<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tetris For Tab5]]></title><description><![CDATA[<h1>Tetris Game For TAB5</h1>
<p dir="auto"><img src="/assets/uploads/files/1764684155755-tetris.png" alt="Tetris.png" class=" img-fluid img-markdown" /></p>
<h2>Quick Operation Table</h2>
<table class="table table-bordered table-striped">
<thead>
<tr>
<th>What to Do</th>
<th>How to Do It</th>
</tr>
</thead>
<tbody>
<tr>
<td>⬅️ Move Left</td>
<td>Swipe left on the screen</td>
</tr>
<tr>
<td>➡️ Move Right</td>
<td>Swipe right on the screen</td>
</tr>
<tr>
<td>🔄 Rotate Piece</td>
<td>Tap/Click on the screen</td>
</tr>
<tr>
<td>⬇️ Hard Drop</td>
<td>Swipe down on the screen</td>
</tr>
</tbody>
<tbody>
<tr>
<td>🎵 Sound Effects</td>
<td>Automatically plays when moving, clearing lines, or pieces land</td>
</tr>
</tbody>
</table>
<h2>Interface Guide</h2>
<thead>
<tr>
<th>Location</th>
<th>What's There</th>
<th>What It Does</th>
</tr>
</thead>
<tbody>
<tr>
<td>Top-Left</td>
<td>Score Display</td>
<td>Shows current score</td>
</tr>
<tr>
<td>Top-Center</td>
<td>Level Display</td>
<td>Shows current level (increases as you clear lines)</td>
</tr>
<tr>
<td>Top-Right</td>
<td>Lines Display</td>
<td>Shows total lines cleared</td>
</tr>
<tr>
<td>Middle</td>
<td>Game Board</td>
<td>Main playing area (10x20 grid)</td>
</tr>
<tr>
<td>Middle</td>
<td>Current Piece</td>
<td>The falling tetromino you control</td>
</tr>
<tr>
<td>Middle</td>
<td>Ghost Piece</td>
<td>Shows where the piece will land (semi-transparent)</td>
</tr>
<tr>
<td>Middle</td>
<td>Next Piece Preview</td>
<td>Shows the next piece coming</td>
</tr>
</tbody>
</table>
<h2>Game Rules</h2>
<p dir="auto">✅ <strong>Objective</strong>: Fill complete horizontal lines to clear them and score points</p>
<p dir="auto">✅ <strong>Scoring</strong>:</p>
<li>Single line: 100 points × level</li>
<li>Double lines: 300 points × level</li>
<li>Triple lines: 500 points × level</li>
<li>Tetris (4 lines): 800 points × level</li>
<p dir="auto">✅ <strong>Level Up</strong>: Every 10 lines cleared increases the level (faster falling speed)</p>
<p dir="auto">✅ <strong>Game Over</strong>: Game ends when new pieces can't spawn at the top</p>
<h2>Important Tips</h2>
<p dir="auto">✅ <strong>Single Block Movement</strong>: Each left/right swipe moves the piece exactly 1 block</p>
<p dir="auto">✅ <strong>Hard Drop</strong>: Swipe down to instantly drop the piece to the bottom</p>
<p dir="auto">✅ <strong>Rotation</strong>: Tap anywhere on the screen to rotate the current piece</p>
<p dir="auto">✅ <strong>Sound Effects</strong>:</p>
<li>Move sound when rotating pieces</li>
<li>Clear sound when lines are cleared</li>
<li>Hit sound when pieces land</li>
<p dir="auto">✅ <strong>Auto Fall</strong>: Pieces automatically fall down at increasing speed as level increases</p>
<p dir="auto">✅ <strong>Ghost Piece</strong>: Semi-transparent preview shows where the piece will land</p>
<p dir="auto">✅ <strong>Next Piece Preview</strong>: Always shows what piece is coming next</p>
<h2>Controls Summary</h2>
<thead>
<tr>
<th>Gesture</th>
<th>Action</th>
<th>Notes</th>
</tr>
</thead>
<tbody>
<tr>
<td>← Swipe Left</td>
<td>Move left 1 block</td>
<td>Can swipe continuously while holding</td>
</tr>
<tr>
<td>→ Swipe Right</td>
<td>Move right 1 block</td>
</tr>
<tr>
<td>↓ Swipe Down</td>
<td>Hard drop to bottom</td>
<td>Instantly drops piece</td>
</tr>
<tr>
<td>Tap/Click</td>
<td>Rotate piece</td>
<td>Rotates 90° clockwise</td>
</tr>
</tbody>
</table>
<h2>Download &amp; Burn the Firmware from M5Burner:</h2>
<p dir="auto"><strong>Device Type</strong>: Tab5</p>
<p dir="auto"><strong>Search</strong>: Tetris For M5Stack Tab5</p>
<hr />
<p dir="auto">It's that simple! Enjoy your classic Tetris game! 🎮</p>
]]></description><link>https://community.m5stack.com/topic/7927/tetris-for-tab5</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 21:17:56 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7927.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Dec 2025 14:01:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tetris For Tab5 on Thu, 04 Dec 2025 08:11:17 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1764835872556-tetris2.png" alt="Tetris2.png" class=" img-fluid img-markdown" /><br />
Touch &amp; M5 Stick2 module is also support!<br />
plug M5 Stick2 module  into Port.A<br />
And have fun with you  Stick2 Module Control!</p>
]]></description><link>https://community.m5stack.com/post/30273</link><guid isPermaLink="true">https://community.m5stack.com/post/30273</guid><dc:creator><![CDATA[shmusica]]></dc:creator><pubDate>Thu, 04 Dec 2025 08:11:17 GMT</pubDate></item></channel></rss>
