUT_OUT1 = 0x30, /**&lt; Enable output channel 1 */
    DAC_OUTPUT_OUT2 = 0x0C, /**&lt; Enable output channel 2 */
    DAC_OUTPUT_ALL  = 0x3c, /**&lt; Enable all output channels */
} es_dac_output_t;
 * @brief Microphone gain settings
 * @note Values represent gain steps in 3dB increments
typedef enum {
    MIC_GAIN_0DB = 0, /**&lt; 0dB microphone gain */
    MIC_GAIN_3DB,     /**&lt; 3dB microphone gain */
    MIC_GAIN_6DB,     /**&lt; 6dB microphone gain */
    MIC_GAIN_9DB,     /**&lt; 9dB microphone gain */
    MIC_GAIN_12DB,    /**&lt; 12dB microphone gain */
    MIC_GAIN_15DB,    /**&lt; 15dB microphone gain */
    MIC_GAIN_18DB,    /**&lt; 18dB microphone gain */
    MIC_GAIN_21DB,    /**&lt; 21dB microphone gain */
    MIC_GAIN_24DB,    /**&lt; 24dB microphone gain (maximum) */
} es_mic_gain_t;
typedef enum {
    SAMPLE_RATE_8K = 0, /**&lt; 8000 Hz sampling rate */
    SAMPLE_RATE_11K,    /**&lt; 11025 Hz sampling rate */
    SAMPLE_RATE_16K,    /**&lt; 16000 Hz sampling rate */
    SAMPLE_RATE_24K,    /**&lt; 24000 Hz sampling rate */
    SAMPLE_RATE_32K,    /**&lt; 32000 Hz sampling rate */
    SAMPLE_RATE_44K,    /**&lt; 44100 Hz sampling rate (CD quality) */
    SAMPLE_RATE_48K     /**&lt; 48000 Hz sampling rate (professional audio) */
} es_sample_rate_t;
// API
esp_err_t es_write_reg(uint8_t reg, uint8_t data);
esp_err_t es_read_reg(uint8_t reg, uint8_t *data);
esp_err_t es8388_init(void);
esp_err_t setMicGain(es_mic_gain_t gain);
uint8_t getMicGain();
esp_err_t setADCInput(es_adc_input_t input);
esp_err_t setADCVolume(uint8_t volume);
esp_err_t setDACVolume(uint8_t volume);
esp_err_t setDACOutput(es_dac_output_t output);
esp_err_t setDACmute(bool mute);
esp_err_t setMixSourceSelect(es_mixsel_t lmixsel, es_mixsel_t rmixsel);
esp_err_t setBitsSample(es_module_t mode, es_bits_length_t bits_len);
esp_err_t setSampleRate(es_sample_rate_t rate);
void es8388_dump_registers(void);
esp_err_t es8388_check_connection(void);
#endif /* ES8388_H_ */
<p dir="auto">Maybe is something wrong with my I2S config?</p>
]]></description><link>https://community.m5stack.com/topic/7966/m5stack-audio-module-es8388</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 02:50:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7966.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Dec 2025 20:53:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Audio Module ES8388 on Fri, 02 Jan 2026 11:23:03 GMT]]></title><description><![CDATA[<p dir="auto">I fix the problem by remove condensator C9<br />
<img src="/assets/uploads/files/1767352914243-audiomodulefix.png" alt="audioModuleFix.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><a href="https://youtube.com/shorts/OJ2RSZR5Y94?si=I5c_K-Tsh-rh9QJC" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtube.com/shorts/OJ2RSZR5Y94?si=I5c_K-Tsh-rh9QJC</a></p>
]]></description><link>https://community.m5stack.com/post/30391</link><guid isPermaLink="true">https://community.m5stack.com/post/30391</guid><dc:creator><![CDATA[dkuzniar]]></dc:creator><pubDate>Fri, 02 Jan 2026 11:23:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Audio Module ES8388 on Tue, 23 Dec 2025 17:03:15 GMT]]></title><description><![CDATA[<p dir="auto">I already run it with this codes:</p>
