<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Which external hardware to buy for extend IR range ?]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I'm new.</p>
<p dir="auto">Actually I would like to use TV-B-GONE as feature inside some operative system lyke NEMO, and the function works, I do the test on my TV, but I see that the range of IR is a little bit short and to turn off my tv I need to stay quite close .  Due the fact, I would like to turn off the TV of my parents to joke, I would like to stay more far from their tv , without letting me see.</p>
<p dir="auto">So, my question is:  is there to buy some hardware to put into my M5 stick plus 2 to extend IR range?<br />
thanks</p>
]]></description><link>https://community.m5stack.com/topic/7894/which-external-hardware-to-buy-for-extend-ir-range</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 07:31:03 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7894.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 16 Nov 2025 19:24:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Which external hardware to buy for extend IR range ? on Mon, 24 Nov 2025 11:54:35 GMT]]></title><description><![CDATA[<p dir="auto">To extend the IR range on an M5Stack, the best approach is to use a high-power IR LED paired with a transistor or MOSFET driver to safely handle higher current. Adding a lens or collimator can also help focus the beam for much greater distance and accuracy, and ensuring the signal is properly modulated (like 38 kHz) will improve compatibility with most IR receivers. Just make sure your power supply can support the increased draw from stronger hardware. If you share your budget and required range, I can suggest specific components.</p>
]]></description><link>https://community.m5stack.com/post/30229</link><guid isPermaLink="true">https://community.m5stack.com/post/30229</guid><dc:creator><![CDATA[LukeMathew456]]></dc:creator><pubDate>Mon, 24 Nov 2025 11:54:35 GMT</pubDate></item><item><title><![CDATA[Reply to Which external hardware to buy for extend IR range ? on Sat, 22 Nov 2025 10:34:29 GMT]]></title><description><![CDATA[<p dir="auto">If you just need stronger and more reliable IR output, the easiest option is to add an external IR module like the M5Stack IR Unit, it plugs right into the Grove port and gives a much better range than the built-in LED on the M5StickC Plus 2. Some users also pair it with a simple IR booster circuit for even more distance.</p>
<p dir="auto">You might find this related discussion helpful too, since it covers ways to improve IR performance on M5 devices: <a href="https://community.m5stack.com/topic/1429/m5stickc-improve-ir-range">https://community.m5stack.com/topic/1429/</a><a href="https://estateagentsdagenham.co.uk/" target="_blank" rel="noopener noreferrer nofollow ugc">real estate dagenham</a><a href="https://community.m5stack.com/topic/1429/m5stickc-improve-ir-range">-m5stickc-improve-ir-range</a></p>
]]></description><link>https://community.m5stack.com/post/30223</link><guid isPermaLink="true">https://community.m5stack.com/post/30223</guid><dc:creator><![CDATA[carlbidwell]]></dc:creator><pubDate>Sat, 22 Nov 2025 10:34:29 GMT</pubDate></item><item><title><![CDATA[Reply to Which external hardware to buy for extend IR range ? on Wed, 19 Nov 2025 19:50:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mattewwade06" aria-label="Profile: mattewwade06">@<bdi>mattewwade06</bdi></a> thanks</p>
]]></description><link>https://community.m5stack.com/post/30211</link><guid isPermaLink="true">https://community.m5stack.com/post/30211</guid><dc:creator><![CDATA[conradsm]]></dc:creator><pubDate>Wed, 19 Nov 2025 19:50:19 GMT</pubDate></item><item><title><![CDATA[Reply to Which external hardware to buy for extend IR range ? on Wed, 19 Nov 2025 14:21:41 GMT]]></title><description><![CDATA[<p dir="auto">A stronger IR LED or a small IR amplifier module usually does the trick if you need more range. The built-in IR on M5Stack devices is quite limited, so adding an external high-power emitter and driving it with a proper transistor or driver board can noticeably increase distance. Just make sure the angle and alignment are good, because IR range often depends as much on direction as on power.</p>
]]></description><link>https://community.m5stack.com/post/30206</link><guid isPermaLink="true">https://community.m5stack.com/post/30206</guid><dc:creator><![CDATA[mattewwade06]]></dc:creator><pubDate>Wed, 19 Nov 2025 14:21:41 GMT</pubDate></item><item><title><![CDATA[Reply to Which external hardware to buy for extend IR range ? on Tue, 18 Nov 2025 18:50:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yuyun2000" aria-label="Profile: yuyun2000">@<bdi>yuyun2000</bdi></a> Thank you very much.</p>
