<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Apps - multiple apps installer]]></title><description><![CDATA[<p dir="auto">Check out the new project for firmware flashing right on your M5 Cardputer (currently <strong>under development</strong>)</p>
<p dir="auto">Supported features:</p>
<li>Install app in separate partition (in case the image is single app partition)</li>
<li>Install full firmware bundle (erasing all previous installed apps)</li>
<li>Press any key on boot to enter Apps menu</li>
<li>List of installed apps. Run immediately</li>
<p dir="auto">Supported sources (media):</p>
<li>SD card (FAT formatted)</li>
<li>USB flash drive (FAT formated)</li>
<li>Remote repository (<strong>under development</strong>)</li>
<p dir="auto">Version 1.0 is available in M5Burner under CARDPUTER device.<br />
Waiting for feedback.</p>
]]></description><link>https://community.m5stack.com/topic/7388/m5apps-multiple-apps-installer</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 08:56:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7388.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Mar 2025 21:48:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Mon, 02 Feb 2026 13:58:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/425105">@cricri</a> There is FDISK utility built-in.<br />
You can list all the partitions and delete those are not used anymore. System partitions are read-only, so you will not delete anything extra.<br />
Also you can create new partition at any time. For example, the Game Station requires spare partition for cache. so just add it in FDISK with a few clicks.</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/412049">@dzepetko</a> said in <a href="/post/30358">M5Apps - multiple apps installer</a>:</p>
<p dir="auto">How can i install meshtastic and 4exampe winamp? - i have error not enough space.. ;/</p>
<p dir="auto">By default the SDK (ESP-IDF) makes firmware bundle with default partitions, But the thing is: application could not use it at all or use one of them. So we can cook a binary with only partitions that really need by the app. This can save much space.</p>
]]></description><link>https://community.m5stack.com/post/30560</link><guid isPermaLink="true">https://community.m5stack.com/post/30560</guid><dc:creator><![CDATA[d4rkmen]]></dc:creator><pubDate>Mon, 02 Feb 2026 13:58:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Tue, 27 Jan 2026 11:53:24 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Nice job !!! very interesting approch with no burning in between apps</p>
<p dir="auto">But memory is a real limit</p>
<p dir="auto">How to uninstall unused app from memory ?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/post/30527</link><guid isPermaLink="true">https://community.m5stack.com/post/30527</guid><dc:creator><![CDATA[cricri]]></dc:creator><pubDate>Tue, 27 Jan 2026 11:53:24 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Thu, 25 Dec 2025 12:41:38 GMT]]></title><description><![CDATA[<p dir="auto">How can i install meshtastic and 4exampe winamp? - i have error not enough space.. ;/</p>
]]></description><link>https://community.m5stack.com/post/30358</link><guid isPermaLink="true">https://community.m5stack.com/post/30358</guid><dc:creator><![CDATA[dzepetko]]></dc:creator><pubDate>Thu, 25 Dec 2025 12:41:38 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Wed, 15 Oct 2025 20:10:33 GMT]]></title><description><![CDATA[<p dir="auto">New version available on M5Burner</p>
<p dir="auto">v1.9</p>
<li>Added new app FINDER: two-panel file manager for SD card and USB drive</li>
<li>Improved keyboard navigation in all apps</li>
<li>Fixed keyboard sound issues</li>
<li>INSTALLER: Added sorting files and folders by name</li>
<li>INSTALLER: Cloud source fixed HTTP buffers</li>
<li>FDISK: Added creation of new data partitions (press A)</li>
<li>FDISK: No reboot required after deleting data partition</li>
<li>Updated to the latest ESP-IDF v5.5.1</li>