<p dir="auto">my main file audioFX.c:</p>
#include "freertos/task.h"
#include "es8388.h"
#include "driver/i2s_std.h"
static char *TAG = "app_main";
// I2S config
#define I2S_NUM         (0)
#define SAMPLE_RATE     (48000)
#define I2S_MCLK 0
#define I2S_SCLK 7
#define I2S_WS 6
#define I2S_DOUT 13
#define I2S_DIN 14
#define DMA_DESC_NUM   8
#define DMA_FRAME_NUM  256
#define AUDIO_BUF_SAMPLES 256
#define FRAMES_PER_BLOCK 256
#define CHANNELS         2
static i2s_chan_handle_t tx_handle;
static i2s_chan_handle_t rx_handle;
static void codec_init(void)
    es8388_init();
    setADCInput(ADC_INPUT_LINPUT1_RINPUT1);
    setADCVolume(100);
    setDACVolume(60);
    setDACOutput(DAC_OUTPUT_OUT1);
    setBitsSample(ES_MODULE_LINE, BIT_LENGTH_16BITS);
    setSampleRate(SAMPLE_RATE_48K);
static void init_i2s(void)
    /* ---------- CHANNEL CONFIG ---------- */
    i2s_chan_config_t chan_cfg = {
        .id = I2S_NUM,
        .role = I2S_ROLE_MASTER,
        .dma_desc_num = DMA_DESC_NUM,
        .dma_frame_num = DMA_FRAME_NUM,
        .auto_clear = true,
        .intr_priority = 0,
    ESP_ERROR_CHECK(i2s_new_channel(&amp;chan_cfg, &amp;tx_handle, &amp;rx_handle));
    /* ---------- STANDARD I2S CONFIG ---------- */
    i2s_std_config_t std_cfg = {
        .clk_cfg = {
            .sample_rate_hz = SAMPLE_RATE,
            .clk_src = I2S_CLK_SRC_DEFAULT,
            .ext_clk_freq_hz = 0,
            .mclk_multiple = I2S_MCLK_MULTIPLE_256,
        .slot_cfg = {
            .data_bit_width = I2S_DATA_BIT_WIDTH_16BIT,
            .slot_bit_width = I2S_SLOT_BIT_WIDTH_16BIT,
            .slot_mode = I2S_SLOT_MODE_STEREO,
            .slot_mask = I2S_STD_SLOT_BOTH,
            .ws_width = 16,
            .ws_pol = false,
            .bit_shift = true,
            .left_align = true,
            .big_endian = false,
            .bit_order_lsb = false,
        .gpio_cfg = {
            .mclk = I2S_MCLK,
            .bclk = I2S_SCLK,
            .ws   = I2S_WS,
            .dout = I2S_DOUT,
            .din  = I2S_DIN,
            .invert_flags = {
                .mclk_inv = false,
                .bclk_inv = false,
                .ws_inv   = false,
    /* ---------- INIT + ENABLE ---------- */
    ESP_ERROR_CHECK(i2s_channel_init_std_mode(tx_handle, &amp;std_cfg));
    ESP_ERROR_CHECK(i2s_channel_init_std_mode(rx_handle, &amp;std_cfg));
    ESP_ERROR_CHECK(i2s_channel_enable(tx_handle));
    ESP_ERROR_CHECK(i2s_channel_enable(rx_handle));
#define SINE_SAMPLES 48
static const int16_t sine_lut[SINE_SAMPLES] = {
     0,  3916,  7764, 11480, 15000, 18263, 21213, 23800,
 25981, 27716, 28978, 29750, 30000, 29750, 28978, 27716,
 25981, 23800, 21213, 18263, 15000, 11480,  7764,  3916,
     0, -3916, -7764,-11480,-15000,-18263,-21213,-23800,
-25981,-27716,-28978,-29750,-30000,-29750,-28978,-27716,
-25981,-23800,-21213,-18263,-15000,-11480, -7764, -3916
int16_t sine_1khz_next_sample(void)
    static uint32_t idx = 0;
    int16_t sample = sine_lut[idx];
    idx++;
    if (idx &gt;= SINE_SAMPLES) {
        idx = 0;
    return sample;
static void audioTask(void *arg)
    ESP_LOGI("AUDIO", "audioTask STARTED");
    // Bufor I2S (interleaved: L R L R ...)
