<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error)]]></title><description><![CDATA[<p dir="auto">I was trying to test the Tab5 with the M5Stack Tube/Air Pressure Unit sensor (U130).</p>
<p dir="auto">Unfortunately, every time I try to deploy and run a simple program to show the readings from the Tube Pressure sensor using UiFlow v2.3.1 I get a <strong>i2c driver install error</strong> and the program does not load on the Tab5. See attached images...</p>
<p dir="auto">Has anyone had success with using the Tab5 with the Tube Pressure sensor and UiFlow v2.3.1?</p>
<p dir="auto">Thanks!</p>
<p dir="auto"><img src="/assets/uploads/files/1752634316165-tab5andtubepressureerror_1.png" alt="Tab5andTubePressureError_1.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1752634328122-tab5andtubepressureerror_2.png" alt="Tab5andTubePressureError_2.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1752634346474-tab5andtubepressureerror_3.png" alt="Tab5andTubePressureError_3.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1752634360610-tab5andtubepressureerror_4.png" alt="Tab5andTubePressureError_4.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/7688/possible-issue-with-tab5-and-uiflow-v2-3-1-i2c-driver-install-error</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 21:33:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7688.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Jul 2025 02:52:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 12 Aug 2025 15:14:02 GMT]]></title><description><![CDATA[<p dir="auto">Just tested another release of UiFlow (version 2.3.3) for the Tab5... Unfortunately, I am seeing the same results that I saw with Version 2.3.2...   -16Kpa without any air tubes connected to the M5Stack Air Tube sensor... Along with the i2c driver install error...</p>
<p dir="auto">Hopefully M5Stack Team is getting close to resolving the issue... I was planning to use the Tab5 project I was working on for the M5stack Innovation contest but it looks like that will not happen due to the issues I am running into with finding an air tube sensor that will accurately work with the Tab5...  Oh well... Hopefully the M5stack team will release an upgraded Air Tube sensor soon that will easily work with the Tab5...  Until then, I will keep searching for a solution....</p>
]]></description><link>https://community.m5stack.com/post/29736</link><guid isPermaLink="true">https://community.m5stack.com/post/29736</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Tue, 12 Aug 2025 15:14:02 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Thu, 31 Jul 2025 03:54:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/168201">@kuriko</a> Just finished testing the latest release of UiFlow (v2.3.2 ).</p>
<p dir="auto">The Kpa readings was better this time but the accuracy is not there yet... See attached photo.</p>
<p dir="auto">Hopefully the next release will improve the accuracy of the Tube/Air sensor and Tab5...</p>
<p dir="auto"><img src="/assets/uploads/files/1753934057073-voltagereading_2-resized.jpg" alt="VoltageReading_2.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/29669</link><guid isPermaLink="true">https://community.m5stack.com/post/29669</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Thu, 31 Jul 2025 03:54:53 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Sun, 27 Jul 2025 01:31:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/168201">@kuriko</a> Thanks Kuriko for responding and taking a further look into the issue!    Looking forward to testing out the updated version of UiFlow with the fix!</p>
<p dir="auto">I will now wait quietly and patiently while your team works on an ADC fix.</p>
]]></description><link>https://community.m5stack.com/post/29621</link><guid isPermaLink="true">https://community.m5stack.com/post/29621</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Sun, 27 Jul 2025 01:31:29 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Fri, 25 Jul 2025 04:21:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/313293">@Kenzo</a><br />
This is an ADC problem. We are fixing UiFlow2 codes. Please be patient.</p>
]]></description><link>https://community.m5stack.com/post/29608</link><guid isPermaLink="true">https://community.m5stack.com/post/29608</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Fri, 25 Jul 2025 04:21:21 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Thu, 24 Jul 2025 17:23:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5596">@robski</a> I sent an email to M5Stack Support about the possible issue with the Tab5 and Tube Pressure sensor BUT no response so far....</p>
