<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Controller that can be powered with 5v through GROVE]]></title><description><![CDATA[<p dir="auto">I'm looking for a controller that accepts 5v through GROVE. This is to use it with a heat pump that sends 5v over the 5v line. I know the Atom S3 Lite does. I would be particularly interested in either the M5stickC Plus 2 and the Nano C6. Now I have some basic knowledge of schematics but I can't decide wether these can be powered over GROVE. I looked up all schematics.</p>
<p dir="auto"><a href="https://docs.m5stack.com/en/core/ATOM%20Lite" target="_blank" rel="noopener noreferrer nofollow ugc">Atom S3 Lite schematics</a><br />
<a href="https://docs.m5stack.com/en/core/M5StickC%20PLUS2" target="_blank" rel="noopener noreferrer nofollow ugc">M5StickC Plus2 schematics</a><br />
<a href="https://docs.m5stack.com/en/core/M5NanoC6" target="_blank" rel="noopener noreferrer nofollow ugc">Nano C6 schematics</a></p>
<p dir="auto">I can't read the schematics well enough to decide wether the Stick and Nano can be powered over GROVE. If I look at the Atom S3 Lite schematics I see the GROVE port is wired differently. But that's all I can conclude. It would be great if anyone could help me in wether the Stick and Nano are fit for my purpose and how you came to that conclusion so I can learn from it. Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/7301/controller-that-can-be-powered-with-5v-through-grove</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 21:23:29 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7301.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Feb 2025 22:43:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Controller that can be powered with 5v through GROVE on Sun, 16 Feb 2025 20:40:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thank you! I learned something today by downloading the PDF's and applying what you explained :)</p>
]]></description><link>https://community.m5stack.com/post/28243</link><guid isPermaLink="true">https://community.m5stack.com/post/28243</guid><dc:creator><![CDATA[amateur58]]></dc:creator><pubDate>Sun, 16 Feb 2025 20:40:31 GMT</pubDate></item><item><title><![CDATA[Reply to Controller that can be powered with 5v through GROVE on Sun, 16 Feb 2025 12:52:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/amateur58" aria-label="Profile: amateur58">@<bdi>amateur58</bdi></a></p>
<p dir="auto">you need to open the PDF of the schematic, else you don't see all of it. <code>+5VOUT</code> going to the Grove port comes out of <code>U6</code> going through diode <code>D20</code>. So if you were to feed 5 V to the Grove port it would end at the diode.</p>
]]></description><link>https://community.m5stack.com/post/28241</link><guid isPermaLink="true">https://community.m5stack.com/post/28241</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 16 Feb 2025 12:52:25 GMT</pubDate></item><item><title><![CDATA[Reply to Controller that can be powered with 5v through GROVE on Sun, 16 Feb 2025 09:15:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
Thanks! How did you see that in the schematic for the M5StickC Plus2?</p>
]]></description><link>https://community.m5stack.com/post/28239</link><guid isPermaLink="true">https://community.m5stack.com/post/28239</guid><dc:creator><![CDATA[amateur58]]></dc:creator><pubDate>Sun, 16 Feb 2025 09:15:26 GMT</pubDate></item><item><title><![CDATA[Reply to Controller that can be powered with 5v through GROVE on Sun, 16 Feb 2025 07:10:44 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/amateur58" aria-label="Profile: amateur58">@<bdi>amateur58</bdi></a></p>
<p dir="auto">as you already found out M5AtomS3 can be powered via 5 V through Grove. The same is true for M5NanoC6 as VBUS (from USB-C) is connected to 5 V of the Groove port.</p>
<p dir="auto">However M5StickCPlus2 is different as it has a dedicated 5 V <strong>IN</strong> and 5 V <strong>OUT</strong>. It can only be powered via 5 V <strong>IN</strong> (which is <strong>not</strong> on the Grove port).</p>
]]></description><link>https://community.m5stack.com/post/28237</link><guid isPermaLink="true">https://community.m5stack.com/post/28237</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 16 Feb 2025 07:10:44 GMT</pubDate></item></channel></rss>
