<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[EXTIO2 with three UltrasoundIO connected]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I'm fairly new to UiFlow however I have been C++ coding with Arduino for a while now and though I would try using the M5Stack gear.</p>
<p dir="auto">I purchased a Core device, a EXTIO2 and a number of UltrasoundIO (GPIO model). I want to build a test that reads the distance from the UltrasoundIO connected to the EXTIO2, however im not sure how to reference the pins within the EXTIO2 in the UltrasoundIO configuration or methods</p>
<p dir="auto">Can anyone assist or provide a basic example ?</p>
]]></description><link>https://community.m5stack.com/topic/7533/extio2-with-three-ultrasoundio-connected</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 20:13:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7533.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Apr 2025 20:49:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to EXTIO2 with three UltrasoundIO connected on Fri, 23 May 2025 06:21:52 GMT]]></title><description><![CDATA[<p dir="auto">The EXTIO2 with three UltrasoundIO devices connected delivers high-performance, synchronized ultrasound data acquisition. Ideal for advanced diagnostic and research applications, this setup ensures seamless connectivity and reliable data transfer. EXTIO2's robust architecture supports simultaneous operation of all three UltrasoundIO units, maximizing efficiency and enabling multi-channel imaging or analysis. With plug-and-play functionality and scalable design, it’s the perfect solution for labs or clinics requiring precise, real-time ultrasound integration and control.</p>
]]></description><link>https://community.m5stack.com/post/29093</link><guid isPermaLink="true">https://community.m5stack.com/post/29093</guid><dc:creator><![CDATA[peolsolutions]]></dc:creator><pubDate>Fri, 23 May 2025 06:21:52 GMT</pubDate></item><item><title><![CDATA[Reply to EXTIO2 with three UltrasoundIO connected on Wed, 30 Apr 2025 18:09:49 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/266726">@oracle_sod</a></p>
<p dir="auto">ok, I see, the DFRobot version has an UART interface. M5ExtIO2 GPIOs can be set to multiple modes (input, output, ADC, servo, neopixel and PWM) but I am afraid none of these modes can be used for an UART connection.</p>
<p dir="auto">According to the wiki <a href="https://wiki.dfrobot.com/_A02YYUW_Waterproof_Ultrasonic_Sensor_SKU_SEN0311#target_5" target="_blank" rel="noopener noreferrer nofollow ugc">page</a> RX is used to select the mode, this could be achieved via M5ExtIO GPIO set as output.</p>
<p dir="auto">However the TX line sends data with 9600 Baud, which I doubt M5ExtIO2 can handle.</p>
<p dir="auto">That said, what is the reason you don't connect all three Ultrasound units directly to the M5Core? That would require 6 GPIOs.</p>
<p dir="auto">And if you could live with the fact that all three Ultrasound units use the same mode you could get away with only 4 GPIOs, 1 GPIO to select the mode for all three units, and 1 GPIO for each unit to receive the UART data.</p>
]]></description><link>https://community.m5stack.com/post/29008</link><guid isPermaLink="true">https://community.m5stack.com/post/29008</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 30 Apr 2025 18:09:49 GMT</pubDate></item><item><title><![CDATA[Reply to EXTIO2 with three UltrasoundIO connected on Wed, 30 Apr 2025 15:02:34 GMT]]></title><description><![CDATA[<p dir="auto">(sorry about the double post)</p>
<p dir="auto">I'm not able to use the I2C variant as i didn't get that sensor from M5stack, its one of these:<br />
<a href="https://www.dfrobot.com/product-1935.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dfrobot.com/product-1935.html</a></p>
<p dir="auto">I need it to be water resistant for this setup.</p>
]]></description><link>https://community.m5stack.com/post/29007</link><guid isPermaLink="true">https://community.m5stack.com/post/29007</guid><dc:creator><![CDATA[oracle_sod]]></dc:creator><pubDate>Wed, 30 Apr 2025 15:02:34 GMT</pubDate></item><item><title><![CDATA[Reply to EXTIO2 with three UltrasoundIO connected on Wed, 30 Apr 2025 15:00:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> said in <a href="/post/28991">EXTIO2 with three UltrasoundIO connected</a>:</p>
<p dir="auto">PaHub</p>
]]></description><link>https://community.m5stack.com/post/29006</link><guid isPermaLink="true">https://community.m5stack.com/post/29006</guid><dc:creator><![CDATA[oracle_sod]]></dc:creator><pubDate>Wed, 30 Apr 2025 15:00:09 GMT</pubDate></item><item><title><![CDATA[Reply to EXTIO2 with three UltrasoundIO connected on Tue, 29 Apr 2025 22:13:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/266726">@oracle_sod</a></p>
<p dir="auto">Note: I don't have the UltrasonicIO unit so my conclusions might be inaccurate.</p>
<p dir="auto">Looking at the Arduino <a href="https://github.com/m5stack/M5Unit-Sonic/blob/master/src/Unit_Sonic.cpp#L60" target="_blank" rel="noopener noreferrer nofollow ugc">code</a>, I see it uses a function called <code>pulseIn()</code> which does some sort of timing. I doubt it exists on the EXTIO2 unit so you would have to emulate this functionality yourself.</p>
<p dir="auto">BTW: I think an easier setup would have been a PaHub unit with three Ultrasonic (I2C variant) units connected to it.</p>
]]></description><link>https://community.m5stack.com/post/28991</link><guid isPermaLink="true">https://community.m5stack.com/post/28991</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 29 Apr 2025 22:13:19 GMT</pubDate></item></channel></rss>
