<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow2.0 Tab5]]></title><description><![CDATA[<p dir="auto">Since the last 2 updates I can not get any thing to work on PortA. Relays, Lights any sensors. If I go back 2 updates and burn it, it all works fine.<br />
Did something change?</p>
]]></description><link>https://community.m5stack.com/topic/7829/uiflow2-0-tab5</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 05:38:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7829.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Sep 2025 14:06:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Mon, 03 Nov 2025 08:55:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> said in <a href="/post/29970">UIFlow2.0 Tab5</a>:</p>
<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/handcannon" aria-label="Profile: Handcannon">@<bdi>Handcannon</bdi></a></p>
<p dir="auto">yes, I see that too. It seems that the latest versions (2.3.5 and 2.3.6) have power to port A disabled. E.g. port A has no power.</p>
<p dir="auto">Please find my example in the UIFlow2 Project Zone which manually turns on power to port A: <em>M5Tab5_Enable_Ext5V_EnvIV_Test_UIFlow2.3.6</em></p>
<p dir="auto">I created an <a href="https://github.com/m5stack/uiflow-micropython/issues/63" target="_blank" rel="noopener noreferrer nofollow ugc">issue</a> on github for this issue.</p>
<p dir="auto">I tried recreating your M5Tab5 script for the Core 2 and got these results:<br />
(I realise that the RGB Unit doesn't use I2C but for port A to work I think I need to set it up in the same way anyway.)<br />
The code:</p>
<pre><code>import os, sys, io
import M5
from M5 import *
import m5ui
import lvgl as lv
from unit import RGBUnit
from hardware import I2C
from hardware import Pin
import time
page0 = None
switch0 = None
i2c0 = None
rgb_0 = None
bytearrayone = None
def setup():
  global page0, switch0, i2c0, rgb_0, bytearrayone
  M5.begin()
  Widgets.setRotation(1)
  m5ui.init()
  page0 = m5ui.M5Page(bg_c=0xffffff)
  switch0 = m5ui.M5Switch(x=130, y=105, w=60, h=30, bg_c=0xe7e3e7, bg_c_checked=0x2196f3, circle_c=0xffffff, parent=page0)
  page0.screen_load()
  bytearrayone = bytearray(1)
  i2c0 = I2C(0, scl=Pin(33), sda=Pin(32), freq=100000)
  i2c0.readfrom_mem_into(0x43, 0x03, bytearrayone)
  # set PI4IO P2 (Ext5V enable) as output
  print(hex(myByteArr[0]))
  myByteArr[0] |= 0x04
  i2c0.writeto_mem(0x43, 0x03, bytearrayone)
  i2c0.readfrom_mem_into(0x43, 0x05, bytearrayone)
  # set PI4IO P2 (Ext5V enable) to high
  i2c0.writeto_mem(0x43, 0x05, bytearrayone)
  time.sleep(1)
  rgb_0 = RGBUnit((33, 32), 3)
def loop():
  M5.update()
  rgb_0.set_brightness(100)
  if switch0.has_state(lv.STATE.CHECKED):
    rgb_0.set_color(0, 0x6600cc)
  else:
    rgb_0.set_color(0, 0x000000)
if __name__ == '__main__':
  try:
    setup()
    while True:
      loop()
    try:
      m5ui.deinit()
      print_error_msg(e)
    except ImportError:
<p dir="auto">1st attempt:</p>
<pre><code>E (725096) i2c: i2c driver install error
E (725128) i2c: i2c driver install error
E (725275) i2c: i2c driver install error
  File "&lt;stdin&gt;", line 49, in &lt;module&gt;
  File "&lt;stdin&gt;", line 25, in setup
OSError: [Errno 116] ETIMEDOUT
<p dir="auto">2nd attempt:</p>
<pre><code>E (740623) i2c: i2c driver install error
E (740655) i2c: i2c driver install error
A fatal error occurred. The crash dump printed below may be used to help
determine what caused it. If you are not already running the most recent
version of MicroPython, consider upgrading. New versions often fix bugs.