<li>Updated USB MSC driver</li>
]]></description><link>https://community.m5stack.com/post/30062</link><guid isPermaLink="true">https://community.m5stack.com/post/30062</guid><dc:creator><![CDATA[d4rkmen]]></dc:creator><pubDate>Wed, 15 Oct 2025 20:10:33 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Fri, 19 Sep 2025 06:17:10 GMT]]></title><description><![CDATA[<p dir="auto">is there a way to increase the storage to add more apps, i have 64gb.</p>
]]></description><link>https://community.m5stack.com/post/29963</link><guid isPermaLink="true">https://community.m5stack.com/post/29963</guid><dc:creator><![CDATA[troyler]]></dc:creator><pubDate>Fri, 19 Sep 2025 06:17:10 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Thu, 14 Aug 2025 15:18:09 GMT]]></title><description><![CDATA[<p dir="auto">If this broke your cardputer here is how to fix it:<br />
Before plugging your cardputer in hold the GO button and then plug in the cable. Cardputer will enter the download mode and you can then flash everything you want!<br />
~ yehor</p>
]]></description><link>https://community.m5stack.com/post/29755</link><guid isPermaLink="true">https://community.m5stack.com/post/29755</guid><dc:creator><![CDATA[yehors]]></dc:creator><pubDate>Thu, 14 Aug 2025 15:18:09 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Tue, 29 Jul 2025 12:11:39 GMT]]></title><description><![CDATA[<p dir="auto">Would this project ever be open-source? I was trying to create such a firmware manager for my Tab5 device and was encountering troubles, the M5Launcher's approach was strange (seems like it needs a custom bootloader which I don't have) so I wanted to check M5Apps out. It would be the best if M5Apps are open source.</p>
]]></description><link>https://community.m5stack.com/post/29646</link><guid isPermaLink="true">https://community.m5stack.com/post/29646</guid><dc:creator><![CDATA[ImLunchtime]]></dc:creator><pubDate>Tue, 29 Jul 2025 12:11:39 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Wed, 23 Jul 2025 14:04:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/248603">@d4rkmen</a><br />
Hi, are you talking about M5 Launcher project or something different?<br />
I'm confused (new user) as the version numbers seem very different between what you say and what I see on M5 Burner.<br />
Thanks<br />
PS is there any chance of something like this for Tab5?</p>
]]></description><link>https://community.m5stack.com/post/29595</link><guid isPermaLink="true">https://community.m5stack.com/post/29595</guid><dc:creator><![CDATA[kermit17]]></dc:creator><pubDate>Wed, 23 Jul 2025 14:04:33 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Wed, 23 Jul 2025 08:07:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/311825">@bigchease</a> no, you have to flash full firmware (bootloader, PT, nvs, and the rest). Thans why you have to use some other flasher like M5Burner or esptools.</p>
]]></description><link>https://community.m5stack.com/post/29588</link><guid isPermaLink="true">https://community.m5stack.com/post/29588</guid><dc:creator><![CDATA[d4rkmen]]></dc:creator><pubDate>Wed, 23 Jul 2025 08:07:04 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Wed, 16 Jul 2025 03:47:13 GMT]]></title><description><![CDATA[<p dir="auto">this might be a dumb question but is there any way to get a bin file for m5 launcher</p>
]]></description><link>https://community.m5stack.com/post/29507</link><guid isPermaLink="true">https://community.m5stack.com/post/29507</guid><dc:creator><![CDATA[bigchease]]></dc:creator><pubDate>Wed, 16 Jul 2025 03:47:13 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Mon, 31 Mar 2025 09:52:56 GMT]]></title><description><![CDATA[<p dir="auto">v1.5</p>
<li>Added version to boot animation</li>
<li>Cloud source error messages are now more informative</li>
<li>Minor UI fixes (hints, navigation, sound)</li>
