<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The Speaker playing a wave file in UiFlow 2 sounds strutter while it plays fine in UiFlow 1.14]]></title><description><![CDATA[<p dir="auto">I have an SDCard with a wave file. When I play a wave using Speaker in UiFlow 2, it plays the sound clip however the sound is not playing smoothly,  it strutters (hard to explain..but it is like having short pauses all the time).  Changing to new wave files still results in the same way.  However, when I changed it to UiFlow 1.14, it played correctly.  I guess that I have missed some settings or didn't properly initialize something in UiFlow 2.  I tried to search around but still had no luck. If you have any suggestions, would you please help (or give me some ideas about where should I look into)?  Thank you very much.</p>
]]></description><link>https://community.m5stack.com/topic/7265/the-speaker-playing-a-wave-file-in-uiflow-2-sounds-strutter-while-it-plays-fine-in-uiflow-1-14</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Mar 2026 04:36:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7265.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Feb 2025 12:24:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to The Speaker playing a wave file in UiFlow 2 sounds strutter while it plays fine in UiFlow 1.14 on Sun, 16 Feb 2025 01:44:03 GMT]]></title><description><![CDATA[<p dir="auto">I had a similar issue. What solved it for me, was to add the Init SDCard block and increase the frequency. So I'm guessing that reading from the sd card was just to slow to be able to play the music smoothly</p>
]]></description><link>https://community.m5stack.com/post/28235</link><guid isPermaLink="true">https://community.m5stack.com/post/28235</guid><dc:creator><![CDATA[zaraken]]></dc:creator><pubDate>Sun, 16 Feb 2025 01:44:03 GMT</pubDate></item></channel></rss>
