<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CAN I USE EXTERNAL MODULES, LIKE PIR SENSOR, IR SENSOR, ETC WHICH ARE NOT FROM M5STACK FOR PROGRAMMING M2STICKC PLUS 2 in micropython]]></title><description><![CDATA[<p dir="auto">??</p>
]]></description><link>https://community.m5stack.com/topic/7380/can-i-use-external-modules-like-pir-sensor-ir-sensor-etc-which-are-not-from-m5stack-for-programming-m2stickc-plus-2-in-micropython</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Mar 2026 09:10:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7380.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Mar 2025 14:51:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CAN I USE EXTERNAL MODULES, LIKE PIR SENSOR, IR SENSOR, ETC WHICH ARE NOT FROM M5STACK FOR PROGRAMMING M2STICKC PLUS 2 in micropython on Tue, 11 Mar 2025 18:44:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/246708">@DarshanAtwal</a> As long as you know how to program in micropython You can still use programs like Thonny to program directly.</p>
]]></description><link>https://community.m5stack.com/post/28468</link><guid isPermaLink="true">https://community.m5stack.com/post/28468</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 11 Mar 2025 18:44:56 GMT</pubDate></item><item><title><![CDATA[Reply to CAN I USE EXTERNAL MODULES, LIKE PIR SENSOR, IR SENSOR, ETC WHICH ARE NOT FROM M5STACK FOR PROGRAMMING M2STICKC PLUS 2 in micropython on Tue, 11 Mar 2025 15:45:46 GMT]]></title><description><![CDATA[<p dir="auto">at the end its esp32 with screen then any sensor compatible with library for it would work</p>
]]></description><link>https://community.m5stack.com/post/28466</link><guid isPermaLink="true">https://community.m5stack.com/post/28466</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 11 Mar 2025 15:45:46 GMT</pubDate></item></channel></rss>
