<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[help me bruh]]></title><description><![CDATA[<p dir="auto">my pc cant find the com cable and says this when i try to flash  "<br />
No serial data received" i just bought my m5stack cplus1</p>
]]></description><link>https://community.m5stack.com/topic/7563/help-me-bruh</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 14:24:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7563.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 May 2025 22:31:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to help me bruh on Tue, 20 May 2025 10:16:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/coolman861263" aria-label="Profile: coolman861263">@<bdi>coolman861263</bdi></a><br />
Please follow this instruction and see if helps:</p>
<li>Observe whether there are any obvious physical damage marks on the device.</li>
<li>Install the device driver:
<li>Windows: <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/drivers/CH9102_VCP_SER_Windows.exe" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/drivers/CH9102_VCP_SER_Windows.exe</a></li>
<li>macOS: <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/drivers/CH9102_VCP_MacOS_v1.7.zip" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/drivers/CH9102_VCP_MacOS_v1.7.zip</a></li>
</li>
<li>Connect the device using a USB cable and open the device manager. Check whether the device manager page refreshes when the device is inserted, and whether a new device appears in Universal Serial Bus controllers. If not:
<li>If you are using USB C to C cable: First disconnect the StickCPlus, turn off the device, and then plug in the cable (press and hold the power button until the green light turns on to indicate that it is turned off). Or replace it with an A to C cable.</li>
<li>If you are using USB A to C cable: "Try to change the data cable", "Try to reinstall the driver", "Try to change the PC".</li>
</li>
<li>Reburn the factory firmware: <a href="https://docs.m5stack.com/en/guide/restore_factory/m5stickc_plus" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/guide/restore_factory/m5stickc_plus</a>.</li>
<li>The screen is still black after burning:
<li>Press and hold the leftmost button until the green light inside turns on, then plug in the USB cable</li>
<li>Observe whether the screen is black but has a faint backlight, and whether there is a beep sound when pressing the button</li>
</li>
]]></description><link>https://community.m5stack.com/post/29073</link><guid isPermaLink="true">https://community.m5stack.com/post/29073</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Tue, 20 May 2025 10:16:28 GMT</pubDate></item></channel></rss>
