<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickcCPlus: Microphone not working]]></title><description><![CDATA[<p dir="auto">Hello everyone,<br />
It's been 2 weeks I'm trying to configure the microphone on M5stickCplus 1.1</p>
<p dir="auto">Here is the sample code I'm using<br />
I believe that the module has a built-in microphone.</p>
<p dir="auto">As output of this code, only 0 is displayed.</p>
<p dir="auto">Can someone please help me out 🙏?</p>
<pre><code>
#include &lt;M5StickCPlus.h&gt;
#include &lt;driver/i2s.h&gt;
#define SAMPLE_RATE 16000
#define SAMPLES 256
  M5.begin();
  Serial.begin(115200);
  // I2S config
  i2s_config_t i2s_config = {
      .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX),
      .sample_rate = SAMPLE_RATE,
      .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
      .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
      .communication_format = I2S_COMM_FORMAT_I2S,
      .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
      .dma_buf_count = 8,
      .dma_buf_len = 64,
      .use_apll = false,
  i2s_pin_config_t pin_config = {
      .bck_io_num = 0,
      .ws_io_num = 34,
      .data_out_num = I2S_PIN_NO_CHANGE,
      .data_in_num = 32
  i2s_driver_install(I2S_NUM_0, &amp;i2s_config, 0, NULL);
  i2s_set_pin(I2S_NUM_0, &amp;pin_config);
  Serial.println("Mic test started...");
  int16_t buffer[SAMPLES];
  size_t bytesRead;
  i2s_read(I2S_NUM_0, (char *)buffer, SAMPLES * sizeof(int16_t), &amp;bytesRead, portMAX_DELAY);
  // Print a few samples
  for (int i = 0; i &lt; 10; i++) {
    Serial.println(buffer[i]);
  delay(500);
]]></description><link>https://community.m5stack.com/topic/7794/m5stickccplus-microphone-not-working</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 15:59:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7794.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Sep 2025 07:19:03 GMT</pubDate><ttl>60</ttl></channel></rss>
