<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 cannot be burned as Public and is not active in UI2Flow]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I played with a Core2 after long time. I did something wrong. I reprogrammed it. But current result is:<br />
If I burn it, Device is still only "Private" regardless of the programming option (Public/Private).<br />
UI2Flow display device correctly as a Private or Public. But I am not able to activate device. Unregistration in UI2Flow and reburning do not help.<br />
I am able to use UIFlow1 with API Key and connect it by USB in UI2Flow.<br />
How to make it Public and control it online in UI2Flow?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/7635/core2-cannot-be-burned-as-public-and-is-not-active-in-ui2flow</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 02:59:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7635.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Jun 2025 12:28:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 cannot be burned as Public and is not active in UI2Flow on Thu, 03 Jul 2025 19:28:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pavelndc" aria-label="Profile: PavelNDC">@<bdi>PavelNDC</bdi></a> Public (red) means that's it's not connected. normally this is an issue with the M5Stack server.</p>
]]></description><link>https://community.m5stack.com/post/29389</link><guid isPermaLink="true">https://community.m5stack.com/post/29389</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 03 Jul 2025 19:28:45 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 cannot be burned as Public and is not active in UI2Flow on Thu, 03 Jul 2025 11:53:19 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply, but no progress.</p>
<p dir="auto">My steps are:</p>
<p dir="auto">Core2 device connected<br />
Core2 device = Private (on display)<br />
logged in to the UI2flow. It shows Core2 as Public, red</p>
<li>Core2 unregistered  in UI2flow</li>
<li>Core2 not visible in UI2flow</li>
<li>registered to M5Burner, downloaded last FW 2.3.0-Core2</li>
<li>Press Burn, Erase → Erased successfully</li>
<li>Press Burn, Start, Baud Rate default (1500000)</li>
<li>Checking device...</li>
<li>Burn UIFlow2 pop-up window froze</li>
<li>Waited 2 min.</li>
<li>UI2Flow page refreshed</li>
<li>Waited 30 min. → no change</li>
<li>Closed Burn pop-up window</li>
<li>Reopened Burn pop-up window</li>
<li></li>
<li>Set BaudRate to750000</li>
<li>Erased successfully</li>
<li>Waring: ...bind your account now? → Yes</li>
<li>Binding device → keep settings to "Public" → next</li>
<li>Binding device successfully</li>
<li>Press Erase</li>
<li>Brun, Set BaudRate to750000</li>
<li>Checking device....</li>
<li>Configure, filled Wifi credentials → Next</li>
<li>Burning</li>
<li>Core2 restarted, Burn successfully</li>
<li>I can see on display "Private" again</li>
<li>Core2 is visible in UI2Flow as Public, red. (After reloading the page).</li>
<p dir="auto">Any idea?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/post/29381</link><guid isPermaLink="true">https://community.m5stack.com/post/29381</guid><dc:creator><![CDATA[PavelNDC]]></dc:creator><pubDate>Thu, 03 Jul 2025 11:53:19 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 cannot be burned as Public and is not active in UI2Flow on Thu, 26 Jun 2025 04:03:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slarck" aria-label="Profile: Slarck">@<bdi>Slarck</bdi></a> You should always Erase first because of this. never just burn only.<br />
Thats the reason for the big red erase button being there!</p>
]]></description><link>https://community.m5stack.com/post/29336</link><guid isPermaLink="true">https://community.m5stack.com/post/29336</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 26 Jun 2025 04:03:42 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 cannot be burned as Public and is not active in UI2Flow on Thu, 26 Jun 2025 03:04:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/29333">Core2 cannot be burned as Public and is not active in UI2Flow</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yuyun2000" aria-label="Profile: yuyun2000">@<bdi>yuyun2000</bdi></a> Did you Erase existing firmware first?</p>
<p dir="auto">Good point, I was also wondering if a full erase before burning might be necessary here. Sometimes leftover configs can cause issues with the device mode not updating properly. Has anyone confirmed if doing a complete erase in M5Burner helped switch the Core2 to Public successfully?</p>
]]></description><link>https://community.m5stack.com/post/29335</link><guid isPermaLink="true">https://community.m5stack.com/post/29335</guid><dc:creator><![CDATA[Slarck]]></dc:creator><pubDate>Thu, 26 Jun 2025 03:04:16 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 cannot be burned as Public and is not active in UI2Flow on Wed, 25 Jun 2025 19:00:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yuyun2000" aria-label="Profile: yuyun2000">@<bdi>yuyun2000</bdi></a> Did you Erase existing firmware first?</p>
]]></description><link>https://community.m5stack.com/post/29333</link><guid isPermaLink="true">https://community.m5stack.com/post/29333</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 25 Jun 2025 19:00:35 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 cannot be burned as Public and is not active in UI2Flow on Wed, 25 Jun 2025 01:11:21 GMT]]></title><description><![CDATA[<p dir="auto">To resolve the issue with your M5Stack Core2 not switching to "Public" mode in UIFlow 2.0, follow these steps:<br />
Steps to Fix:</p>
<p dir="auto">Reconfigure in M5Burner:</p>
<p dir="auto">Open M5Burner and ensure you are using the latest firmware for Core2.<br />
Select the correct port and click Configure.<br />
Choose Public mode in the configuration options before burning the firmware.</p>
<p dir="auto">Check Account Binding:</p>
<p dir="auto">Ensure the device is bound to the same account used in UIFlow 2.0. Log in to UiFlow2 with the same credentials as M5Burner.<br />
If the device is still "Private," unbind it from your account and rebind it.</p>
<p dir="auto">Wi-Fi Connection:</p>
<p dir="auto">Ensure the Core2 is connected to Wi-Fi. A stable connection is required for online control.</p>
<p dir="auto">Reset and Reburn:</p>
<p dir="auto">Perform a factory reset on the Core2.<br />
Reburn the firmware, ensuring Public mode is selected.</p>
<p dir="auto">Verify in UIFlow 2.0:</p>
<p dir="auto">After reburning, check the device status in UIFlow 2.0 under Select Device. It should now appear as "Public."</p>
<p dir="auto">Additional Notes:</p>
<p dir="auto">If the issue persists, contact <a href="mailto:support@m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">support@m5stack.com</a> for further assistance.<br />
Ensure no conflicting configurations (e.g., API keys) are interfering with the mode switch.</p>
<p dir="auto"><a href="https://chat.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://chat.m5stack.com/</a></p>
]]></description><link>https://community.m5stack.com/post/29325</link><guid isPermaLink="true">https://community.m5stack.com/post/29325</guid><dc:creator><![CDATA[yuyun2000]]></dc:creator><pubDate>Wed, 25 Jun 2025 01:11:21 GMT</pubDate></item></channel></rss>
