<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[noting shows on m5stick and unable to connect to pc]]></title><description><![CDATA[<p dir="auto">can someone help me fix my m5stick plus 2</p>
]]></description><link>https://community.m5stack.com/topic/7039/noting-shows-on-m5stick-and-unable-to-connect-to-pc</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 05:42:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7039.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Nov 2024 09:36:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to noting shows on m5stick and unable to connect to pc on Tue, 03 Dec 2024 05:49:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/192341">@Hristak</a> Is it charged?<br />
Have you checked that you are using a working data cable and not a charge cable?<br />
Did you erase firmware before burning new?<br />
Did you select the correct firmware version?<br />
What computer are you using?<br />
What OS are you using?</p>
]]></description><link>https://community.m5stack.com/post/27319</link><guid isPermaLink="true">https://community.m5stack.com/post/27319</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 03 Dec 2024 05:49:48 GMT</pubDate></item><item><title><![CDATA[Reply to noting shows on m5stick and unable to connect to pc on Mon, 02 Dec 2024 08:19:48 GMT]]></title><description><![CDATA[<p dir="auto">when you open M5burner and you connect USB to your M5StickC+2 can you see com port number popup in top right corner of M5burner?<br />
if so then download latest firmware for your M5StickC+2, hit erase, then burn</p>
]]></description><link>https://community.m5stack.com/post/27293</link><guid isPermaLink="true">https://community.m5stack.com/post/27293</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 02 Dec 2024 08:19:48 GMT</pubDate></item><item><title><![CDATA[Reply to noting shows on m5stick and unable to connect to pc on Mon, 02 Dec 2024 02:34:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/192341">@Hristak</a><br />
have you tried replacing a cable?</p>
]]></description><link>https://community.m5stack.com/post/27280</link><guid isPermaLink="true">https://community.m5stack.com/post/27280</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Mon, 02 Dec 2024 02:34:04 GMT</pubDate></item></channel></rss>
