<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 stack paper stop storing data in preferences?]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am using <code>Preferences.h</code> to store data on my <code>M5 Stack Paper</code>, such as Wi-Fi credentials, during my application's setup. It was working fine.<br />
During development and testing, I have rewritten the data in <code>Preferences</code> multiple times on this device. However, I recently noticed that new data is no longer being stored in <code>Preferences</code>, even though there is still available space, as confirmed by running the following code.</p>
<pre><code>#include &lt;Preferences.h&gt;
void checkWifiCredentialsAndDecide(){
  preferences.begin("wifiCredentials", false);
 if(debugFlag){
    size_t whatsLeft = preferences.freeEntries();
    Serial.printf("Available enteries in the namespace table.\n" );
    Serial.println(whatsLeft);
    preferences.putString("test1", "test 1 value");
    Serial.println("preferences.getString(test1): " + String(preferences.getString("test1", "Default value")));
<pre><code>Output
127
preferences.getString(test1): Default value // I am expecting to see "test 1 value"
<p dir="auto">I have read that the NVS (Non-Volatile Storage) has a write cycle limitation of approximately 10,000 to 100,000 cycles.<br />
I have a few questions:<br />
Is there a way to check how many write cycles are remaining?<br />
Can I check if my flash memory is healthy or corrupted?<br />
Is it possible that the flash memory of my M5 Stack Paper has worn out?</p>
<p dir="auto">Thank you</p>
]]></description><link>https://community.m5stack.com/topic/7461/m5-stack-paper-stop-storing-data-in-preferences</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 11:49:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7461.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Apr 2025 10:15:01 GMT</pubDate><ttl>60</ttl></channel></rss>