<p dir="auto">For sure for the first I buy the Unit IR .</p>
<p dir="auto">But if I would build the option n.3 I have not understood well if I need to complete both options :</p>
<li>increase led current</li>
<li>Two stage amplification<br />
or only on of them.</li>
]]></description><link>https://community.m5stack.com/post/30203</link><guid isPermaLink="true">https://community.m5stack.com/post/30203</guid><dc:creator><![CDATA[conradsm]]></dc:creator><pubDate>Tue, 18 Nov 2025 18:50:55 GMT</pubDate></item><item><title><![CDATA[Reply to Which external hardware to buy for extend IR range ? on Tue, 18 Nov 2025 03:00:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/conradsm" aria-label="Profile: conradsm">@<bdi>conradsm</bdi></a> To extend the IR range of your M5StickC Plus2 for TV control, here are the recommended hardware solutions based on official specifications and technical designs:</p>
<h3><strong>1. Official Recommended Solution: M5Stack Unit IR Module</strong></h3>
<p dir="auto">The <strong>M5Stack Unit IR</strong> (infrared expansion module) is the most straightforward option. It integrates a transistor-based current amplification circuit to boost IR signal strength.</p>
<p dir="auto"><strong>Key Advantages</strong>:</p>
<li><strong>Plug-and-play</strong>: Connects via the Grove interface (HY2.0-4P port) on M5StickC Plus2.</li>
<li><strong>Amplified发射设计</strong>: Uses an S8050 NPN transistor to amplify current, driving the IR LED with higher power than the built-in GPIO alone.</li>
<li><strong>Proven Compatibility</strong>: Works seamlessly with M5StickC Plus2, requiring minimal wiring (only 4 pins: GND, 5V, IR_TX, IR_RX).</li>
<p dir="auto"><strong>Expected Range</strong>: When used with Unit IR, the effective distance typically exceeds 5 meters (based on similar configurations like the BugC2 base test results of 5.6 meters at 180° angle).</p>
<h3><strong>2. Alternative: BugC2 Robot Base (SKU:K033-C)</strong></h3>
<p dir="auto">If you need both IR range extension and mobility, the <strong>BugC2 base</strong> (a robot chassis for M5StickC Plus2) includes optimized IR hardware:</p>
<li>Integrates an SL0038GD IR receiver and enhanced发射电路.</li>
<li><strong>Tested Range</strong>: Up to 5.6 meters (180° angle) when paired with StickC Plus2, which meets your "long-distance TV control" requirement.</li>
<h3><strong>3. DIY Enhancement (For Advanced Users)</strong></h3>
<p dir="auto">If you prefer a custom solution, you can modify the IR circuit based on M5Stack’s reference designs:</p>
<li><strong>Increase LED Current</strong>: Replace the built-in 100Ω current-limiting resistor with a smaller value (e.g., 10-50Ω) to boost IR LED power (ensure the LED’s maximum current rating is not exceeded).</li>
<li><strong>Two-Stage Amplification</strong>: Use a MOSFET (e.g., AO3401A) alongside a transistor (like the M5GO Bottom base design) for higher power output.</li>
<p dir="auto"><strong>Connection Notes</strong>:</p>
<li>Use GPIO19 (shared with the built-in red LED) to control the external IR circuit.</li>
<li>Power the external circuit via the Grove interface’s 5V pin (requires USB or external battery for stable 5V supply).</li>
<h3><strong>Summary of Recommendations</strong></h3>
<table class="table table-bordered table-striped">
<thead>
<tr>
<th>Solution</th>
<th>Complexity</th>
<th>Estimated Range</th>
<th>Best For</th>
</tr>
</thead>
<tbody>
<tr>
<td>M5Stack Unit IR Module</td>
<td>Easy</td>
<td>5-6 meters</td>
<td>Plug-and-play extension</td>
</tr>
<tr>
<td>BugC2 Base (SKU:K033-C)</td>
<td>Moderate</td>
<td>5.6 meters</td>
<td>Mobile + long-range operation</td>
</tr>
<tr>
<td>DIY Circuit</td>
<td>Advanced</td>
<td>6+ meters</td>
<td>Custom power optimization</td>
</tr>
</tbody>
</table>
<p dir="auto">All these options should resolve your short-range issue. The <strong>Unit IR module</strong> is the simplest and most cost-effective choice for standalone range extension. Let me know if you need help with wiring diagrams or code adjustments!</p>
<p dir="auto"><a href="https://chat.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://chat.m5stack.com/</a></p>
]]></description><link>https://community.m5stack.com/post/30198</link><guid isPermaLink="true">https://community.m5stack.com/post/30198</guid><dc:creator><![CDATA[yuyun2000]]></dc:creator><pubDate>Tue, 18 Nov 2025 03:00:17 GMT</pubDate></item></channel></rss>