]]></description><link>https://community.m5stack.com/post/28723</link><guid isPermaLink="true">https://community.m5stack.com/post/28723</guid><dc:creator><![CDATA[d4rkmen]]></dc:creator><pubDate>Mon, 31 Mar 2025 09:52:56 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Sat, 29 Mar 2025 17:30:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/109443">@erwantest123</a> was my fault. I have put single app file to M5Burner isntead of full fw :(</p>
<p dir="auto">Check for new TOP-20 updates:</p>
<li>
<p dir="auto">Snake: classic game</p>
</li>
<li>
<p dir="auto">M5Tuna: guitar tuner app</p>
</li>
<p dir="auto">Both apps are ~350Kb, could be used with M5Apps very well</p>
]]></description><link>https://community.m5stack.com/post/28713</link><guid isPermaLink="true">https://community.m5stack.com/post/28713</guid><dc:creator><![CDATA[d4rkmen]]></dc:creator><pubDate>Sat, 29 Mar 2025 17:30:30 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Fri, 28 Mar 2025 12:11:54 GMT]]></title><description><![CDATA[<p dir="auto">hello 1.3 work for me<br />
thank you</p>
]]></description><link>https://community.m5stack.com/post/28701</link><guid isPermaLink="true">https://community.m5stack.com/post/28701</guid><dc:creator><![CDATA[erwantest123]]></dc:creator><pubDate>Fri, 28 Mar 2025 12:11:54 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Sun, 23 Mar 2025 21:21:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/109443">@erwantest123</a> wow, first feedback :)<br />
thanks for this. whould be nice to have steps to reproduce</p>
]]></description><link>https://community.m5stack.com/post/28617</link><guid isPermaLink="true">https://community.m5stack.com/post/28617</guid><dc:creator><![CDATA[d4rkmen]]></dc:creator><pubDate>Sun, 23 Mar 2025 21:21:28 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Sun, 23 Mar 2025 08:38:52 GMT]]></title><description><![CDATA[<p dir="auto">hello i have a error with sha256 verification<br />
bye<br />
P.S. i love your project</p>
<p dir="auto">serial logs:<br />
[FROM M5Burner] COM3 opened.<br />
load:0x600fe100,len:0x1c<br />
SHA-256 comparison failed:<br />
Calculated: 5e23c97eab19023e851de85f4eeea87aed472ea13e871562b17f2a5ec097a9f5<br />
Expected: 1108a20e982d1031358092f5f1acb0437a206312e99d5443a1985793bd2c5984<br />
Attempting to boot anyway...<br />
entry 0x40375408<br />
ESP-ROM:esp32s3-20210327<br />
Build:Mar 27 2021<br />
rst:0x7 (TG0WDT_SYS_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)<br />
Saved PC:0x40389f10<br />
SPIWP:0xee<br />
mode:DIO, clock div:1<br />
load:0x3c0f0020,len:0xc91a8<br />
load:0x3fc9a100,len:0x4ba8<br />
load:0x40374000,len:0x2298<br />
load:0x42000020,len:0xe5b9c<br />
load:0x40376298,len:0x13e40<br />
Saved PC:0x403743c0<br />
SPIWP:0xee<br />
[FROM M5Burner] Serial Port Disconnected.</p>
]]></description><link>https://community.m5stack.com/post/28614</link><guid isPermaLink="true">https://community.m5stack.com/post/28614</guid><dc:creator><![CDATA[erwantest123]]></dc:creator><pubDate>Sun, 23 Mar 2025 08:38:52 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Fri, 21 Mar 2025 16:31:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/248603">@d4rkmen</a> v1.2 comes with WiFi scan feature and more free flash space for apps.<br />
The Cloud repository:<br />
M5Burner for burner mirror in convenient way.<br />
TOP-20 for best apps tested by me</p>
]]></description><link>https://community.m5stack.com/post/28595</link><guid isPermaLink="true">https://community.m5stack.com/post/28595</guid><dc:creator><![CDATA[d4rkmen]]></dc:creator><pubDate>Fri, 21 Mar 2025 16:31:22 GMT</pubDate></item><item><title><![CDATA[Reply to M5Apps - multiple apps installer on Wed, 19 Mar 2025 22:55:39 GMT]]></title><description><![CDATA[<p dir="auto">v1.1 is out and its crazy</p>
]]></description><link>https://community.m5stack.com/post/28558</link><guid isPermaLink="true">https://community.m5stack.com/post/28558</guid><dc:creator><![CDATA[d4rkmen]]></dc:creator><pubDate>Wed, 19 Mar 2025 22:55:39 GMT</pubDate></item></channel></rss>
