<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AirQuality v1.1 restarts roughly every minute]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">I recently got my hands on an AirQuality v1.1 together with the Stamp S3A. I went through the quick start guide, and tried connecting it up to WiFi, but it seems to reset itself every minute. When this happens there is a bleep sound, and the screen flashes black. This regular bleeping makes it not particularly desirable to have in my living environment.</p>
<p dir="auto">I've noticed a few things:</p>
<li>The temperature readings seem to be much higher than the actual temperature. Some other posts mention this for other air quality meters, and it is not a must for my project</li>
<li>I am powering the device via the USB C cable on the Stamp board. Is this a problem, or should it be charged via the 5Vin pin?</li>
<p dir="auto">I asked the GPT for M5Stack, and it recommended flashing the firmware using M5Burner to ensure its not a corrupted firmware issue. Is this really a likely cause (out of the box), and if so which firmware should I flash?</p>
<p dir="auto">All the best,<br />
Kforjf</p>
]]></description><link>https://community.m5stack.com/topic/7881/airquality-v1-1-restarts-roughly-every-minute</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 01:50:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7881.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Nov 2025 18:36:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AirQuality v1.1 restarts roughly every minute on Mon, 10 Nov 2025 08:20:29 GMT]]></title><description><![CDATA[<p dir="auto">you can disable sound and adjust timer, 60s for reset is default it does flash black like many ink displays</p>
]]></description><link>https://community.m5stack.com/post/30154</link><guid isPermaLink="true">https://community.m5stack.com/post/30154</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 10 Nov 2025 08:20:29 GMT</pubDate></item></channel></rss>