]]></description><link>https://community.m5stack.com/post/29606</link><guid isPermaLink="true">https://community.m5stack.com/post/29606</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Thu, 24 Jul 2025 17:23:50 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 16:43:59 GMT]]></title><description><![CDATA[<p dir="auto">Also here is the formula I was using to calculate Kpa</p>
<p dir="auto">So for <strong>12 bit parameter</strong>, this gives a kpa resolution of 300Kpa/4096 bits or   0.0732421875 kpa/bit (73.2pa/bit)</p>
<p dir="auto">x =  ( (0.0732421875 kpa/bit * Raw Value bit) - 100Kpa)<br />
x = ( (0.0732421875 kpa/bit * 3287 bit) - 100Kpa) = 140.7Kpa</p>
<p dir="auto">For the <strong>16 bit parameter</strong> this gives a kpa resolution of 300Kpa/65536 bits or 0.00457763671875 kpa/bit (4.6pa/bit)</p>
<p dir="auto">x =  ( (0.00457763671875 kpa/bit * Raw Value bit) - 100Kpa)<br />
x = ( (0.00457763671875 kpa/bit * 52600 bit) - 100Kpa) = 140.8Kpa</p>
]]></description><link>https://community.m5stack.com/post/29578</link><guid isPermaLink="true">https://community.m5stack.com/post/29578</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Tue, 22 Jul 2025 16:43:59 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 15:25:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5596">@robski</a> - I think you hit on something there!  I measured the voltage between the ground and the sensor and it came to around 1.1v which according to the graph should be around 0 Kpa. (see attached photos)  Something is definitely strange...</p>
<p dir="auto"><img src="/assets/uploads/files/1753197912557-voltagereading_1.jpg" alt="VoltageReading_1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1753197924169-pressuregraph_1.jpg" alt="PressureGraph_1.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/29575</link><guid isPermaLink="true">https://community.m5stack.com/post/29575</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Tue, 22 Jul 2025 15:25:36 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 14:10:29 GMT]]></title><description><![CDATA[<p dir="auto">just connect voltage to sensor and measure what voltage it is giving out between output pin and ground. for 0 kPa your raw Analog value should be around 1300 i think</p>
]]></description><link>https://community.m5stack.com/post/29574</link><guid isPermaLink="true">https://community.m5stack.com/post/29574</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 22 Jul 2025 14:10:29 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 14:01:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5596">@robski</a> I keep coming up with 140Kpa also...<br />
We must be missing something...</p>
]]></description><link>https://community.m5stack.com/post/29573</link><guid isPermaLink="true">https://community.m5stack.com/post/29573</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Tue, 22 Jul 2025 14:01:17 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 13:40:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5596">@robski</a> - hmmm.... Well that raw value was with nothing connected to the Tube Pressor sensor.  Because nothing is connected to the tube pressure sensor I would assume it would be closer to 0 Kpa...   140Kpa is a big difference from 0 Kpa...  I wonder what we are missing?</p>
]]></description><link>https://community.m5stack.com/post/29572</link><guid isPermaLink="true">https://community.m5stack.com/post/29572</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Tue, 22 Jul 2025 13:40:59 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 13:18:23 GMT]]></title><description><![CDATA[<p dir="auto">with your raw value as 3287<br />
sensor range  -100 to  200<br />
analog range 0 to 4095</p>
<p dir="auto">your calculated pressure should be around 140</p>
]]></description><link>https://community.m5stack.com/post/29571</link><guid isPermaLink="true">https://community.m5stack.com/post/29571</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 22 Jul 2025 13:18:23 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 12:53:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5596">@robski</a> - I stumbled across this youtube video about an Arduino Pressure Sensor and was thinking about testing a version of his method for coming up with a calculation...</p>
