<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TAB5: Unable to mount SD card as USB mass storage]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm trying to get the SD2USBMSC example (<a href="https://github.com/espressif/arduino-esp32/tree/master/libraries/SD_MMC/examples/SD2USBMSC" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/espressif/arduino-esp32/tree/master/libraries/SD_MMC/examples/SD2USBMSC</a>) running on my M5TAB5</p>
<p dir="auto">I have been able to get the same example running on an ESP32-S3 board &amp; now I want to test the High Speed USB of the ESP32-P4 in the Tab5.</p>
<p dir="auto">I have the sketch running on my Tab5 and the SD card appears to be detected &amp; mounted correctly; at run-time I get USB UNPLUGGED reported (ARDUINO_USB_STOPPED_EVENT).</p>
<p dir="auto">I have powered the Tab5 externally via the posts on the battery slot but I do not see events reported for the other USB events:</p>
<li>ARDUINO_USB_STARTED_EVENT</li>
<li>ARDUINO_USB_SUSPEND_EVENT</li>
<li>ARDUINO_USB_RESUME_EVENT</li>
<p dir="auto">Below is the log from the device</p>
<pre><code>EESP-ROM:esp32p4-eco2-20240710
Build:Jul 10 2024
rst:0x1 (POWERON),boot:0x20f (SPI_FAST_FLASH_BOOT)
SPI mode:DIO, clock div:1
load:0x4ff33ce0,len:0x118c
load:0x4ff2abd0,len:0xcd0
load:0x4ff2cbd0,len:0x3304
entry 0x4ff2abd0
Build:Jul 10 2024
rst:0x7 (HP_SYS_HP_WDT_RESET),boot:0x20f (SPI_FAST_FLASH_BOOT)
entry 0x4ff2abd0
[     1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
[    12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
[    23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
[    35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
[    46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
[    57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
[    68][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
[    80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
[    91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
[   102][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
[   114][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
[   125][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
[   136][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
[   147][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
[   159][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
[   170][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
[   181][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
[   193][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
[   204][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
[   215][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
[   226][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x400138a8
[   238][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x40013866
[   249][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x40013824
[   260][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x400137e2
[   272][D][esp32-hal-tinyusb.c:806] tinyusb_enable_interface2(): Interface MSC enabled
[   286][I][esp32-hal-psram.c:102] psramAddToHeap(): PSRAM added to the heap.
[   297][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 38 successfully set to type UART_RX (2) with bus 0x4ff11048
[   308][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 37 successfully set to type UART_TX (3) with bus 0x4ff11048
=========== Before Setup Start ===========
Chip Info:
  Model             : ESP32-P4
  Package           : 0
  Revision          : 1.00
  Cores             : 2
  CPU Frequency     : 360 MHz
  XTAL Frequency    : 40 MHz
  Features Bitfield : 0000000000
  Embedded Flash    : No
  Embedded PSRAM    : No
  2.4GHz WiFi       : No
  Classic BT        : No
  BT Low Energy     : No
  IEEE 802.15.4     : No
INTERNAL Memory Info:
  Total Size        :   572780 B ( 559.4 KB)
  Free Bytes        :   544996 B ( 532.2 KB)
  Allocated Bytes   :    21964 B (  21.4 KB)
  Minimum Free Bytes:   540020 B ( 527.4 KB)
  Largest Free Block:   385012 B ( 376.0 KB)
SPIRAM Memory Info:
  Total Size        : 33554432 B (32768.0 KB)
  Free Bytes        : 33551856 B (32765.5 KB)
  Allocated Bytes   :        0 B (   0.0 KB)
  Minimum Free Bytes: 33551856 B (32765.5 KB)
  Largest Free Block: 33030132 B (32256.0 KB)
  Bus Mode          : QSPI
Flash Info:
  Chip Size         : 16777216 B (16 MB)
  Block Size        :    65536 B (  64.0 KB)
  Sector Size       :     4096 B (   4.0 KB)
  Page Size         :      256 B (   0.2 KB)
  Bus Speed         : 80 MHz
  Bus Mode          : QIO
Partitions Info:
                nvs : addr: 0x00009000, size:    20.0 KB, type: DATA, subtype: NVS
            otadata : addr: 0x0000E000, size:     8.0 KB, type: DATA, subtype: OTA
               app0 : addr: 0x00010000, size:  6400.0 KB, type:  APP, subtype: OTA_0
               app1 : addr: 0x00650000, size:  6400.0 KB, type:  APP, subtype: OTA_1
             spiffs : addr: 0x00C90000, size:  3456.0 KB, type: DATA, subtype: SPIFFS
           coredump : addr: 0x00FF0000, size:    64.0 KB, type: DATA, subtype: COREDUMP
Software Info:
  Compile Date/Time : Sep 10 2025 11:23:03
  Compile Host OS   : windows
  ESP-IDF Version   : v5.4.2-25-g858a988d6e
  Arduino Version   : 3.2.1
Board Info:
  Arduino Board     : M5STACK_TAB5
  Arduino Variant   : m5stack_tab5
  Arduino FQBN      : m5stack:esp32:m5stack_tab5:UploadSpeed=921600,USBMode=default,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=360,FlashFreq=80,FlashMode=qio,FlashSize=16M,PartitionScheme=default,DebugLevel=verbose,PSRAM=enabled,EraseFlash=none,JTAGAdapter=builtin
============ Before Setup End ============
[   673][V][esp32-hal-uart.c:676] uartBegin(): UART0 baud(115200) Mode(800001c) rxPin(38) txPin(37)
[   682][V][esp32-hal-uart.c:774] uartBegin(): UART0 not installed. Starting installation
[   690][V][esp32-hal-uart.c:784] uartBegin(): UART0 RX FIFO full threshold set to 120 (value requested: 120 || FIFO Max = 128)
[   701][V][esp32-hal-uart.c:810] uartBegin(): Setting UART0 to use XTAL clock
[   709][V][esp32-hal-uart.c:874] uartBegin(): UART0 initialization done.
