<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Unified 0.2.3 broken on PaperS3]]></title><description><![CDATA[<p dir="auto">My sketches all fail to compile. I am using the 1.8.19 IDE on Linux, haven't moved to the 2.0 IDE yet :</p>
<pre><code>Arduino: 1.8.19 (Linux), Board: "M5PaperS3, Disabled, OPI PSRAM, QIO 80MHz, 16MB (128Mb), Core 1, Core 1, Hardware CDC and JTAG, Enabled, Disabled, Disabled, UART0 / Hardware CDC, 16M Flash (3MB APP/9.9MB FATFS), 240MHz (WiFi), 921600, None, Disabled"
In file included from /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.h:5,
                 from /home/wsanders/Documents/ArduinoSketchbook/M5/badgeWX/badgeWX.ino:2:
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.hpp: In member function 'virtual void m5::M5Unified::begin(m5::M5Unified::config_t)':
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.hpp:326:62: error: no matching function for call to 'm5gfx::M5GFX::init_without_reset(bool&amp;)'
       bool res = Display.init_without_reset(cfg.clear_display);
In file included from /home/wsanders/Documents/ArduinoSketchbook/libraries/M5GFX/src/M5GFX.h:22,
                 from /home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.hpp:19,
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5GFX/src/lgfx/v1/LGFXBase.hpp:1411:10: note: candidate: 'bool lgfx::v1::LGFX_Device::init_without_reset()'
     bool init_without_reset(void) { return init_impl(false, false); };
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5GFX/src/lgfx/v1/LGFXBase.hpp:1411:10: note:   candidate expects 0 arguments, 1 provided
Multiple libraries were found for "WiFi.h"
 Used: /home/wsanders/.arduino15/packages/m5stack/hardware/esp32/2.1.3/libraries/WiFi
 Not used: /home/wsanders/arduino-1.8.19-NOSAVE/libraries/WiFi
exit status 1
<p dir="auto">With 0.2.2 I needed to use these includes, in this order:</p>
<pre><code>#include &lt;epdiy.h&gt;
#include &lt;M5Unified.h&gt;
<p dir="auto">Maybe this has changed? Here's some sample code, it compiles with 0.2.2:</p>
static constexpr const char* state_name[16] =
{ "none"
    , "touch"
    , "touch_end"
    , "touch_begin"
    , "___"
    , "hold"
    , "hold_end"
    , "hold_begin"
    , "___"
    , "flick"
    , "flick_end"
    , "flick_begin"
    , "___"
    , "drag"
    , "drag_end"
    , "drag_begin"
void setup(void)
  Serial.begin(115200);
  M5.begin();
  M5.Display.setRotation(M5.Display.getRotation() ^ 2);
  M5.Display.setEpdMode(epd_mode_t::epd_fastest);
  M5.Display.startWrite();
  M5.Display.setTextSize(2);
void loop(void)
  // too slow! M5.delay(10);
  M5.delay(2);
  M5.update();
  // Count is going to be the bumber of "fingers" detected: 0, 1, max 2
  // So, can be ignored for simple button press
  // Always seems to be 0 inside for loop?
  // auto count = M5.Touch.getCount();
  auto t = M5.Touch.getDetail(0);
  if (t.state &gt; 0) {
  // State is state of the entire touch screen
  // All we care about is t.wasFlicked
      Serial.print(t.state);
      Serial.println(state_name[t.state]);
  M5.Display.display();
]]></description><link>https://community.m5stack.com/topic/7291/m5unified-0-2-3-broken-on-papers3</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 11:59:04 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7291.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Feb 2025 05:01:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Unified 0.2.3 broken on PaperS3 on Fri, 14 Feb 2025 05:19:44 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/18806">@wsanders</a></p>
<p dir="auto">I think these compiler error have been fixed (see <a href="https://github.com/m5stack/M5Unified/commit/bdbb871120429b2315a7af834abf3ecab40b72cb#diff-aee5cba25eeb82e0bb266a1c273fba6dfae4753bf3bdcdbe569360ff5fd6b153L338" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>), but after tagging the library. I guess it will be in M5Unified 0.2.4.</p>
]]></description><link>https://community.m5stack.com/post/28219</link><guid isPermaLink="true">https://community.m5stack.com/post/28219</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 14 Feb 2025 05:19:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5Unified 0.2.3 broken on PaperS3 on Thu, 13 Feb 2025 19:58:18 GMT]]></title><description><![CDATA[<p dir="auto">Still a problem:</p>
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp: In static member function 'static bool m5::M5Unified::_speaker_enabled_cb_atomic_echo(void*, bool)':
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:338:10: error: variable 'spk_cfg' set but not used [-Werror=unused-but-set-variable]
     auto spk_cfg = self-&gt;Speaker.config();
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp: In static member function 'static bool m5::M5Unified::_microphone_enabled_cb_atomic_echo(void*, bool)':
/home/wsanders/Documents/ArduinoSketchbook/libraries/M5Unified/src/M5Unified.cpp:441:10: error: variable 'spk_cfg' set but not used [-Werror=unused-but-set-variable]
cc1plus: some warnings being treated as errors
exit status 1
Error compiling for board M5PaperS3.
<p dir="auto">M5GFX is now 0.2.5, M5United is 0.2.3, this bug comes from M5United, upgraded M5GFX is OK.</p>
<p dir="auto">Too busy today to file a bug report on this, later.</p>
]]></description><link>https://community.m5stack.com/post/28213</link><guid isPermaLink="true">https://community.m5stack.com/post/28213</guid><dc:creator><![CDATA[wsanders]]></dc:creator><pubDate>Thu, 13 Feb 2025 19:58:18 GMT</pubDate></item><item><title><![CDATA[Reply to M5Unified 0.2.3 broken on PaperS3 on Thu, 13 Feb 2025 07:53:20 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/18806">@wsanders</a></p>
<p dir="auto">the error indicates that M5GFX library is out of date. Did you update M5GFX library to the latest as well?</p>
]]></description><link>https://community.m5stack.com/post/28196</link><guid isPermaLink="true">https://community.m5stack.com/post/28196</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 13 Feb 2025 07:53:20 GMT</pubDate></item></channel></rss>