To learn more about how to debug and/or report this crash visit the wiki
page at: https://github.com/micropython/micropython/wiki/ESP32-debugging
MPY version : v1.25.0-dirty on 2025-09-30
IDF version : v5.4.2-dirty
Machine     : M5STACK Core2 with ESP32(SPIRAM)
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x40166a09  PS      : 0x00060730  A0      : 0x800dc068  A1      : 0x3ffd92f0
A2      : 0x00000000  A3      : 0x3f4329e7  A4      : 0x00000000  A5      : 0x00000000
A6      : 0x00000001  A7      : 0x3ffd92f0  A8      : 0x00000074  A9      : 0x3ffc1090
A10     : 0x00000000  A11     : 0x3ffd94b0  A12     : 0x00000000  A13     : 0x00000001
A14     : 0x00000000  A15     : 0x00000004  SAR     : 0x00000020  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000088  LBEG    : 0x400945b2  LEND    : 0x400945bd  LCOUNT  : 0x00000000
Backtrace: 0x40166a06:0x3ffd92f0 0x400dc065:0x3ffd9330 0x400f5729:0x3ffd9350 0x400dc46d:0x3ffd9390 0x401ec3f5:0x3ffd93d0 0x401ec4bf:0x3ffd93f0 0x40087c62:0x3ffd9410 0x401e65a8:0x3ffd94b0 0x401ec3f5:0x3ffd9510 0x402161ac:0x3ffd9530 0x402161e9:0x3ffd9570 0x401ec3f5:0x3ffd9590 0x401ec479:0x3ffd95b0 0x402187a4:0x3ffd95e0 0x401ed36c:0x3ffd9660 0x4008739e:0x3ffd9680 0x401e65a8:0x3ffd9720 0x401ec3f5:0x3ffd9770 0x401ec4bf:0x3ffd9790 0x40087c62:0x3ffd97b0 0x401e65a8:0x3ffd9850 0x401ec3f5:0x3ffd9880 0x401ec40e:0x3ffd98a0 0x4021bbf6:0x3ffd98c0 0x4021beda:0x3ffd9950 0x401fde08:0x3ffd9990
ELF file SHA256: 1843f6d45
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:4340
load:0x40078000,len:15972
load:0x40080400,len:4
ho 8 tail 4 room 4
load:0x40080404,len:3656
entry 0x400805c0
       _  __ _
 _   _(_)/ _| | _____      __
| | | | | |_| |/ _ \ \ /\ / /
| |_| | |  _| | (_) \ V  V /
 \__,_|_|_| |_|\___/ \_/\_/  V2.3.6-hotfix2
E (2840) i2c: i2c driver install error
]]></description><link>https://community.m5stack.com/post/30123</link><guid isPermaLink="true">https://community.m5stack.com/post/30123</guid><dc:creator><![CDATA[RPI25]]></dc:creator><pubDate>Mon, 03 Nov 2025 08:55:00 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Mon, 03 Nov 2025 08:40:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
Ok I can now confirm that Core 2 V2.3.6 hotfix doesn't power port A so I am going back to V2.3.5 to check that - I think it still works.<br />
Core 2:<br />
V2.3.7 - Doesn't power port A (if that is the problem)<br />
V2.3.6 hotfix - Doesn't power port A (if that is the problem)<br />
V2.3.6 - Doesn't power port A (if that is the problem)</p>
]]></description><link>https://community.m5stack.com/post/30124</link><guid isPermaLink="true">https://community.m5stack.com/post/30124</guid><dc:creator><![CDATA[RPI25]]></dc:creator><pubDate>Mon, 03 Nov 2025 08:40:49 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Mon, 03 Nov 2025 08:32:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
I was having the same issue with my Core 2 not powering Port A but my Nano C6 still works on V2.3.7 if that helps.<br />
The screen, UI etc work on the Core 2 but the Port A just doesn't do anything.<br />
Thanks.</p>
]]></description><link>https://community.m5stack.com/post/30125</link><guid isPermaLink="true">https://community.m5stack.com/post/30125</guid><dc:creator><![CDATA[RPI25]]></dc:creator><pubDate>Mon, 03 Nov 2025 08:32:46 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Mon, 03 Nov 2025 06:57:33 GMT]]></title><description><![CDATA[<p dir="auto">When I flash back the demo, it works perfectly. Programs transferred with the Arduino IDE also work, only UIFlow 2 doesn't.</p>
