<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 DAPLink as debugger]]></title><description><![CDATA[<p dir="auto">Does it work as debugger?</p>
]]></description><link>https://community.m5stack.com/topic/7509/m5-daplink-as-debugger</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 15:38:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7509.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Apr 2025 08:27:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 DAPLink as debugger on Fri, 23 May 2025 04:34:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/120">@Kabron</a> The benefit is that it can be used as an offline programmer.  Love this idea in that I don't need to use a computer to program a few various HEX/BIN files to several different chips.</p>
<p dir="auto">Once the partition.cvs table is converted for Arduino IDE, it made it simple to change the fat image for updates.</p>
<p dir="auto">The project is set to be compiled with Expressif-IDF/IDE.<br />
Modify the html / display code prior to fit your needs (Like updating to English to avoid confusion if you're trying to use the in program ability to upload files).</p>
]]></description><link>https://community.m5stack.com/post/29097</link><guid isPermaLink="true">https://community.m5stack.com/post/29097</guid><dc:creator><![CDATA[Michail1]]></dc:creator><pubDate>Fri, 23 May 2025 04:34:32 GMT</pubDate></item><item><title><![CDATA[Reply to M5 DAPLink as debugger on Fri, 18 Apr 2025 09:30:12 GMT]]></title><description><![CDATA[<p dir="auto">No, it can not.<br />
So, the benefit is very questionable...</p>
<p dir="auto">Also, the current FW is very fragmental</p>
]]></description><link>https://community.m5stack.com/post/28927</link><guid isPermaLink="true">https://community.m5stack.com/post/28927</guid><dc:creator><![CDATA[Kabron]]></dc:creator><pubDate>Fri, 18 Apr 2025 09:30:12 GMT</pubDate></item></channel></rss>