    int16_t i2s_buf[FRAMES_PER_BLOCK * CHANNELS];
    // channels
    int16_t left[FRAMES_PER_BLOCK];
    int16_t right[FRAMES_PER_BLOCK];
    size_t bytes_read = 0;
    size_t bytes_written = 0;
    while (true) {
        /* ===== RX ===== */
        esp_err_t err = i2s_channel_read(
            rx_handle,
            i2s_buf,
            sizeof(i2s_buf),
            &amp;bytes_read,
            portMAX_DELAY
        if (err != ESP_OK || bytes_read == 0) {
            continue;
        size_t frames = bytes_read / (CHANNELS * sizeof(int16_t));
        /* ===== DEINTERLEAVE ===== */
        for (size_t i = 0; i &lt; frames; i++)
            left[i]  = i2s_buf[2 * i];       // L
            right[i] = i2s_buf[2 * i + 1];   // R
        /* ===== DSP ===== */
            left[i]  = left[i]  * 1.0f;
            right[i] = right[i] * 1.0f;
            // left[i]  = sine_1khz_next_sample();
            // right[i] = 0;
        /* ===== INTERLEAVE ===== */
            i2s_buf[2 * i]     = left[i];    // L
            i2s_buf[2 * i + 1] = right[i];   // R
        /* ===== TX ===== */
        i2s_channel_write(
            tx_handle,
            i2s_buf,
            frames * CHANNELS * sizeof(int16_t),
            &amp;bytes_written,
            portMAX_DELAY
void app_main(void)
    codec_init();
    init_i2s();
    BaseType_t ret = xTaskCreate(
    audioTask,
    "audioTask",
    4096,
    NULL,
    5,
    NULL
    if (ret != pdPASS) {
        ESP_LOGE(TAG, "audioTask creation FAILED");
    } else {
        ESP_LOGI(TAG, "audioTask created OK");
<p dir="auto">es8388.c:</p>
#include "es8388.h"
#define I2C_SDA         12
#define I2C_SCL         11
    i2c_init();
    res |= es_write_reg(ES8388_CONTROL1, 0x14);
    /* ADC setting */
    res |= es_write_reg(ES8388_ADCCONTROL4, 0x0C);
    // disable HPF
    res |= es_write_reg(ES8388_ADCCONTROL6, 0x00);
    res |= es_write_reg(ES8388_ADCCONTROL7, 0x00);
    res |= es_write_reg(ES8388_ADCCONTROL14, 0xC2);
    /* DAC setting */
    // unmute codec
    // Setup Mixer
    if(res == ESP_OK)
    else
	return res;
esp_err_t es8388_init2(void)
    i2c_init();
    /* mute DAC during setup, power up all systems, slave mode */
    res |= es_write_reg(ES8388_DACCONTROL3, 0x04);
    res |= es_write_reg(ES8388_CONTROL2, 0x50);
    /* power up DAC and enable LOUT1+2 / ROUT1+2, ADC sample rate = DAC sample rate */
    res |= es_write_reg(ES8388_DACPOWER, 0x3e);
    res |= es_write_reg(ES8388_CONTROL1, 0x12);
    /* DAC I2S setup: 16 bit word length, I2S format; MCLK / Fs = 256*/
    /* DAC to output route mixer configuration: ADC MIX TO OUTPUT */
    res |= es_write_reg(ES8388_DACCONTROL16, 0x1B);
    /* DAC and ADC use same LRCK, enable MCLK input; output resistance setup */
    res |= es_write_reg(ES8388_DACCONTROL23, 0x00);
    /* DAC volume control: 0dB (maximum, unattented)  */
    res |= es_write_reg(ES8388_DACCONTROL5, 0x00);
    res |= es_write_reg(ES8388_DACCONTROL4, 0x00);
    /* power down ADC while configuring; volume: +9dB for both channels */
    res |= es_write_reg(ES8388_ADCPOWER, 0xff);
    /* select LINPUT1 / RINPUT1 as ADC input; stereo; 16 bit word length, format right-justified, MCLK / Fs = 256 */
    /* set ADC volume */
    res |= es_write_reg(ES8388_ADCCONTROL8, 0x20);
    res |= es_write_reg(ES8388_ADCCONTROL9, 0x20);
    /* set LOUT1 / ROUT1 volume: 0dB (unattenuated) */
    res |= es_write_reg(ES8388_DACCONTROL24, 0x1e);
    res |= es_write_reg(ES8388_DACCONTROL25, 0x1e);
    /* set LOUT2 / ROUT2 volume: 0dB (unattenuated) */
    res |= es_write_reg(ES8388_DACCONTROL26, 0x10);
    res |= es_write_reg(ES8388_DACCONTROL27, 0x10);
    /* power up and enable DAC; power up ADC (no MIC bias) */
    res |= es_write_reg(ES8388_DACPOWER, 0x3c);
    if(res == ESP_OK)
    else
	return res;
    return res;
