<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to add multiple modules]]></title><description><![CDATA[<p dir="auto">Hello,<br />
Does anyone know if it would be possible to add a cc1101 transceiver and a pn532 to the same m5stick and how would this be done?</p>
<p dir="auto">All advice is appreciated!</p>
]]></description><link>https://community.m5stack.com/topic/7204/how-to-add-multiple-modules</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Mar 2026 14:27:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7204.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Jan 2025 07:24:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to add multiple modules on Fri, 04 Apr 2025 20:05:53 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, it's possible! You just need to make sure the modules use different communication protocols or assign different pins if they're both using something like SPI. The CC1101 typically uses SPI, and the PN532 can use I2C or SPI—so setting the PN532 to I2C might make things easier.</p>
]]></description><link>https://community.m5stack.com/post/28799</link><guid isPermaLink="true">https://community.m5stack.com/post/28799</guid><dc:creator><![CDATA[Slarck]]></dc:creator><pubDate>Fri, 04 Apr 2025 20:05:53 GMT</pubDate></item><item><title><![CDATA[Reply to How to add multiple modules on Thu, 20 Feb 2025 10:55:16 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://www.youtube.com/watch?v=mbAgfB75xso" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=mbAgfB75xso</a></p>
]]></description><link>https://community.m5stack.com/post/28276</link><guid isPermaLink="true">https://community.m5stack.com/post/28276</guid><dc:creator><![CDATA[flypeek]]></dc:creator><pubDate>Thu, 20 Feb 2025 10:55:16 GMT</pubDate></item><item><title><![CDATA[Reply to How to add multiple modules on Tue, 18 Feb 2025 21:27:28 GMT]]></title><description><![CDATA[<p dir="auto">Adding multiple modules to an M5Stick is possible, but you'll need to plan the connections carefully to avoid pin conflicts. Check the pinouts and consider using an expansion board. With the right firmware, you can get both the CC1101 and PN532 working together.</p>
]]></description><link>https://community.m5stack.com/post/28274</link><guid isPermaLink="true">https://community.m5stack.com/post/28274</guid><dc:creator><![CDATA[Slarck]]></dc:creator><pubDate>Tue, 18 Feb 2025 21:27:28 GMT</pubDate></item></channel></rss>