<p dir="auto"><a href="https://youtu.be/UrqPxwsPWGk?si=4Ho9CQwpoFZstMBk&amp;t=321" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/UrqPxwsPWGk?si=4Ho9CQwpoFZstMBk&amp;t=321</a></p>
]]></description><link>https://community.m5stack.com/post/29570</link><guid isPermaLink="true">https://community.m5stack.com/post/29570</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Tue, 22 Jul 2025 12:53:35 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 12:47:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5596">@robski</a> Thanks for replying!  With nothing connected to the Tube pressure sensor, I am getting a RAW value of <strong>3,287</strong> (12 bit option selected in the ADC parameter).</p>
<p dir="auto">In regards to a 3.6V reference, where is that in the documentation?</p>
<p dir="auto"><img src="/assets/uploads/files/1753188380098-rangespan_1.jpg" alt="RangeSpan_1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I think we are getting close to solving this problem!</p>
]]></description><link>https://community.m5stack.com/post/29569</link><guid isPermaLink="true">https://community.m5stack.com/post/29569</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Tue, 22 Jul 2025 12:47:56 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 12:18:16 GMT]]></title><description><![CDATA[<p dir="auto">what are RAW values you are getting from your sensor? pure analog read value?</p>
<p dir="auto">try below</p>
<p dir="auto">float raw = analogRead(sensorPin);  // Read analog value<br />
float Vout = raw / 4095.0 * 3.6;    // Convert to voltage (assuming 3.6V reference)<br />
float P = (Vout - 0.1) / 3.0 * 300.0 - 100.0;  // Calculate pressure in kPa</p>
]]></description><link>https://community.m5stack.com/post/29567</link><guid isPermaLink="true">https://community.m5stack.com/post/29567</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 22 Jul 2025 12:18:16 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 12:12:17 GMT]]></title><description><![CDATA[<p dir="auto">So if I assume the ADC 12 bit option will give me 4,096 different points and the ADC 16 bit option will give me 65,536 different points maybe I can come up with a formula ( using the voltage - Pressure graph) of how to calculate Kpa when using ADC option for the Tube pressure... Everyone I am just thinking out loud so don't bash me too badly... LOL!</p>
]]></description><link>https://community.m5stack.com/post/29566</link><guid isPermaLink="true">https://community.m5stack.com/post/29566</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Tue, 22 Jul 2025 12:12:17 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 11:21:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks everyone for your suggestions!</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5596">@robski</a> - I went back to my Tube example and the only one that worked was the ADC parameter to pull data. (I used 12bit)</p>
<p dir="auto">So I looked at the UiFlow1 example for the Tube Pressure and tried to duplicate it.  The program now runs BUT I am not sure if I am using the correct math conversion to convert the raw data from the ADC parameter into Kpa.  I have searched a couple of sources BUT can't seem to find documentation that fully explains how to correctly calculate Kpa with the ADC parameter to Kpa...</p>
<p dir="auto">Does anyone know were to get really good documentation on the tube pressure sensor that explains how to properly calculate Kpa using the sensor with ADC option?</p>
<p dir="auto"><img src="/assets/uploads/files/1753183073580-uiflow2_workingcode.jpg" alt="UiFlow2_WorkingCode.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1753183089436-blockypythoncode.jpg" alt="BlockyPythonCode!.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1753183100880-uiflow1_calculationexample.jpg" alt="UiFlow1_CalculationExample.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/29565</link><guid isPermaLink="true">https://community.m5stack.com/post/29565</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Tue, 22 Jul 2025 11:21:35 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Tue, 22 Jul 2025 07:53:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/306757">@adamm5</a>  Ive rebuilt this project from scratch and can confirm that ignoring the i2c load error is possible even when using the AIN i2c unit and PAhub unit. This seems to be a change to my earlier experience but perhaps something else was happening with the code.</p>
