<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 power use versus CoreS3 power use.]]></title><description><![CDATA[<p dir="auto">I noticed that for my application(a Geiger counter)  a Core2 uses 120mA from 5volt and drains a 2000mA battery in about 16 hours, But when I use the CoreS3 it uses 250mA from 5volt and drains a 2000mA/h battery down in 8 hours.</p>
<p dir="auto">I prefer to use the CoreS3 (much better screen responses) and I can order them as CoreS3-SE (no back). But the double amount of the current drain of the CoreS3 is not acceptable for my clients.</p>
<p dir="auto">Is there a way to reduce the current drain while keeping the CoreS3 fully functional?</p>
<p dir="auto">Regards<br />
Rob Oudendijk</p>
<p dir="auto">For more information about the project, <a href="https://bgeigiezen.safecast.jp" target="_blank" rel="noopener noreferrer nofollow ugc">https://bgeigiezen.safecast.jp</a></p>
]]></description><link>https://community.m5stack.com/topic/7581/core2-power-use-versus-cores3-power-use</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 15:03:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7581.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 May 2025 00:36:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 power use versus CoreS3 power use. on Fri, 30 May 2025 16:06:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4415">@robouden</a></p>
<p dir="auto">hmm, running UIFlow2 on my M5CoreS3 and measuring current on USB-C I get about 140 mA / 5 V.</p>
<p dir="auto">Is your M5CoreS3 maybe charging the battery?</p>
]]></description><link>https://community.m5stack.com/post/29136</link><guid isPermaLink="true">https://community.m5stack.com/post/29136</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 30 May 2025 16:06:19 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 power use versus CoreS3 power use. on Thu, 29 May 2025 02:54:00 GMT]]></title><description><![CDATA[<p dir="auto">The CoreS3 (SKU: K128) and CoreS3-SE (SKU: K128-SE) use AXP2101 power management chips and are designed with low power consumption. However, to further reduce power consumption while maintaining full functionality, you can consider the following aspects:</p>
<p dir="auto">Power Supply Configuration: You can configure the XPD_SDIO_REG to select the power supply from the regulator or an external power source.<br />
Voltage Selection: Configure SDIO_TIEH to select a 3.3V or 1.8V voltage.<br />
Under - voltage Detection: The CoreS3's ESP32 - S3 chip has an under - voltage detector that can detect the voltage of some pins. When the voltage drops rapidly below a preset threshold (default is 2.7V), it can turn off some power - consuming modules to save power.</p>
<p dir="auto">In addition, the power consumption of a device is also affected by factors such as the brightness of the screen, the operation mode of the Wi - Fi module, and the working state of other components. You can try to adjust these factors to reduce the power consumption of the CoreS3.</p>
<p dir="auto">(The above content is generated from <a href="https://chat.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://chat.m5stack.com/</a>)</p>
]]></description><link>https://community.m5stack.com/post/29122</link><guid isPermaLink="true">https://community.m5stack.com/post/29122</guid><dc:creator><![CDATA[yuyun2000]]></dc:creator><pubDate>Thu, 29 May 2025 02:54:00 GMT</pubDate></item></channel></rss>
