<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[paper s3 Get mac failed]]></title><description><![CDATA[<p dir="auto">Hi everyone i'm new to the m5 ecosystem and the paper s3 is my first device, I'm trying to burn the uiflow 2.0 for s3 firmware to it but I keep getting a "GET mac failed" error.</p>
<p dir="auto">For more info, when I plug in the device, it recognises it and brings up the usb port it's connected to, The when I press burn, it loads fo a second, the paper s3 restarts, m5burner loses connections fora couple of seconds then reconnects when th s3 has finished restarting. All this happens while it is still trying to "Burn"</p>
<p dir="auto">for computer details, i'm using an M2 macbook air 16inch running the latest macos Sequio with Xcode installed</p>
]]></description><link>https://community.m5stack.com/topic/7668/paper-s3-get-mac-failed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 14:08:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7668.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Jul 2025 07:55:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to paper s3 Get mac failed on Thu, 17 Jul 2025 09:26:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/310813">@jahaan2311</a> The "GET mac failed" error when burning UIFlow 2.0 firmware to your PaperS3 (SKU:C139) typically relates to communication issues during the flashing process. Here are the recommended steps to resolve this:</p>
<p dir="auto">Ensure Correct Download Mode: When connecting the PaperS3 to your Mac, make sure the device enters download mode properly. The screen should remain blank after connecting, indicating it's in programming mode.</p>
<p dir="auto">Verify M5Burner Setup:</p>
<p dir="auto">Confirm you have the latest M5Burner version installed for macOS<br />
Select the correct PaperS3 firmware in M5Burner<br />
Double-check the USB port selection matches your connected device</p>
<p dir="auto">Check USB Connection:</p>
<p dir="auto">Try using a different USB-C cable (preferably a data cable, not charging-only)<br />
Connect directly to your Mac's USB port instead of using a hub<br />
Avoid using USB-C adapters if possible</p>
<p dir="auto">Reconfigure Burning Settings:</p>
<p dir="auto">In M5Burner, click "Configure" before burning<br />
Verify all Wi-Fi settings are correctly entered<br />
Ensure the baud rate is set to the recommended value (typically 115200)</p>
<p dir="auto">macOS Specific Considerations:</p>
<p dir="auto">Ensure you have the necessary USB drivers installed<br />
Check System Preferences &gt; Security &amp; Privacy for any blocked developer extensions<br />
Try restarting your Mac and the PaperS3 device before retrying</p>
<p dir="auto">If the issue persists after these steps, please try burning the factory firmware first using the PaperS3 Factory Firmware and then attempt the UIFlow 2.0 firmware again.</p>
<p dir="auto"><a href="https://chat.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://chat.m5stack.com/</a></p>
]]></description><link>https://community.m5stack.com/post/29529</link><guid isPermaLink="true">https://community.m5stack.com/post/29529</guid><dc:creator><![CDATA[yuyun2000]]></dc:creator><pubDate>Thu, 17 Jul 2025 09:26:51 GMT</pubDate></item></channel></rss>