]]></description><link>https://community.m5stack.com/post/29563</link><guid isPermaLink="true">https://community.m5stack.com/post/29563</guid><dc:creator><![CDATA[adamm5]]></dc:creator><pubDate>Tue, 22 Jul 2025 07:53:46 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Mon, 21 Jul 2025 06:47:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/313293">@Kenzo</a> as Ive said before  try below: remove "get voltage" block and try your Tube Pressure unit with analog value only<br />
<img src="/assets/uploads/files/1753080429726-kenzo0.png" alt="kenzo0.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/29558</link><guid isPermaLink="true">https://community.m5stack.com/post/29558</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 21 Jul 2025 06:47:26 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Mon, 21 Jul 2025 03:34:38 GMT]]></title><description><![CDATA[<p dir="auto">in my case i need to query an AIN unit, which is i2c...so this error is a total blocker.</p>
]]></description><link>https://community.m5stack.com/post/29557</link><guid isPermaLink="true">https://community.m5stack.com/post/29557</guid><dc:creator><![CDATA[adamm5]]></dc:creator><pubDate>Mon, 21 Jul 2025 03:34:38 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Sat, 19 Jul 2025 06:15:33 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys</p>
<p dir="auto">I think that is what I wanted to tell you guys with my previous post. The <code>i2c driver install error</code>, which I also get, does <strong>not</strong> prevent most of my units to work properly.</p>
<p dir="auto">Out of all my units only two did not work and two I2C units would only work after switching the i2c speed to 400 k.</p>
<p dir="auto">In other words I do not think the <code>i2c driver install error</code> matters in regard with the Tube Pressure unit, which is not an I2C unit.</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/313293">@Kenzo</a> : do you have any other units you could try with your M5Tab5? Or any other core(s) you could try the Tube Pressure unit with?</p>
]]></description><link>https://community.m5stack.com/post/29549</link><guid isPermaLink="true">https://community.m5stack.com/post/29549</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 19 Jul 2025 06:15:33 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Sat, 19 Jul 2025 04:07:56 GMT]]></title><description><![CDATA[<p dir="auto">i'm getting the same i2c driver error on an Atom Lite, the error began following an erase but persists regardless of the UIflow2 version I attempt to refresh with.</p>
]]></description><link>https://community.m5stack.com/post/29548</link><guid isPermaLink="true">https://community.m5stack.com/post/29548</guid><dc:creator><![CDATA[adamm5]]></dc:creator><pubDate>Sat, 19 Jul 2025 04:07:56 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Sat, 19 Jul 2025 01:07:27 GMT]]></title><description><![CDATA[<p dir="auto">Well I started doing the process of elimination and decided to compile a default blank Tab5 project in UiFlow v2.3.1 with no unit sensors and the i2c driver install error still occurred...   <strong>See screen shots...</strong>   So something else is trying to load the i2c drivers in UiFlow v2.3.1 for the Tab5 device and is having a problem installing it...</p>
<p dir="auto"><strong>Question:</strong> Could this be a possible bug somewhere when it comes to Tab5 and the UiFlow IDE???</p>
<p dir="auto"><img src="/assets/uploads/files/1752886945753-tab5andtest4_error_1.png" alt="Tab5andTest4_Error_1.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1752886962326-tab5andtest4_error_2.png" alt="Tab5andTest4_Error_2.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1752886975469-tab5andtest4_error_3.png" alt="Tab5andTest4_Error_3.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/29547</link><guid isPermaLink="true">https://community.m5stack.com/post/29547</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Sat, 19 Jul 2025 01:07:27 GMT</pubDate></item><item><title><![CDATA[Reply to Possible issue with Tab5 and UiFlow v2.3.1 - (i2c driver install error) on Fri, 18 Jul 2025 22:13:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> Yep, I read that wrong... my fault...</p>
]]></description><link>https://community.m5stack.com/post/29546</link><guid isPermaLink="true">https://community.m5stack.com/post/29546</guid><dc:creator><![CDATA[Kenzo]]></dc:creator><pubDate>Fri, 18 Jul 2025 22:13:33 GMT</pubDate></item></channel></rss>
