<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Add MCP9600 I2C Thermocouple Amplifier - K, J, T, N, S, E, B and R Type T]]></title><description><![CDATA[<p dir="auto">Add MCP9600 I2C Thermocouple Amplifier - K, J, T, N, S, E, B and R Type T</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/7338/add-mcp9600-i2c-thermocouple-amplifier-k-j-t-n-s-e-b-and-r-type-t</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 21:23:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7338.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 28 Feb 2025 02:02:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Add MCP9600 I2C Thermocouple Amplifier - K, J, T, N, S, E, B and R Type T on Tue, 04 Mar 2025 06:16:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mgrouch" aria-label="Profile: mgrouch">@<bdi>mgrouch</bdi></a> KMeter is just the thermocouple converter. The TC insulation itself can be made from plastic or silicon or it can be made from glass fabric. It can also be inside a stainless steel housing or whatever. It depends on the application.<br />
I just did a quick search for exhaust thermosensors and there are many K-type thermocouple in different housing available. As long as they have a TC connector or open wires for mounting one by yourself you can use them with KMeter.</p>
<p dir="auto">I strongly recommend you to read the basics about thermocouples and how they work. You may than understand, that this "plastic thing" can be and should be far away from the high temperature exhaust.</p>
<p dir="auto">By the way: If you feel better with the MCP9600 then buy one from e.g. Adafruit and use it with its library in the Arduino environment. You controller can still be M5. As for the KMeter the MCP9600 breakout is not made to put in the exhaust as well.</p>
]]></description><link>https://community.m5stack.com/post/28385</link><guid isPermaLink="true">https://community.m5stack.com/post/28385</guid><dc:creator><![CDATA[holofloh]]></dc:creator><pubDate>Tue, 04 Mar 2025 06:16:07 GMT</pubDate></item><item><title><![CDATA[Reply to Add MCP9600 I2C Thermocouple Amplifier - K, J, T, N, S, E, B and R Type T on Tue, 04 Mar 2025 00:58:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mgrouch" aria-label="Profile: mgrouch">@<bdi>mgrouch</bdi></a> You are so disappointed with M5Stack.</p>
]]></description><link>https://community.m5stack.com/post/28384</link><guid isPermaLink="true">https://community.m5stack.com/post/28384</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Tue, 04 Mar 2025 00:58:45 GMT</pubDate></item><item><title><![CDATA[Reply to Add MCP9600 I2C Thermocouple Amplifier - K, J, T, N, S, E, B and R Type T on Tue, 04 Mar 2025 00:38:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a></p>
<p dir="auto">What can I do with that? Thermocouple is for measuring higher temperatures. This thing is plastic.</p>
<p dir="auto">Thermocouple for measuring exhaust temperature of a car engine looks quite different.</p>
]]></description><link>https://community.m5stack.com/post/28380</link><guid isPermaLink="true">https://community.m5stack.com/post/28380</guid><dc:creator><![CDATA[mgrouch]]></dc:creator><pubDate>Tue, 04 Mar 2025 00:38:27 GMT</pubDate></item><item><title><![CDATA[Reply to Add MCP9600 I2C Thermocouple Amplifier - K, J, T, N, S, E, B and R Type T on Fri, 28 Feb 2025 03:50:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mgrouch" aria-label="Profile: mgrouch">@<bdi>mgrouch</bdi></a> <a href="https://docs.m5stack.com/en/unit/kmeter" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/unit/kmeter</a></p>
]]></description><link>https://community.m5stack.com/post/28355</link><guid isPermaLink="true">https://community.m5stack.com/post/28355</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Fri, 28 Feb 2025 03:50:15 GMT</pubDate></item></channel></rss>
