<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Watering unit sensor calibration]]></title><description><![CDATA[<p dir="auto">I am using the watering.ino example</p>
<p dir="auto"><a href="https://github.com/m5stack/M5Stack/blob/master/examples/Unit/WATERING/WATERING.ino" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Stack/blob/master/examples/Unit/WATERING/WATERING.ino</a></p>
<p dir="auto">How should I interpret the humidity sensor values? Is there a way to do a calibration? I get values ​​of about 2100 for the sensor in air, 1800 if wrapped in a wet rag and 1500 if immersed in water.</p>
<p dir="auto">thanks</p>
]]></description><link>https://community.m5stack.com/topic/7564/watering-unit-sensor-calibration</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 07:17:04 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7564.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 May 2025 12:22:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Watering unit sensor calibration on Tue, 20 May 2025 18:48:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gantini" aria-label="Profile: gantini">@<bdi>gantini</bdi></a> The sensor is a capacitive sensor and so the higher the reading the lower the moisture level.<br />
These are superior to the resistive sensors that rot easy but work the same way.</p>
]]></description><link>https://community.m5stack.com/post/29075</link><guid isPermaLink="true">https://community.m5stack.com/post/29075</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 20 May 2025 18:48:31 GMT</pubDate></item></channel></rss>