]]></description><link>https://community.m5stack.com/post/30115</link><guid isPermaLink="true">https://community.m5stack.com/post/30115</guid><dc:creator><![CDATA[Tandu]]></dc:creator><pubDate>Mon, 03 Nov 2025 06:57:33 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Sun, 02 Nov 2025 14:09:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi everyone, I flashed UIFlow 2.3.7 onto my Tab 5 using mburner. Afterwards, it starts up and the backlight is on. I can also access it from UIFlow via USB and Wi-Fi. However, it doesn't launch any programs after the successful transfer. What could be the problem? Nothing seems to be happening on the Tab 5. Thanks, Thomas</p>
]]></description><link>https://community.m5stack.com/post/30114</link><guid isPermaLink="true">https://community.m5stack.com/post/30114</guid><dc:creator><![CDATA[Tandu]]></dc:creator><pubDate>Sun, 02 Nov 2025 14:09:15 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Fri, 17 Oct 2025 10:20:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/handcannon" aria-label="Profile: Handcannon">@<bdi>Handcannon</bdi></a> UiFlow2 is not responding when I press "RUN" after upgrade to v2.3.6 hotfix2. Any idea why it happens? Thank you!</p>
]]></description><link>https://community.m5stack.com/post/30065</link><guid isPermaLink="true">https://community.m5stack.com/post/30065</guid><dc:creator><![CDATA[KaiWWW]]></dc:creator><pubDate>Fri, 17 Oct 2025 10:20:19 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Fri, 26 Sep 2025 07:47:27 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/handcannon" aria-label="Profile: Handcannon">@<bdi>Handcannon</bdi></a></p>
<p dir="auto">M5Tab5 UIFlow v2.3.6-<strong>hotfix</strong> solves the no power on port A issue.</p>
]]></description><link>https://community.m5stack.com/post/30003</link><guid isPermaLink="true">https://community.m5stack.com/post/30003</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 26 Sep 2025 07:47:27 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Sun, 21 Sep 2025 14:58:53 GMT]]></title><description><![CDATA[<p dir="auto">Tab5 still will not load and run a App from the menu. Any M5UI Apps I have in the menu list. Apps that have been made only in M5GFX will load and run from the Apps list menu. Any thoughts. Thanks in advance.</p>
]]></description><link>https://community.m5stack.com/post/29979</link><guid isPermaLink="true">https://community.m5stack.com/post/29979</guid><dc:creator><![CDATA[Handcannon]]></dc:creator><pubDate>Sun, 21 Sep 2025 14:58:53 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Sun, 21 Sep 2025 13:57:48 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, that worked awesome. Good news I was half right in trying to turn it on. Bad news I was just half way right.<br />
Wonder why they turned it off?</p>
]]></description><link>https://community.m5stack.com/post/29978</link><guid isPermaLink="true">https://community.m5stack.com/post/29978</guid><dc:creator><![CDATA[Handcannon]]></dc:creator><pubDate>Sun, 21 Sep 2025 13:57:48 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 Tab5 on Sat, 20 Sep 2025 16:07:16 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/handcannon" aria-label="Profile: Handcannon">@<bdi>Handcannon</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/29970</link><guid isPermaLink="true">https://community.m5stack.com/post/29970</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 20 Sep 2025 16:07:16 GMT</pubDate></item></channel></rss>