[   715][V][esp32-hal-uart.c:925] uartSetRxFIFOFull(): UART0 RX FIFO Full value set to 120 from a requested value of 120
Starting Serial
Mounting SDcard
[   726][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type SDMMC_CLK (38) successfully set to 0x4000b840
[   740][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type SDMMC_CMD (39) successfully set to 0x4000b840
[   752][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type SDMMC_D0 (40) successfully set to 0x4000b840
[   763][D][SD_MMC.cpp:188] begin(): pin_cmd: 44, pin_clk: 43, pin_d0: 39, pin_d1: 40, pin_d2: 41, pin_d3: 42
[   773][I][SD_MMC.cpp:252] begin(): On-chip power channel specified, use external power for SDMMC
[   846][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 44 successfully set to type SDMMC_CMD (39) with bus 0x4ff142f8
[   857][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 43 successfully set to type SDMMC_CLK (38) with bus 0x4ff142f8
[   868][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 39 successfully set to type SDMMC_D0 (40) with bus 0x4ff142f8
Initializing MSC
Initializing USB
[   879][D][esp32-hal-tinyusb.c:684] tinyusb_load_enabled_interfaces(): Load Done: if_num: 1, descr_len: 32, if_mask: 0x1
Card Size: 7447MB
                 Sector: 512    Count: 15251456
                                               =========== After Setup Start ============
USB UNPLUGGED
  Free Bytes        :   538448 B ( 525.8 KB)
  Allocated Bytes   :    28064 B (  27.4 KB)
  Minimum Free Bytes:   538428 B ( 525.8 KB)
SPIRAM Memory Info:
  Free Bytes        : 33520032 B (32734.4 KB)
  Allocated Bytes   :    31584 B (  30.8 KB)
  Minimum Free Bytes: 33520032 B (32734.4 KB)
GPIO Info:
  GPIO : BUS_TYPE[bus/unit][chan]
    37 : UART_TX[0]
    38 : UART_RX[0]
    39 : SDMMC_D0
    43 : SDMMC_CLK
    44 : SDMMC_CMD
============ After Setup End =============
<p dir="auto">Has anyone had any luck (or problems) with getting this working on the Tab5 device?</p>
<p dir="auto">Appreciate any help/direction...</p>
]]></description><link>https://community.m5stack.com/topic/7822/tab5-unable-to-mount-sd-card-as-usb-mass-storage</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 23:38:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7822.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Sep 2025 07:37:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TAB5: Unable to mount SD card as USB mass storage on Thu, 06 Nov 2025 03:02:47 GMT]]></title><description><![CDATA[<p dir="auto">Using this example is fine.</p>
<p dir="auto"><a href="https://github.com/espressif/esp-idf/tree/master/examples/peripherals/usb/device/tusb_msc" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/espressif/esp-idf/tree/master/examples/peripherals/usb/device/tusb_msc</a></p>
<p dir="auto">sdkconfig.defaults</p>
<pre><code># This file was generated using idf.py save-defconfig. It can be edited manually.
