<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[StamPLC - user demo- wifi&#x2F;time config?]]></title><description><![CDATA[<p dir="auto">Received StamPLC with user demo project, updated to latest ver via M5Burner but there is no config to set up wifi or time. How can I do this when user demo is loaded? Uiflow2 firmware went in ok and there is "config" before burn so wifi ant time zone can be set thats ok. With user demo only timezone change is allowed from display.</p>
]]></description><link>https://community.m5stack.com/topic/7487/stamplc-user-demo-wifi-time-config</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 01:25:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7487.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Apr 2025 06:54:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to StamPLC - user demo- wifi&#x2F;time config? on Mon, 11 Aug 2025 22:18:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/322886">@onlysaadat</a> My new StamPLC is exactly the same.  Registered the device with M5Burner, It's on-line in UiFlow2, Loaded a fresh StamPLC demo - demo initially logged in and just flashed the monitor page no matter what browser is used on multiple computers. Cleared the monitoring user per M5s directions.</p>
<p dir="auto">Now I get an invalid token no matter what I do.</p>
<p dir="auto">Did you ever get your device to work with the demo or figure out how to fix the invalid token?</p>
]]></description><link>https://community.m5stack.com/post/29725</link><guid isPermaLink="true">https://community.m5stack.com/post/29725</guid><dc:creator><![CDATA[earla]]></dc:creator><pubDate>Mon, 11 Aug 2025 22:18:25 GMT</pubDate></item><item><title><![CDATA[Reply to StamPLC - user demo- wifi&#x2F;time config? on Fri, 01 Aug 2025 22:07:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/266432">@Mellie2025</a> hi there, when i try to open the ezdata link in login page says invalid token. whats the problem?</p>
]]></description><link>https://community.m5stack.com/post/29679</link><guid isPermaLink="true">https://community.m5stack.com/post/29679</guid><dc:creator><![CDATA[onlysaadat]]></dc:creator><pubDate>Fri, 01 Aug 2025 22:07:35 GMT</pubDate></item><item><title><![CDATA[Reply to StamPLC - user demo- wifi&#x2F;time config? on Wed, 16 Apr 2025 17:12:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5596">@robski</a>  Thank you, binding the device was the issue....DOH! Working now, much appreciated.</p>
]]></description><link>https://community.m5stack.com/post/28914</link><guid isPermaLink="true">https://community.m5stack.com/post/28914</guid><dc:creator><![CDATA[Mellie2025]]></dc:creator><pubDate>Wed, 16 Apr 2025 17:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to StamPLC - user demo- wifi&#x2F;time config? on Wed, 16 Apr 2025 07:04:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/266432">@Mellie2025</a> yes EZdata works ok on mine, you have to  log in with your M5stack credentials true, tried different web browser?<br />
I'm using firefox and it works ok.<br />
Can you maybe try to load Uiflow2 firmware and then bind it to your account and check if its visible as online device in your devices list.</p>
]]></description><link>https://community.m5stack.com/post/28904</link><guid isPermaLink="true">https://community.m5stack.com/post/28904</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Wed, 16 Apr 2025 07:04:46 GMT</pubDate></item><item><title><![CDATA[Reply to StamPLC - user demo- wifi&#x2F;time config? on Tue, 15 Apr 2025 11:51:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello robski,</p>
<p dir="auto">Did you manage to get the "EzData" demo to work?</p>
<p dir="auto">I received a STAMPLC recently and made a start with the preinstalled demo but i cannot get EzData to work correctly. Wifi setup went ok (eventually) along with the correct time zone so "Dashboard" shows a connection to EZData.<br />
Scanning the "Monitor Link" QR code takes me to a login page, and entering the correct credentials, briefly shows the EzData dashboard but quickly reverts back to the login page. The top right corner shows i am logged in but no joy in getting to the dashboard, repeatedly reverting back to the login page.<br />
I also updated the firmware to V0.2 with the same results.</p>
<p dir="auto">Hopefully there is a solution or am i missing something?</p>
]]></description><link>https://community.m5stack.com/post/28893</link><guid isPermaLink="true">https://community.m5stack.com/post/28893</guid><dc:creator><![CDATA[Mellie2025]]></dc:creator><pubDate>Tue, 15 Apr 2025 11:51:10 GMT</pubDate></item><item><title><![CDATA[Reply to StamPLC - user demo- wifi&#x2F;time config? on Thu, 10 Apr 2025 07:11:30 GMT]]></title><description><![CDATA[<p dir="auto">well just found EZData config/wifi setup so maybe thats the one to play with</p>
]]></description><link>https://community.m5stack.com/post/28857</link><guid isPermaLink="true">https://community.m5stack.com/post/28857</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Thu, 10 Apr 2025 07:11:30 GMT</pubDate></item></channel></rss>