    return data;
    uint8_t reg = 0;
    return res;
    return res;
    return res;
    return res;
// mute Output
    uint8_t _reg;
    if (mute)
    else
    return res;
    switch (lmixsel) {
        case MIXLIN1:
            left_bits = 0b000;
            break;
        case MIXLIN2:
            left_bits = 0b001;
            break;
        case MIXADC:
            left_bits = 0b011;
            break;
        case MIXRES:
            return false;
        default:
            return false;
    switch (rmixsel) {
        case MIXLIN1:
            right_bits = 0b000;
            break;
        case MIXLIN2:
            right_bits = 0b001;
            break;
        case MIXADC:
            right_bits = 0b011;
            break;
        case MIXRES:
            return false;
        default:
            return false;
    return res;
    uint8_t reg = 0;
    return res;
    switch (rate) {
            dacFsRatio = 0x0A;
            break;
            dacFsRatio = 0x07;
            break;
            dacFsRatio = 0x06;
            break;
            dacFsRatio = 0x04;
            break;
            dacFsRatio = 0x03;
            break;
            dacFsRatio = 0x02;
            mclkDiv    = 0x40;
            break;
            dacFsRatio = 0x02;
            break;
        default:
            return false;
    return res;
<pre><code>/*
 * es8388.h
 *      Author: xenir
#ifndef ES8388_H_
#define ES8388_H_
#include "stdint.h"
/* ADC registers */
/* DAC registers */
typedef enum {
} es_mixsel_t;
typedef enum {
} es_module_t;
typedef enum {
} es_bits_length_t;
typedef enum {
} es_adc_input_t;
typedef enum {
} es_dac_output_t;
typedef enum {
} es_mic_gain_t;
typedef enum {
} es_sample_rate_t;
// API
esp_err_t es8388_init2(void);
<p dir="auto">driver works but I still have a problem with left ADC, I do measures with generator -&gt; audioModule -&gt; M5Stack Code S3 SE -&gt; DSP bypass in code -&gt; audioModule -&gt; interface audio on my PC. I check 440 Hz on rigth and left channel, white noise, and also I check only DAC outputs and DAC seems to work properly. Maybe my audioModule is broken? Something<br />
wrong with left ADC circuit or es83388 chip.</p>
<p dir="auto">waveforms<br />
<img src="/assets/uploads/files/1766509063343-waveforms.png" alt="waveforms.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">R bypass 440 Hz<br />
<img src="/assets/uploads/files/1766509025521-r_bypass_440hz.png" alt="R_bypass_440Hz.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">L bypass 440 Hz<br />
<img src="/assets/uploads/files/1766509035686-l_bypass_440hz.png" alt="L_bypass_440Hz.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">R bypass white noise<br />
<img src="/assets/uploads/files/1766509047598-r_bypass_whitenoise.png" alt="R_bypass_whiteNoise.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">L bypass white noise<br />
<img src="/assets/uploads/files/1766509048316-l_bypass_whitenoise.png" alt="L_bypass_whiteNoise.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">R DAC 1kHz<br />
<img src="/assets/uploads/files/1766509055650-r_dac_1khz.png" alt="R_DAC_1kHz.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">L DAC 1 kHz<br />
<img src="/assets/uploads/files/1766509058042-l_dac_1khz.png" alt="L_DAC_1kHz.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">You can see that signal on left ADC channel have lower amplitude and frequency analysis with white noise shows that left ADC is not "flat" like on right channel.<br />
DAC outputs have the same amplitude so DAC works good.</p>
]]></description><link>https://community.m5stack.com/post/30351</link><guid isPermaLink="true">https://community.m5stack.com/post/30351</guid><dc:creator><![CDATA[dkuzniar]]></dc:creator><pubDate>Tue, 23 Dec 2025 17:03:15 GMT</pubDate></item></channel></rss>