# Espressif IoT Development Framework (ESP-IDF) 5.5.1 Project Minimal Configuration
CONFIG_IDF_TARGET="esp32p4"
CONFIG_ESPTOOLPY_FLASHSIZE_4MB=y
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_EXAMPLE_STORAGE_MEDIA_SDMMC=y
CONFIG_EXAMPLE_SD_PWR_CTRL_LDO_INTERNAL_IO=n
CONFIG_ESP_CONSOLE_USB_SERIAL_JTAG=y
CONFIG_FATFS_LFN_HEAP=y
CONFIG_WL_SECTOR_SIZE_512=y
CONFIG_WL_SECTOR_MODE_PERF=y
CONFIG_TINYUSB_MSC_ENABLED=y
]]></description><link>https://community.m5stack.com/post/30139</link><guid isPermaLink="true">https://community.m5stack.com/post/30139</guid><dc:creator><![CDATA[tinyu806]]></dc:creator><pubDate>Thu, 06 Nov 2025 03:02:47 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5: Unable to mount SD card as USB mass storage on Fri, 31 Oct 2025 15:05:15 GMT]]></title><description><![CDATA[<p dir="auto">I'm having the same issue with my Tab5, when I try USBMSC or SD2USBMSC examples in Arduino IDE they upload fine but I don't get a usb device on my computer. I did notice in the serial monitor that it says USB-Serial/JTAG, even though I changed the settings under tools, following this fellows video:<br />
<a href="https://www.youtube.com/watch?v=hJSBTFsOnoA" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=hJSBTFsOnoA</a><br />
He's using a ESP32-S3 and it seems to work fine. One thing I did discover in the ESP32-P4 docs is that it needs the strapping pins set in order to get the chip in Joint download mode:<br />
<a href="https://docs.espressif.com/projects/esp-hardware-design-guidelines/en/latest/esp32p4/schematic-checklist-esp32p4.html#schematic-checklist-strapping-pins" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.espressif.com/projects/esp-hardware-design-guidelines/en/latest/esp32p4/schematic-checklist-esp32p4.html#schematic-checklist-strapping-pins</a><br />
It also can share the same lines for USB:<br />
<a href="https://docs.espressif.com/projects/esp-hardware-design-guidelines/en/latest/esp32p4/schematic-checklist-esp32p4.html#usb" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.espressif.com/projects/esp-hardware-design-guidelines/en/latest/esp32p4/schematic-checklist-esp32p4.html#usb</a><br />
I think the usb-c might be connected to both sets of lines and the pins are not set correctly to select joint download mode. I couldn't really determine this in the schematics provided by M5 as they are confusing but I think they need to provide separate examples and libraries for the ESP32-P4 as it is quite different from the ESP32-S3</p>
]]></description><link>https://community.m5stack.com/post/30107</link><guid isPermaLink="true">https://community.m5stack.com/post/30107</guid><dc:creator><![CDATA[rkirchne]]></dc:creator><pubDate>Fri, 31 Oct 2025 15:05:15 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5: Unable to mount SD card as USB mass storage on Tue, 23 Sep 2025 07:53:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/346865">@henryCharm</a></p>
<p dir="auto">Thanks for the feedback.</p>
<p dir="auto">I have tried several examples from both the Arduino &amp; IDF (both updated to the latest) and none of them seem to expose the Tab5 as a usb device:</p>
<li>USB Keyboard &amp; Mouse examples</li>
<li>USB Custom HID device</li>
<li>USBMSC example</li>
<li>USB Serial example</li>
<p dir="auto">I can get similar projects working on my ESP32-S3 device without issue..</p>
<p dir="auto">I'm wondering if anyone has a working example of the Tab5 enumerating as a USB device?</p>
]]></description><link>https://community.m5stack.com/post/29988</link><guid isPermaLink="true">https://community.m5stack.com/post/29988</guid><dc:creator><![CDATA[vitalEOL]]></dc:creator><pubDate>Tue, 23 Sep 2025 07:53:47 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5: Unable to mount SD card as USB mass storage on Tue, 16 Sep 2025 12:49:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">From what you described and the logs, it looks like the SD card is being detected and mounted correctly, but the USB MSC interface reports USB UNPLUGGED (ARDUINO_USB_STOPPED_EVENT). This usually means the USB host (e.g., your PC) is not recognizing the device as connected or the USB device stack on the ESP32-P4 isn’t properly signaling a connection.</p>
<p dir="auto">check:</p>
<li>
<p dir="auto">Make sure the USB data lines (D+ and D-) and power (VBUS) are hooked up right. If you’re just powering through the battery spots without the USB power line, the computer might think the device is unplugged.</p>
</li>
<li>
<p dir="auto">Check that the USB Mass Storage mode is turned on in your code and board settings.</p>
</li>
<li>
<p dir="auto">Use the latest ESP32-P4 USB support in Arduino or ESP-IDF. Sometimes the USB stuff on this chip can be a bit tricky.</p>
</li>
<li>
<p dir="auto">If you don’t see USB started or resume messages, the USB connection might not be working properly or the computer isn’t recognizing the device.</p>
</li>
<li>
<p dir="auto">Run a basic USB example (like USB serial or simple storage) to see if USB itself works, without the SD card part.</p>
</li>
<li>
<p dir="auto">Make sure the pins for SD card and USB don’t clash with each other or other parts.</p>
</li>
<p dir="auto">this is all I can think off</p>
]]></description><link>https://community.m5stack.com/post/29973</link><guid isPermaLink="true">https://community.m5stack.com/post/29973</guid><dc:creator><![CDATA[henryCharm]]></dc:creator><pubDate>Tue, 16 Sep 2025 12:49:39 GMT</pubDate></item></channel></rss>
